BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > UK > Coding EBT - squeeky bum
proTUNING Freaks
      03-04-2014, 07:04 AM   #1
dazzapb
Drives: 2019 X3M Comp
Apologies for the new thread but I want to get the best audience
Little bit of a squeeky bum time - spend most of this morning looking at e-sys etc.
I was also using this video to get a few tips etc - nice vid
www.youtube.com/watch?v=pPhZ7kep1aY
So onto the EBT coding. below I followed part one and did a VO code and changed 6NH to 6NK. All ok as its all in the PDF.
Onto part 2 then. I just need more detail here, I can see that the change is all ok for part 1.
So I go back to coding right click on ECU and select code. I followed this instructions here:
In this case, you VO Code HU_CIC and CMB_MEDIA, which is the same process as FDL Coding, except you highlight the ECU itself, not the underlying CAFD entry, right-click on it, and select CODE (NOT FDL Code).
When you do this, it will code the entire ECU to support all options in the VO, so you do not have to manually FDL Code, each and every required parameter needed to support an option.
Things reboot and I get all sorts of errors (driving, ecu) that have gone but still no EB
Could someone please give me step by step instructions on 2 please
Ie what icons to click etc. Don't want to do that again without being certain what to do. Also bear in mind that the first part is done? Do I have to do it again.. and load some files again?
Cheers
1) Read this Guide:
How to change FA in F-series car:
http://www.f30post.com/forums/attach...4&d=1338274757
Afterward, you should understand how to replace 6NH with 6NK in your VO.
2) VO Code HU_CIC and CM_MEDIA ECU's:
Connect => Read FA (VO) => Activate FA (VO) => Read SVT (VCM) => Right-Click on ECU (the ECU itself not the underlying CAFD) => Select CODE.
      03-04-2014, 08:15 AM   #2
Jim-Bow
Jim-Bow's Avatar
Wales
131
Drives: G16 840i
Assuming you have pro nav, you shouldn't be touching the CIC - recent pro nav units use NBT.
Also I don't think 6NK is an option on recent cars, 6NS is the appropriate option for in the UK.
Change the VO to 6NS and code the NBT.
Now- 2021 G16 840i
Last- 2017 G30 530d
Prev- 2013 F30 330d
      03-04-2014, 08:34 AM   #3
dazzapb
Cheers Jim. So NBT should be in the coding screen under the ECU tree? Right click and code it?
Thanks!
      03-04-2014, 08:37 AM   #4
paulf
paulf's Avatar
Drives: 330e M Sport 2020
Thanks!
Some screen dumps would be useful....
Driving - 330e M Sport 2020
Previous - 2017 F32 420d M Sport, 2014 F30 330d M Sport, 2011 E90 320d Efficient Dynamics
      03-04-2014, 08:40 AM   #5
dazzapb
Sure i will get them later. Thanks
      03-04-2014, 08:49 AM   #6
Jim-Bow
Jim-Bow's Avatar
Wales
131
Drives: G16 840i
Thanks!
Yup should be there at the top level of the tree.
If you have NBT you definitely want to use 6NS in your vehicle order (FA/VO) 6NK isn't supported.
Now- 2021 G16 840i
Last- 2017 G30 530d
Prev- 2013 F30 330d
      03-04-2014, 09:21 AM   #7
dazzapb
nice one guys I think it worked! in the car typing this
I coded the entire ECU before - didn't single out NBT...
As i got lots of errors on the idrive before do you think I might have done something bad? they cleared after a while
I don't have a token so I doubt it?
      03-04-2014, 09:23 AM   #8
dazzapb
this was the error log from this morning
TAL execution started.
ExecutionID=2014/03/04-12:38:28.884
[] prepareTALExecution started
[] prepareTALExecution finished
[] prepareVehicleForCoding started
[] prepareVehicleForCoding finished
[FEM_BODY - 40] prepareECUforCoding started
[FEM_BODY - 40] prepareECUforCoding finished
[FEM_BODY - 40] authenticateECUforCoding started
[FEM_BODY - 40] authenticateECUforCoding finished
[FEM_BODY - 40 - cafd_00000794-007_031_012] Transaction type: cdDeploy; Message: TA started
[FEM_BODY - 40 - cafd_00000794-007_031_012] Transaction type: cdDeploy; Message: TA finished
[FEM_BODY - 40] finalizeECUCoding started
[FEM_BODY - 40] finalizeECUCoding finished
[HU_NBT - 63] prepareECUforCoding started
[HU_NBT - 63] There was an error during TAL execution, please check the log files.
