05-10-2024, 11:23 AM | #3 |
Rep 59
All of these lights came on at once after no prior errors ?
05-10-2024, 11:30 AM | #5 |
Rep 7
05-10-2024, 11:34 AM | #6 |
Rep 59
05-10-2024, 11:38 AM | #7 |
Rep 7
05-11-2024, 11:58 AM | #8 |
Rep 14
Drives: 2014 BMW 435i xdrive
Is it tuned? I have the same issue rn
05-11-2024, 12:02 PM | #10 |
Rep 14
05-11-2024, 12:12 PM | #12 |
Rep 14
mb i didn’t see what you said about not being able to scan it. your best bet is to go fill up your tires and reset your tpms, i can see your light is on. i’d look into getting a code reader if the chassis stabilization stays on. i linked the one i have below, it works great and reads both the DME and DTC codes. even if it’s just the tpms, there’s a possibility the chassis stabilization will stay on until you manually clear the codes in the DTC. you can try to put it into sport/ eco while you’re driving to see if the cars being fr or not.
i don’t reccomend you take it to get diagnosed yet. my wheel speed sensors fried themselves after flashing and didn’t give me any issues, despite showing up in the DTC. took it to some local places and the dealer, they were no help until the car bricked the trans months later. Creator C410 https://www.amazon.com/Creator-Scann...Y2hfYXRm&psc=1 |
05-14-2024, 06:50 PM | #13 | |||
Rep 1
05-14-2024, 08:06 PM | #14 |
Rep 810
Scanning takes like 30 seconds, if you don’t have a scanner Autozone used to scan for free. If they do just write down the codes and post them. Not possible to take a guess just off of those pop up’s.. I can certainly tell you you’re tire pressure is low though 🤷‍♂️
MG F30 M-Sport 6mt FBO w/ MHD stage 2 plus (PWG), ST XA Coilovers, 19" VMR V804.
05-14-2024, 08:07 PM | #15 |
Rep 810
Also just saw your post about being tuned, MHD ir BM3? Both have the ability to scan for codes
05-16-2024, 12:04 PM | #16 | |
1322
Rep 3,593
It can be a hundred things man.. without codes nobody can help you at all. It might be the battery, might be a sensor, might be a wire, might be etc etc etc etc and etc.. and etc and etc.. and another 30 causes.. or, could be a different 5 things.. OR it could be something else, or even something else. Fucking scan the car man.. it's literally the only way to try and guess.
2017 m240i xDrive 10.67@132.32mph w/bm3
LA1Z24431.50 |
05-16-2024, 01:46 PM | #17 | |
Rep 881
05-16-2024, 01:48 PM | #18 |
1322
Rep 3,593
Oh.. my bad
OP.. it's the rod bearings.. you spun them
05-16-2024, 10:36 PM | #20 |
Rep 810
