01-30-2020, 07:25 PM | #1 |
Rep 179
B58 cylinder scoring/injector failure <any and all experiences>
Good evening,
I am writing to try to get info, and outcomes from anyone who.may have experienced the same issue I am having. Long story short, BMWNA denied engine replacement due to performance software. I am looking for any documented cases I can provide as evidence, especially if it resulted in engine replacement by BMW. 2016 340i rwd at 42k Dinan intake, VRSF downpipe, remus exhaust, bm3 stage 2 Cylinder misfire, scoring on cylinder walls (#6) Thanks for any help! |
01-30-2020, 08:06 PM | #2 |
Rep 4,877
What exactly do you expect to achieve here? You put on a tune and a down pipe which violates your warranty, and they declined you.
That is as cut and dry as you can possibly get. You need to pay to play, and there is always a risk. Was the scoring related to the tune? Probably not, but they have ZERO reason to entertain that idea. |
01-30-2020, 09:01 PM | #3 | |
Rep 179
01-31-2020, 07:31 AM | #5 | |
Rep 913
Drives: '17 F22,15 E84 M Sport,02 R53
Posting this in a public forum will get you both support and the things you do not want to hear. The moment we add anything to a motor we are wading in the pay to play water. Chill out.
Silverlining_m21734.50 pyrorupt3.00 |
01-31-2020, 08:16 AM | #6 |
Rep 201
If a fellow enthusiast cannot ask for this kind of feedback/help in a place like this in a dire moment in time than what are we all doing here? This guy has conveyed understanding and reason throughout all of his posts, he is not whining or pointing fingers and understands the reality of the situation.
At the same time, he had a widely used tune on his car for only 4000 miles and injector failure/scoring is something we have seen on b58s running bone stock. If you don't have something to contribute than keep your keystrokes to yourself and move on while also crossing your fingers that you never find yourself in a situation like this. |
Beek707.00 Supr3me552.00 Mehim76.50 TanzM4197.00 Stlblues68.50 helloelectro174.00 teapain146.50 Londoner168.00 Boostedphil698436.00 WrxToBeamerGuy492.00 samspiderman312545.50 blueboxer0070.00 |
01-31-2020, 09:47 AM | #7 |
Rep 79
Honestly, a database of these failures would be a good thing, regardless of whether it gets OP a new engine. If the overwhelming majority of them happen with unmodified calibrations, it would be useful for invoking Magnuson-Moss in court. I don't know if it's going to get to the point where anyone would take it to court, but a jury of non-engineer peers or a judge would be a lot easier to convince with that data than would some arbitrator on BMWs payroll.
Disclaimer: I am not a lawyer. I'm interested to see the split though. |
01-31-2020, 10:02 AM | #8 | |
Rep 179
That's a great idea, as this seems to be an emerging issue.on some b58s. If the failure on my engine was caused by a known issue I intend to push it as far as I need to hold BMW accountable. That being said I obviously understand it may be all for naught and I knew that when I started modding. |
01-31-2020, 11:24 AM | #9 |
Rep 98
I like the idea of this thread so we can have a central "database" to document the failures and see if there's a pattern. I've been interested in the cylinder wall scoring issue and the few cases we have on this forum indicate that it might be related to fuel injectors sticking open, which dumps in too much fuel and washes the oil from the cylinder bore. Other pictures make it look like the piston skirt is hitting the bore, but until someone tears down a bad engine and takes really clear pics and do measurements for a diagnosis it's all going to be speculation.... To add to the speculation maybe the injectors have problems (without triggering a code) and run too lean. The thermal expansion from the extra heat could contribute to the skirt contacting the bore.
The B58TU received an updated fueling system and I recall reading the wire arc spray thickness was increased too, but I'll have to dig to find the source. There was also a change to the cylinder bore honing process to achieve optimal bore shape during operation: "The cylindrical bore hole of a combustion engine becomes deformed during the operating condition by thermal loads. Form honing allows this deformation to be achieved in production, so that there is an almost cylindrical shape in the operating condition. This has a positive effect on the emissions quality, oil and fuel consumption, as well as output and wear." So maybe part of the issue is excessive "warping" when the engine is under load? The link below has a lot of good information explaining the differences between the B58 and B58TU https://f30.bimmerpost.com/forums/at...4&d=1565745080 Last edited by StannisBaratheon; 01-31-2020 at 11:35 AM.. |
01-31-2020, 11:50 AM | #10 |
Rep 10,352
What sort of engine air filter? I'd look there first.
What oil were you running?
"Drive more, worry less. "
01-31-2020, 12:09 PM | #12 |
Rep 1,454
That won't work. A PUMA case was most likely opened for engine failure (these are rare). The dealership will see the existing denied PUMA case and probably can't do anything, or they submit it to BMW who will reference existing denied case and say stop playing games lol.
01-31-2020, 12:52 PM | #13 | |
Rep 1,239
Air filter question is an interesting one, iirc the OP said he had a fault code or something once when the filter wasnt installed correctly, i would have though in the short space of time it would of struggled to in hail some partials to cause damage. I know people run some cars/turbo set ups with no filters ( i dont get it) but are these new sprayed bores acceptable to damage through dirt really easy? |
01-31-2020, 07:28 PM | #14 | |
Rep 4,877
Not trying to be a d*ck here, but your question is a serious WTF. Good luck OP. Your claim has already been flagging in the BMW warranty system and EVERY dealership will give you the same answer. |
01-31-2020, 08:36 PM | #15 | |
Rep 179
Supr3me552.00 les anderson145.50 M140_BCS237.50 BimBimM21486.00 Mehim76.50 B58togo808.50 about94ninjas94.50 teapain146.50 Londoner168.00 isenc2146.50 |
01-31-2020, 11:06 PM | #16 | ||
Rep 201
A quick search reveals a recent stage 2 flash tune, aftermarket plugs gapped to non oem specs leading to a plug failure and catastrophic engine failure. BMW replaced this engine under warranty. The thread celebrates the engine swap! Your out of line and your spirit is out of sync with what we are doing here. Stop being a douche! |
01-31-2020, 11:18 PM | #17 |
Rep 179
I have read this thread as well. I PM'd the OP to get more info from him about what the dealer said, whether they could see the tune, etc. I'm curious to hear as they seemed to have no problem replacing the engine in his case.
02-01-2020, 01:40 AM | #18 |
Rep 231
There has been many cases with this issue bone stock and tuned.
disintegrator66412.50 |
02-01-2020, 04:41 PM | #19 |
Rep 90
Wow. Such documentation.
Bootmod3 | BMS intake | Dinan springs and swaybars
02-01-2020, 04:43 PM | #20 |
Rep 90
les anderson145.50 |
02-01-2020, 10:35 PM | #22 |
Rep 231
Sorry I'm not BMWNA to pull up this "documentation" you're after. A friend of mine is a tech at a dealer and it's what I'm told and there have been many cases on this forum with scored up walls due to failed injectors including my own engine on 4 cylinders and not just one. The first one noted occurred in 2016 and it was not flashed..... JB4 only + meth and luckily the dealer covered it. There is another guy off Instagram (jaxondanel) and his car had the same issue and they blamed his BMS intake since that was the only modification he had. I'm not going to dig deep into which users and people have suffered with this issue.... I'm living proof with 4 scored up walls with 4 failed injectors.