[HU_NBT - 63] finalizeECUCoding started
[HU_NBT - 63] finalizeECUCoding finished
[Exception - UNKNOWN] Errors during NCD generation for CAF cafd_00000ded-003_005_107:
DataGroup AUDIO_TUNER_TRAFFIC, Function MICROPHONE_NUMBER: More than one condition parameter is active: [wert_1, wert_2]
[KOMBI - 60] prepareECUforCoding started
[KOMBI - 60] prepareECUforCoding finished
[KOMBI - 60] authenticateECUforCoding started
[KOMBI - 60] authenticateECUforCoding finished
[KOMBI - 60 - cafd_000009c8-006_000_031] Transaction type: cdDeploy; Message: TA started
[KOMBI - 60 - cafd_000009c8-006_000_031] Transaction type: cdDeploy; Message: TA finished
[KOMBI - 60] finalizeECUCoding started
[KOMBI - 60] finalizeECUCoding finished
[AMPT - 37] prepareECUforCoding started
[AMPT - 37] prepareECUforCoding finished
[AMPT - 37] authenticateECUforCoding started
[AMPT - 37] authenticateECUforCoding finished
[AMPT - 37 - cafd_00000fa2-001_005_000] Transaction type: cdDeploy; Message: TA started
[AMPT - 37 - cafd_00000fa2-001_005_000] Transaction type: cdDeploy; Message: TA finished
[AMPT - 37] finalizeECUCoding started
[AMPT - 37] finalizeECUCoding finished
[ACSM - 1] prepareECUforCoding started
[ACSM - 1] prepareECUforCoding finished
[ACSM - 1] authenticateECUforCoding started
[ACSM - 1] authenticateECUforCoding finished
[ACSM - 1 - cafd_00000911-003_001_013] Transaction type: cdDeploy; Message: TA started
[ACSM - 1 - cafd_00000911-003_001_013] Transaction type: cdDeploy; Message: TA finished
[ACSM - 1 - cafd_00000912-003_007_016] Transaction type: cdDeploy; Message: TA started
[ACSM - 1 - cafd_00000912-003_007_016] Transaction type: cdDeploy; Message: TA finished
[ACSM - 1 - cafd_00000913-003_005_001] Transaction type: cdDeploy; Message: TA started
[ACSM - 1 - cafd_00000913-003_005_001] Transaction type: cdDeploy; Message: TA finished
[ACSM - 1] finalizeECUCoding started
[ACSM - 1] finalizeECUCoding finished
[TRSVC - 6] prepareECUforCoding started
[TRSVC - 6] prepareECUforCoding finished
[TRSVC - 6] authenticateECUforCoding started
[TRSVC - 6] authenticateECUforCoding finished
[TRSVC - 6 - cafd_00000223-013_008_009] Transaction type: cdDeploy; Message: TA started
[TRSVC - 6 - cafd_00000223-013_008_009] Transaction type: cdDeploy; Message: TA finished
[TRSVC - 6] finalizeECUCoding started
[TRSVC - 6] finalizeECUCoding finished
[IHKA - 78] prepareECUforCoding started
[IHKA - 78] prepareECUforCoding finished
[IHKA - 78] authenticateECUforCoding started
[IHKA - 78] authenticateECUforCoding finished
[IHKA - 78 - cafd_00000a3f-005_001_016] Transaction type: cdDeploy; Message: TA started
[IHKA - 78 - cafd_00000a3f-005_001_016] Transaction type: cdDeploy; Message: TA finished
[IHKA - 78] finalizeECUCoding started
[IHKA - 78] finalizeECUCoding finished
[DSC - 29] prepareECUforCoding started
[DSC - 29] prepareECUforCoding finished
[DSC - 29] authenticateECUforCoding started
[DSC - 29] authenticateECUforCoding finished
[DSC - 29 - cafd_000019cc-100_011_007] Transaction type: cdDeploy; Message: TA started
[DSC - 29 - cafd_000019cc-100_011_007] Transaction type: cdDeploy; Message: TA finished
[DSC - 29] finalizeECUCoding started
[DSC - 29] finalizeECUCoding finished
[EKPM2 - 17] prepareECUforCoding started
[EKPM2 - 17] prepareECUforCoding finished
[EKPM2 - 17] authenticateECUforCoding started
[EKPM2 - 17] authenticateECUforCoding finished
[EKPM2 - 17 - cafd_00000098-000_008_100] Transaction type: cdDeploy; Message: TA started
