09-11-2016, 08:55 AM | #45 |
Rep 172
would like to hear feedback on n20 users with supersprint exhaust, especially whether if there is drone on low rev and improvements over stock. I can't really tell from the YouTube clips.
Thank a lot! |
08-06-2017, 11:35 PM | #46 | |
f30harp
Rep 4
**** if I purchase the entire system (cat back Remus or AFE) then I will not need an adapter correct? I will just need to cut my rear bumper to fit the exhaust... am I right? |
08-09-2017, 11:02 AM | #47 |
Rep 589
Question: Did you all source your exhausts using the 328i model? Haven't really found anything that's sold specifically for a 320i 2012-16 online yet. At least, for dual exhaust as that's what I'm looking into.
08-17-2017, 08:33 AM | #49 | |
Rep 62
https://ibb.co/nnCxMa Separately does anyone know the outer diameter of the 320i B48 LCI pipe at pictured location? I got 66mm by my measurement which seems off from any known pipe and clamp diameter (2.5inch/64mm, 2.75inch/70mm). I'm looking to get a band clamp but don't know if they'll fit with the pipe being 2mm wider than 2.5 inches. I'm new to this so, when people say a clamp is 2.5 inches is that an inner or outer diameter, or just a nominal figure with some implied inaccuracy? Or is my measurement off? Thanks! https://ibb.co/dqSsnF Last edited by hmmwvj; 08-17-2017 at 09:15 AM.. |
09-20-2017, 04:51 AM | #51 |
Rep 5
Hi,
Know this is a old thread but hope somebody can help me with my issue. My M Performance exhaust is being delivered with the mid pipe aswell. Is there also size different between 328I and 320I at the beginning of the midpipe where it is going to be attached to the downpipe? If so, what is the solution to make this fit? |
10-15-2017, 02:01 AM | #52 |
Rep 172
Believe there is a front pipe in between the midpipe and downpipe. The front pipes (20i and 28i) have different parts number but the clamp (part number 18308632361) is the same. Probably need a clamping bush from 28i.
I am looking to swop a stock 28i midpipe over to 20i, on he assumption that it will increase power? Anyone knows? |
03-30-2020, 10:39 AM | #53 | |
Rep 47
I stand corrected. I've measured the 320i exhaust / midpipe and the OD is indeed 60,2 - 60,3 MM. The 328i exhaust is as you say 75MM OD (Outer Diameter) which is correct and has an ID (Inside Diameter) of 70MM. I think, and which I'm going to try, is that you can order a reducer with below specs: Explaining:
I think I mainly explained it for myself, because my head was spinning with ID/OD. Last edited by Poechi; 04-04-2020 at 07:40 AM.. |
03-31-2020, 03:45 AM | #54 |
Rep 10
320i exhaust recommendations
I want to get a exhaust for my 320i 2015....
i have done a muffler delete so far and it sounds good but not great. i am getting burbles due to bootmod3 stage 1 but i want to get a better quality sound . . . what do you guys recommend to get . please any help and suggestions |
03-31-2020, 08:42 AM | #55 |
Rep 5,457
Drives: F30
@youngmagiic
Any pics of your muffler delete? |
03-31-2020, 10:25 AM | #56 |
Rep 1,065
04-03-2020, 12:53 AM | #57 |
Rep 110
Does anyone happen to have a muffler delete + catless on the N20 320i/328i or have any experience with it? Would be great to hear the sound, even better if you have a tune! I'm currently catless with the magnaflow muffler and might take the whole muffler off and add a vibrant res in replacement.
sspade2466.00 |
04-03-2020, 10:38 AM | #58 | ||
Rep 63
If you remember Porsche originally tuned the 930 by size of the exhaust system, which I suspect is why BMW put a smaller exhaust pipe on the 320 when compared to the 328. The biggest gain you will have will be replacing the downpipe, it will reduce the back pressure on the turbo and reduce the egt's (exhaust gas temps) and as a result it will help protect your engine and turbo from potential damage.
2015 320i
2006 330i 2004 545i 2001 M Roadster |
04-03-2020, 12:54 PM | #59 | |
Rep 1,065
Patel15123.00 |
05-06-2020, 05:01 PM | #60 |
Rep 98
01-27-2021, 12:23 PM | #61 |
Rep 5
Borla Exhaust on a Xdrive 428i
I'm wondering if any one has installed the Borla Cat Back Exhaust S Type Series (140509) on a 328i or a 428i Xdrive. What were the modifications you had to do to make the exhaust system work? I have a 2014 428i Xdrive with a n20 downpipe.
