03-10-2016, 05:19 PM | #1 |
Rep 647
UPDATE: Soaked Carpet
I have a leak somewhere in my car but not sure where... Only the passenger floor behind the driver is flooded. Has about an inch of water from overnight in the rain. Any idea where it could be coming from? I had my windows tinted recently but not sure how that can affect the water coming in. Positive my windows and sunroof was closed. No signs of seepage from the roof
UPDATE: Vacuumed most of the water out and put baking soda on all the carpets to soak up some of the moisture. Vacuumed most of the wet baking soda out after a couple hours but there's still white powder I can't get off the carpet. Luckily I couldn't get the powder completely off, because when I get into my car in the morning, I see where the water is coming from and going since it gets wet and I see the powder stains go away. Looks like there's two small puddles around the velcro for the driver side floor mat and it's leaking towards the back via the seat rails. Any idea what's under the velcros? It's going into the dealership on Monday. Last edited by Project Elite; 03-18-2016 at 04:25 PM.. |
03-11-2016, 02:51 AM | #3 |
64-bit
598
Rep 814
Drives: 2018 BMW 340i xDrive
Same thing happen to my gfs E90. Passenger side carpet would get soaked when raining overnight. Ended up being a small crack on bottom right side of the windshield. My guess would be checking there..
03-11-2016, 03:28 AM | #4 |
Rep 188
I never had to deal with a water leak before but I did some searching and found these links which I thought might be useful:
http://www.motorweek.org/features/go...interior_leaks https://www.youtube.com/watch?v=QC2IUgIXUD0 https://www.youtube.com/watch?v=Af3rq-fNPV0 Hopefully some other members have some better advice for you, but while you're waiting for more responses you can check out some youtube videos. There's a bunch of them for various BMW models which may not pertain to yours specifically but might give you some ideas and possibly help narrow it down. Does you car have high mileage? Has it ever been in an accident or had some kind of custom work?
2012 BMW 320i Alpine White (300) Premium Package (ZAR) Lighting Package (ZAU) Navigation Package (ZAV) Rear Park Distance Control (507) Automatic (205) |
03-11-2016, 05:38 AM | #5 | |
Stark und Frei
48
Rep 155
03-11-2016, 06:58 AM | #6 | |
Rep 4,439
Drives: '23 X1 28i xDrive
03-12-2016, 05:51 AM | #7 | |
Rep 1,114
Even if you have take hose and simulate rain on the roof/sides/etc. do it so you can see where its coming from.
My Ride! : 2015 428i GC (F36) - MSport, Alpine, Black Leather, MBrakes, Adaptive, Sport Seats, Hex. Alum w/Piano, HK Sound, 400m's, Comfort Acc. When I’m not Driving: https://youtube.com/shorts/ViKD_Hj5htE?feature=share
03-12-2016, 06:03 AM | #8 |
Rep 20
This happened to my car 6 months ago. I believe the culprit was both the door handle seal and plastic seal between the door frame and the door panel. Take it to your service rep and they will fix it in a day. Unfortunately I am taking my car in again next week to fix the passenger side door for the same problem.
03-13-2016, 12:34 AM | #9 | |
Rep 188
03-13-2016, 10:54 AM | #10 |
Rep 20
The first time this happened to me my vehicle had ~40900 miles on it. After looking through my service records the Vapor Barrier was faulty. They removed and replaced the vapor barrier and butyl. This time my vehicle now has ~49000 miles. The rear door had roughly twice the amount of water shown in the below image. Good luck!
03-13-2016, 12:22 PM | #12 |
Rep 4,551
Most likely water barrier inside door panel. To test use a hose on front and rear door glass and around handle. Have a 2nd person inside looking for water leaking between door panel and metal door.
Be patient and spray water for a minute or two. Sometimes takes a bit before you see the water flow from behind door panel.
2023 840GC | 2021 740i | 2019 X3
07-10-2018, 09:18 PM | #16 |
Rep 943
Drives: 2012 328i Modern Line
Just realized I had soaked carpet in rear passenger carpet. I've found videos/posts about front drain plugs behind front wheels but nothing about rear drain plugs. Do any of you have experience fixing these?
:wave:
07-11-2018, 03:19 AM | #17 |
Rep 4,456
I used compressed air to clear out the hose. Just make sure the hose is connected after pushing air through it. I knocked one end off and caused even more water to drain into the car until I put the hose back on.
etinifni203.00 MacklinUSOB518.00 |
07-11-2018, 09:35 PM | #18 |
Rep 943
Is there instructions on how to do this?
:wave:
07-11-2018, 09:47 PM | #19 |
Rep 4,456
07-12-2018, 10:15 AM | #20 | |
Rep 891
My old Saab would pool water in the drainage ducts and when I set off on a morning after a rain I'd get a quart or two of water dumped into my lap. Fun times.
328i RWD | MW on CRed Slick Top | 6MT | BM3 | MPE | GPlus FMIC | CSF Radiator | Millway Street Camber Plates & Monoballs | KW V2 6k/18k Swift Springs | F80 LCA/TS | SPL Bump Steer Kit | APEX SM-10 | R-S4 | DS2500 | RBF600 | SS Lines | Past: E36 328is & E38 740i |
07-12-2018, 03:43 PM | #21 |
no relation
130
Rep 442
I have had this similar issue before, of the rear driver carpet getting soaked in rain or after car wash. Turned out to be the vapor barrier on the door was "unstuck"/broken.
11-15-2021, 09:36 PM | #22 |
Rep 4
Bumping this old thread in hopes that the OP got this issue resolved, and can report back what it was. I have the same issue (2016 340xi), with A LOT of water making its way into the back passenger area on the driver's side. I have narrowed it down to water coming through the firewall when the driver side drain is overwhelmed with water. Initially the drain was clogged, but it has been cleaned and now the water only comes in if I pour a lot of water into the drain such that the water flows rearward towards the firewall.
I took off the accelerator pedal and it there is a lot of dampness there. Hard to tell if its a clue, or just that its a low spot. Could be coming in where the throttle wire goes through the firewall? Its most definitely not coming in through the doors or sunroof etc, as I have done a very focused pour of water from a bottle into the drain. Any insights welcome, this is driving me nuts. |