[EKPM2 - 17 - cafd_00000098-000_008_100] Transaction type: cdDeploy; Message: TA finished
[EKPM2 - 17] finalizeECUCoding started
[EKPM2 - 17] finalizeECUCoding finished
[SM2 - 6D] prepareECUforCoding started
[SM2 - 6D] prepareECUforCoding finished
[SM2 - 6D] authenticateECUforCoding started
[SM2 - 6D] authenticateECUforCoding finished
[SM2 - 6D - cafd_000000b5-012_002_037] Transaction type: cdDeploy; Message: TA started
[SM2 - 6D - cafd_000000b5-012_002_037] Transaction type: cdDeploy; Message: TA finished
[SM2 - 6D] finalizeECUCoding started
[SM2 - 6D] finalizeECUCoding finished
[FLA3 - 5F] prepareECUforCoding started
[FLA3 - 5F] prepareECUforCoding finished
[FLA3 - 5F] authenticateECUforCoding started
[FLA3 - 5F] authenticateECUforCoding finished
[FLA3 - 5F - cafd_000000ae-005_006_005] Transaction type: cdDeploy; Message: TA started
[FLA3 - 5F - cafd_000000ae-005_006_005] Transaction type: cdDeploy; Message: TA finished
[FLA3 - 5F] finalizeECUCoding started
[FLA3 - 5F] finalizeECUCoding finished
[EGS - 18] prepareECUforCoding started
[EGS - 18] prepareECUforCoding finished
[EGS - 18] authenticateECUforCoding started
[EGS - 18] authenticateECUforCoding finished
[EGS - 18 - cafd_0000023f-016_016_027] Transaction type: cdDeploy; Message: TA started
[EGS - 18 - cafd_0000023f-016_016_027] Transaction type: cdDeploy; Message: TA finished
[EGS - 18] finalizeECUCoding started
[EGS - 18] finalizeECUCoding finished
[DME - 12] prepareECUforCoding started
[DME - 12] prepareECUforCoding finished
[DME - 12] authenticateECUforCoding started
[DME - 12] authenticateECUforCoding finished
[DME - 12 - cafd_000001a7-000_013_010] Transaction type: cdDeploy; Message: TA started
[DME - 12 - cafd_000001a7-000_013_010] Transaction type: cdDeploy; Message: TA finished
[DME - 12] finalizeECUCoding started
[DME - 12] finalizeECUCoding finished
[ZBE3 - 67] prepareECUforCoding started
[ZBE3 - 67] prepareECUforCoding finished
[ZBE3 - 67] authenticateECUforCoding started
[ZBE3 - 67] authenticateECUforCoding finished
[ZBE3 - 67 - cafd_000011b3-001_002_011] Transaction type: cdDeploy; Message: TA started
[ZBE3 - 67 - cafd_000011b3-001_002_011] Transaction type: cdDeploy; Message: TA finished
[ZBE3 - 67] finalizeECUCoding started
[ZBE3 - 67] finalizeECUCoding finished
[ASD - 3F] prepareECUforCoding started
[ASD - 3F] prepareECUforCoding finished
[ASD - 3F] authenticateECUforCoding started
[ASD - 3F] authenticateECUforCoding finished
[ASD - 3F - cafd_00000f9b-001_010_002] Transaction type: cdDeploy; Message: TA started
[ASD - 3F - cafd_00000f9b-001_010_002] Transaction type: cdDeploy; Message: TA finished
[ASD - 3F] finalizeECUCoding started
[ASD - 3F] finalizeECUCoding finished
[ICM - 1C] prepareECUforCoding started
[ICM - 1C] prepareECUforCoding finished
[ICM - 1C] authenticateECUforCoding started
[ICM - 1C] authenticateECUforCoding finished
[ICM - 1C - cafd_0000067b-002_004_089] Transaction type: cdDeploy; Message: TA started
[ICM - 1C - cafd_0000067b-002_004_089] Transaction type: cdDeploy; Message: TA finished
[ICM - 1C] finalizeECUCoding started
[ICM - 1C] finalizeECUCoding finished
[REM - 72] prepareECUforCoding started
[REM - 72] prepareECUforCoding finished
[REM - 72] authenticateECUforCoding started
[REM - 72] authenticateECUforCoding finished
[REM - 72 - cafd_000007a1-005_031_003] Transaction type: cdDeploy; Message: TA started
[REM - 72 - cafd_000007a1-005_031_003] Transaction type: cdDeploy; Message: TA finished
[REM - 72] finalizeECUCoding started
