10-26-2014, 02:08 PM | #45 |
Rep 418
My suggestions are:
RFT's are prone to something called 'sawtooth' (also known by other names). The tyre appears fine, but jacked up, slow rotation shows a flat spot across the join of the tyre. Go to another tyre specialist to get wheels balanced. In the UK we have specialists who can also do 'extra fine' balancing for particularly accurate setups (most benefit on high speed roads) Don't rule out buckled wheels either..... |
07-03-2017, 10:19 AM | #46 | |
Rep 83
Hi King, the issue you used to have sounds very similar to mine and I made a new post here about my specific case. So they replaced your driveshaft a few years ago... Is the car still smooth? I'm going to mention it to my dealer before I get the new tires (Non-RFT) put on... Mine has brand new Summer RFT's on it now, which is why I doubt it's related to wheel balance or tires, but I need All Season tires for the climate in my area anyway. If you have any documentation or related TSB's or anything I could use them as a suggestion to my dealer and that would be very much appreciated! (Here is my Post: http://f30.bimmerpost.com/forums/sho...1#post21892353) Thanks, Dan Last edited by Altima; 07-03-2017 at 11:48 AM.. |
11-16-2017, 10:14 AM | #48 |
Car Enthusiast
20
Rep 80
Dang.
My F20 120d has developed this issue. I was lucky in terms of mileage, it appeared about 2 months ago when I passed 62,000 miles. Dealer has taken me through the same tyre balancing blah-blah, and even replaced the rear brakes... I have suggested right from the onset that this is caused by the propshaft. I am used to doing all maintainence myself, over hundreds of thousands of miles in my own cars, but this one is a company car, so I am not allowed to do anything but drive it. My dealer said "We have never heard of a defect in the propshaft or it's assembly". BMW has been building RWD cars for over 100 years now, and never had a defective propshaft???? |
11-16-2017, 10:32 AM | #49 |
Rep 1,048
Propeller shafts themselves don't become bad unless there is an accident, but U-joints can fail. My experience has been that those problems usually show up during acceleration and slow-downs, not at steady speed.
Rear motor mount??? Flex disk? Last edited by rak299; 11-16-2017 at 10:40 AM.. |
11-17-2017, 12:55 AM | #50 |
Car Enthusiast
20
Rep 80
When I say propshaft, I am referring to the entire assembly.
Most likely is a failing carrier bearing. It's hung in a rubber bush that starts by going soft and allowing too much play. Sure, it could also be the vibration damper/Guibo/flex disc connecting the prop to the diff, but I reckon the vibrations would be larger in amplitude, and more prone to following throttle inputs. |
11-19-2017, 11:23 AM | #51 |
Rep 529
Could the vibration be mistaken for road wallow/bounciness? The rear shocks have little to no rebound especially if u are non dhp and they are getting up there in mileage.
This is my assumption for a similar issue I am having with my f30, sometimes feels like vibration but I have chased down and inspected everything and have landed on it being super soft rear shocks that can't control spring oscillation due to lack of proper rebound control.
2013 F30 335i xDrive M-Sport 6MT (FBO/BM3 custom tune by HCP, 91 oct, 550i clutch, xDelete)
11-22-2017, 08:07 AM | #52 | |
Car Enthusiast
20
Rep 80
The biggest problem I have encountered is dealer "technicians" who cannot discern the causes and give up, by claiming they cannot reproduce the symptoms. |
01-15-2018, 12:35 PM | #53 |
Rep 130
Add me to the list of people who are getting a new driveshaft. My dealer has opened a PUMA case with BMW. Symptoms were vibration at highway speeds which got worse with time (15-20 minutes).
