BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > B58 Log Review Thread
Studio RSR
      02-27-2020, 11:30 AM   #485
janea1207
Drives: BMW 340i
Originally Posted by kern417 View Post
Originally Posted by janea1207 View Post
486whp???? (~550hp) it is not real for stock turbo!!!
what mods? fuel?
i'll never understand how someone can estimate your bhp and then claim your dyno numbers aren't real.
You better message pure turbo. They've done over 500whp on stock turbo. Mind blown.
on E50 or E85 +meth may be yes, i was thinking on pump gas. How many hp can get on pump gas (93octane/98Ron) & stock turbo???
      02-27-2020, 04:39 PM   #486
SC_B5X
Built Motor F30 340i
SC_B5X's Avatar
403
Drives: Built Motor 2016 BMW 340i
Honestly probably whatever MHD Stage 2 OTS/BM3 Stage 2 OTS provides. Really can't do much on 93 only.
Owner of MRM Performance
Sales@MRMPerformance.com
Built Motor BMW 340i
      02-28-2020, 06:14 AM   #487
RMMAGA
Drives: 120i
@Sµpreme that log looks good, right over target, interesting difference on the road, at most 0.5 PSI over, that is normal
Nice boost profile rising up top, until turbo runs out. Must to be close to the best you can do on stock. WGDC is smoother and does not peak up as as it did on the last one as well. I would be pretty happy with that.
Supr3me551.00
      03-01-2020, 10:31 PM   #488
CntryClub007
CntryClub007's Avatar
490
Drives: 2016 340i | 2015 X5-50i
How we lookin? lol on picture from wife...
https://datazap.me/u/cntryclub007/jb...g=0&data=4
      03-02-2020, 06:41 AM   #489
kern417
Cheapskate
4447
Drives: 2018 440i |2016 340i | 2010 X5
https://datazap.me/u/cntryclub007/jb...2?log=0&data=4
wife used to run logs with me in my old car. now when i leave she panics because every time she assumes i'm doing 140+ on the highway
that log looks crazy. 25+ psi? I'd recommend less boost and more timing.
Youtube/Instagram/TikTok: @kern417
      03-02-2020, 04:32 PM   #490
CntryClub007
490
What will the timing do? Advance ignition? I saw sc_b58x had Meth detonation in their intake manifold, what actually caused that?
      03-02-2020, 04:40 PM   #491
Supr3me
Supr3me's Avatar
Drives: Your mom crazy
Since I had my misfire event on E70 a couple of weeks ago, I've seen this "Combustion period outside of tolerance" code a couple of times in the code history. Any insight into what this is and whether I should be concerned about it?
2020 X3M
MG Flasher; Wedge Performance E50 tune
MSS Urban; Rohana RFX11
      03-03-2020, 07:25 AM   #492
kern417
Cheapskate
4447
Timing will advance ignition, but you need more octane to go past a certain threshold. We seem to have no issues pulling 14°-16° on 93 octane, so I'd start there and then add boost until you run out of fuel. Going the opposite way (add more boost and less timing) tends to make less power.
The intake manifold issue was a fluke. Spraying meth + high psi caused the meth to ignite in the intake manifold. Kind of like how diesels ignite under compression. I wouldn't worry about it.
This is a shot int he dark, but you likely it hit the limit of our variable timing. You can only pull so much timing until you hit the physical limits of our cams. Did you log that E70 run? And is it still coming up now that you corrected the mix?
      03-03-2020, 08:12 AM   #493
alyabiev
Drives: BMW M3 Competition Touring
100% methanol autoignition point is at 700°F+. There is NO WAY it would ignite in intake manifold.
Kirill @ OdinTuned
      03-03-2020, 08:15 AM   #494
baldeagleman
Drives: 2018 M4 6MT
Just got the NGK plugs in and gapped to 0.022" like everyone recommends. First log since
https://datazap.me/u/dparadis21/mhd-...data=5-6-19-44
Didn't have a great spot to do it so it's not perfect. Losing a bit of timing in the beginning, but it ends up evening out in the end. What do you guys think?