[REM - 72] finalizeECUCoding finished
[PMA2 - 2C] prepareECUforCoding started
[PMA2 - 2C] prepareECUforCoding finished
[PMA2 - 2C] authenticateECUforCoding started
[PMA2 - 2C] authenticateECUforCoding finished
[PMA2 - 2C - cafd_00000bce-005_023_005] Transaction type: cdDeploy; Message: TA started
[PMA2 - 2C - cafd_00000bce-005_023_005] Transaction type: cdDeploy; Message: TA finished
[PMA2 - 2C] finalizeECUCoding started
[PMA2 - 2C] finalizeECUCoding finished
[LMV_FR - 19] prepareECUforCoding started
[LMV_FR - 19] prepareECUforCoding finished
[LMV_FR - 19] authenticateECUforCoding started
[LMV_FR - 19] authenticateECUforCoding finished
[LMV_FR - 19 - cafd_00001543-000_046_001] Transaction type: cdDeploy; Message: TA started
[LMV_FR - 19 - cafd_00001543-000_046_001] Transaction type: cdDeploy; Message: TA finished
[LMV_FR - 19] finalizeECUCoding started
[LMV_FR - 19] finalizeECUCoding finished
[TCB - 61] prepareECUforCoding started
[TCB - 61] prepareECUforCoding finished
[TCB - 61] authenticateECUforCoding started
[TCB - 61] authenticateECUforCoding finished
[TCB - 61 - cafd_00000ddc-001_017_001] Transaction type: cdDeploy; Message: TA started
[TCB - 61 - cafd_00000ddc-001_017_001] Transaction type: cdDeploy; Message: TA finished
[TCB - 61] finalizeECUCoding started
[TCB - 61] finalizeECUCoding finished
[FZD - 56] prepareECUforCoding started
[FZD - 56] prepareECUforCoding finished
[FZD - 56] authenticateECUforCoding started
[FZD - 56] authenticateECUforCoding finished
[FZD - 56 - cafd_00000a07-002_015_000] Transaction type: cdDeploy; Message: TA started
[FZD - 56 - cafd_00000a07-002_015_000] Transaction type: cdDeploy; Message: TA finished
[FZD - 56 - cafd_00000a08-003_010_001] Transaction type: cdDeploy; Message: TA started
[FZD - 56 - cafd_00000a08-003_010_001] Transaction type: cdDeploy; Message: TA finished
[FZD - 56] finalizeECUCoding started
[FZD - 56] finalizeECUCoding finished
[EPS - 30] prepareECUforCoding started
[EPS - 30] prepareECUforCoding finished
[EPS - 30] authenticateECUforCoding started
[EPS - 30] authenticateECUforCoding finished
[EPS - 30 - cafd_00000694-003_003_045] Transaction type: cdDeploy; Message: TA started
[EPS - 30 - cafd_00000694-003_003_045] Transaction type: cdDeploy; Message: TA finished
[EPS - 30] finalizeECUCoding started
[EPS - 30] finalizeECUCoding finished
[TBX - 35] prepareECUforCoding started
[TBX - 35] prepareECUforCoding finished
[TBX - 35] authenticateECUforCoding started
[TBX - 35] authenticateECUforCoding finished
[TBX - 35 - cafd_000011c5-001_010_008] Transaction type: cdDeploy; Message: TA started
[TBX - 35 - cafd_000011c5-001_010_008] Transaction type: cdDeploy; Message: TA finished
[TBX - 35] finalizeECUCoding started
[TBX - 35] finalizeECUCoding finished
[VDC1 - 76] prepareECUforCoding started
[VDC1 - 76] prepareECUforCoding finished
[VDC1 - 76] authenticateECUforCoding started
[VDC1 - 76] authenticateECUforCoding finished
[VDC1 - 76 - cafd_000006c6-003_000_003] Transaction type: cdDeploy; Message: TA started
[VDC1 - 76 - cafd_000006c6-003_000_003] Transaction type: cdDeploy; Message: TA finished
[VDC1 - 76] finalizeECUCoding started
[VDC1 - 76] finalizeECUCoding finished
[] finalizeVehicleCoding started
[] finalizeVehicleCoding finished
[] finalizeTALExecution started
[] finalizeTALExecution finished
TAL execution finished
TAL-Execution finished with status: "FinishedWithErrorInTransaction". [C207]
TAL execution finished. Duration: "1min 30s". [C206]
Abarbeitung beendet