I had aligment done, 4 times rebalanced wheels, 3x different rims and non ruflat tires. 2016 440i GC xDrive, 22 500 miles EDIT: It took two more months and engineers from BMW Germany coming over to my dealer to take a look at my car and they finally gave the go ahead on the driveshaft replacement. Last edited by VVlasy; 03-02-2018 at 02:24 AM.. |
04-14-2018, 11:18 AM | #54 |
Rep 708
2015 335xi F30 8AT and starting st 80mph I get vibration. As you increase speed it gets worse
Dealer charged me 360 to straighten two front rims. I have had the car 3 mos and it only had 1000 miles from the 39k I bought it on. Taking it back to ask them to check out again. Was going to rotate tires and road test but raining today. Disappointing as my prior E90s were smooth to 133mph. Never an issue. Traded out of a new Macan as I missed the BMW too much. |
04-24-2018, 06:25 PM | #55 | |
Rep 552
Did they give a reason for the part failure? Last edited by kingmonkey8; 04-25-2018 at 04:10 AM.. |
06-24-2018, 05:16 AM | #56 |
Rep 552
Just wanted to get an update. Anyone else still having high speed vibration issues or managed to resolve this issue?
My car did have this issue back in 2014 when the car was on 6k. The dealer seemed to have fixed it at the time (balanced wheels, swapped diff, prop shaft). But unfortunately the same issue is now back and the car is out of warranty. The fix probably lasted less than 20k and is now back. Took it to two BMW independant garages and they checked the car over, couldn't see anything obvious. 428i MT |
06-24-2018, 10:01 AM | #57 | |
Rep 130
Shop foreman said manufacturing defect. I doubt it but what else can I do. I requested some form of a repair invoice, but I was denied, saying that for warranty repairs (I am in EU), they do not provide it, but it will be in the electronic BMW database. |
06-24-2018, 10:03 AM | #58 | |
Rep 130
06-24-2018, 05:04 PM | #59 | |
Rep 552
I noticed that one of the rear wheels old and when replaced with new wheels looked like it wasn't running true, tiny bit of run out. replaced the hub but still no change. Was your vibration dependant on speed? i.e 70 and above? |
06-25-2018, 08:09 AM | #60 | |
Rep 552
I dropped in a used Prop shaft with a later manufacture date (2015). If anything the problem seems slightly worse than before. But as this has had an effect. It does seems to confirm the issue is related to the prop shaft. |
06-25-2018, 08:55 AM | #61 |
Rep 130
Yes, mine started at about 75Mph and was completely gone at 90Mph.
I have my personal view on this matter, but I have nothing to prove it. I have a feeling that my transmission jerks more than normal. And this contributed to the death of the propshaft (probably the joints, but they replace as a whole piece). Heavy stress on the joints when transmissions jerks would make sense. But I am not saying this is your case. Just my view on this vibration issue... |
06-25-2018, 10:29 AM | #62 | |
Rep 552
I don't find the MT necessarily jerky. Especially at crusing speed on the motorway. When I took off the old shaft I was expecting damage to the center bearing bushing rubber or the guibo flexdisc. However the these parts still looked good. Even the CV joints were still good with no play. Unless the shaft itself was out of balance. But surely these are checked to tolerance when they are manufactured. |
07-02-2018, 08:10 AM | #63 |
Rep 2,957
Any update on this? I find it very disturbing this has been going on for 6 years with no definitive answer. My manual 2015 335 vibrates from around 60-70mph. I've swapped tires, rebalanced, aligned, etc with no resolution.
07-02-2018, 08:43 AM | #64 | |
Rep 552
Where does the source of your vibration seem to come from? |
07-02-2018, 08:49 AM | #65 |
Rep 1,909
Mine vibrates from 75-80 tyres all good & balanced, fitted new front pads Sunday yet to drive car so don't know if its the pads.
Happy Motoring
Evdok |
07-02-2018, 09:39 AM | #66 |
Rep 331
Being that these vibrations are felt throughout the cabin, all of the driveline should be suspect. Driveshaft is the most obvious, but a bad flex disc or “guibo” as its referred to by BMW could also be the culprit.
Can these vibrations be felt under acceleration or at a coast with no throttle? With the car in neutral? |
