07-18-2018, 03:11 PM | #1 |
Rep 1,170
acceleration hiccups
hey you guys so I have been having this problem for some time now but have been ignoring it
I got some other stuff fixed on the car now I want to get this taken car if So on sport mode I notice that when I do a slightly hard acceleration or hard acceleration I get like misfires it hiccups like even a burble at mid Rpm even tho I'm pressing the gas pedal and some times a big cloud of black smoke The car is stock only thing is muffler delete and bms intake you think is a ignition problem Maybe new coils packs Sparks was replaced at 55k Car has 68k now or is it carbon build up Maybe I need a walnut shell blasting or ????? Anyone have any suggestions or opinions By the way I do not get a check engine light or nothing
bmw m2
07-19-2018, 07:07 AM | #2 |
Rep 6,987
First thing you want to do is check for any problem codes with an OBD-II code reader - they don't always produce a check-engine light. Could be a bad coil pack or injector issues - I'd have those checked. Carbon buildup would likely not produce the misfire or black smoke you mentioned.
07-19-2018, 09:37 AM | #3 | |
Rep 279
13' F30 335i - BMS Intake -- VRSF DP -- VRSF CP -- VRSF 5" Stepped Intercooler -- Corsa Touring Catback -- JB4 -- H&R Springs -- Miro Flow Formed F25's
07-19-2018, 11:09 AM | #4 | |
Rep 1,487
Drives: 2108 X3 xDrive30i
07-19-2018, 11:11 AM | #5 | |
Rep 1,170
Ima look in to that today
bmw m2
07-19-2018, 01:26 PM | #6 | |
Rep 1,170
the car runs great I only feel this when I have the pedal like 50 to 85% Once I hit the button on the bottom of the pedal The car pulls smooth no problem no hiccups So idk if that helps a bit
bmw m2
07-19-2018, 01:29 PM | #7 | ||
Rep 1,170
I just got that checked at a local shop No codes pop up never has I been having this issue for quite a while Even when I had jb4 At first I thought it was jb4 so I removed it Now I'm stock and I still have the same issue But never saw a check engine light or a code for this So what you guys think Maybe carbon build up ?
bmw m2
07-19-2018, 01:35 PM | #8 | |
Rep 1,170
bmw m2
07-19-2018, 02:14 PM | #9 |
Rep 1,170
https://www.fcpeuro.com/products/bmw...-12131712219x6
can anybody confirm that these would be the correct ignition coil pack aro buy for my car ? Or is there another brand that's recommended I'm thinking of starting off with coil packs and see if that helps my problem
bmw m2
07-19-2018, 04:17 PM | #10 | |
Rep 117
07-19-2018, 04:18 PM | #11 | ||
Rep 1,170
bmw m2
07-19-2018, 11:42 PM | #13 | |
Rep 1,170
The bms intake I just installed maybe about a week ago I have been having this issue way before the intake
bmw m2
07-20-2018, 05:22 AM | #14 |
Rep 2,015
If you do get a walnut blast done. can you please post picture of what your intakes looked like before the blasting?
I just want to see how much build up there was. Also you did everything for your problem except Walnut blast, so try it. or at least have them inspected. |
07-20-2018, 07:51 PM | #15 | |
Rep 1,170
Then Next will be walnut shell blast
bmw m2
07-20-2018, 08:24 PM | #16 |
Rep 3,679
Sounds kinda like LSPI (low-speed pre-ignition). I only say that because of the black smoke, otherwise I wouldn't have thought of it. This happens in low rpm, but high load conditions, like 50% throttle at 2500-3000 rpms. I'd read about LSPI a bit and see if that sounds like the issue you're having.
07-20-2018, 08:56 PM | #17 | |
Rep 1,170
bmw m2
07-21-2018, 12:48 AM | #18 | |
Rep 1,170
I did read and saw some videos and they said something about high gear and building up boost on a high gear and having Miss fires But my car is doing it on 1st 2nd 3rd lol Is like a constant hiccups all through gears from 1-8
bmw m2
07-21-2018, 07:31 AM | #19 | |
Rep 3,679
07-22-2018, 10:05 PM | #20 | ||
Rep 1,170
When I had jb4 Had the same exact problem I think is the coil packs
bmw m2
07-23-2018, 05:22 PM | #21 |
Rep 155
I had a similar problem. Was worse with the piggyback but present even without. Car was otherwise stock. Dealer replaced coils and plugs @ 55k and it went away. 12k miles later and it's back....
07-23-2018, 06:08 PM | #22 |
Rep 101
This happened to me at WOT throttle only. It didn't always throw a code. It would throw a code maybe after 3-4 back-to-back WOT runs. Cylinder 6 misfire. Only happened on my BM3 tune though. I ended up replacing the coil packs and everything is fine now.
2015 335i ///M-Sport 8AT | M Performance Exhaust/Brakes/Suspension | BMS CP | BM3 Stage 2 | VRSF FMIC | AR Design DP | AFE Filter | RES Delete | BavAuto Coils | P3 Gauge | xHP Stage 3 |