      03-03-2020, 08:26 AM   #495
kern417
Cheapskate
4447
Well, I guess it happened by magic then.
Looks ok. A lot of us have lower timing on cyl 1, but it should catch up by redline. It may need some time to adapt.
      03-03-2020, 08:53 AM   #496
alyabiev
35+ psi is no joke for a plastic mani. Some welded manifolds can crack open even at lower pressure.
Kirill @ OdinTuned
      03-03-2020, 09:19 AM   #497
ivanj308
Drives: M240i DownPipe MHD
Posting just in case anyone has an interest. Dinan Elite v1 using MHD Stock Tune
https://datazap.me/u/ivan308/dinan-e...og=0&data=5-25
Just playing to see what would be logged. Dinan Elite v1 93 Octane
Downpipe being installed and Dinan removed as we speak. I will then load MHD Stage 2 93 octane and post new logs
Any comments
      03-03-2020, 12:18 PM   #498
Supr3me
Supr3me's Avatar
I did log and post it when it happened on this thread, flip back a page or so.
I haven't run anything stronger than E70 since then but it looks like it's come up twice since then.
Edit: I don't know why but I can't find where I shared that now.
Here's the log.
https://datazap.me/u/tnilson/e70-mis...og=0&data=4-18
2020 X3M
      03-03-2020, 01:13 PM   #499
baldeagleman
Drives: 2018 M4 6MT
https://datazap.me/u/dparadis21/mhd-...og=0&data=5-19
93 Oct MHD Stg 2
      03-03-2020, 07:10 PM   #500
Nugget
Nugget's Avatar
650
Drives: G81 M3 Touring, GR Supra GTS
2011 BMW 135i  [10.00]
Pure stage 2, Catted DP, MST intake, XDI hpfp.
https://datazap.me/u/nugs/custom-pur...25&zoom=18-109
Australian 98ron is garbage apparently.
We are gradually turning it down to avoid timing corrections.
Looking forward to starting the ethanol map.
      03-03-2020, 08:19 PM   #501
Supr3me
Supr3me's Avatar
Corn juice rules
2020 X3M
      03-03-2020, 09:28 PM   #502
Nugget
Nugget's Avatar
650
It's Sorghum juice over here
      03-04-2020, 06:59 AM   #503
M140_BCS
M140_BCS's Avatar
238
Drives: 440i Gran Coupe
Fuel rail pressure drops between 2-3k rpm and 4.5-5.5k rpm
Minor timing corrections, cylinder 6 pulling the most.
2017 440i F36 - Drexler LSD - B58TU HPFP - MHD Stage 2 - xHP - 200 Cell DP - MPE
kern4174446.50
      03-04-2020, 07:40 AM   #504
kern417
Cheapskate
4447
it's easier for meth to ignite and cause the failure. Yeah it's a lot of pressure, but I've seen that (on other platforms) without issue on bigger turbo setups. Or he had a slightly weaker unit. But it shouldn't break under that kind of pressure.
Any comments
Looks pretty good. MHD will target higher boost and run safer AFRs. Should be a nice upgrade.
Here's the log.
yeah that's a strange one. everything looks perfect except rail pressure. it is a lot of timing really early though. I wonder if there's a software limit on how much advance can be added throughout the rev range? it's clearly something with timing. if it's just a soft code then maybe something you can ignore, or ask wedge if they have any ignition threshold parameters that can be raised to keep it from coming back.
Looks pretty good. I'm assuming from the log title you swapped to NGK plugs? Did you close the gap at all?
def add some ethanol to get that timing up. that's less than our 91oct maps
      03-04-2020, 07:43 AM   #505
kern417
Cheapskate
4447
Good catch. I didn't even look at fuel pressure since it's an OTS map. Doesn't seem typical at all.
      03-04-2020, 09:32 AM   #506
baldeagleman
Drives: 2018 M4 6MT
Looks pretty good. I'm assuming from the log title you swapped to NGK plugs? Did you close the gap at all?(
Gapped to 0.022". That was my first pull with them installed on that tune. It was also raining outside, so not really ideal conditions. Once they have a bit more time I'm hoping I can get those timing corrections down a bit.
