BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N47 and N57 Turbodiesel Engine / Drivetrain / Exhaust Modifications > N47 F31 2013 boost leak?
proTUNING Freaks
      04-29-2024, 10:45 AM   #1
Pank
Pank's Avatar
Denmark
Drives: BMW F31 320d
Hello guys
Did any of you experience a boost leak
My car is stage 1 mapped and XHP but it doesn’t want to push more than 200hp and 400nm. I was hoping it would be a boost leak rather than a turbo. What do you think? Any weak points in the boost system or just an old turbo. Car has done 269.000 km
It should make 1,9 bar boost but it won’t do more than 1,6 bar. It makes 1,9 between 1000 and 2000rpm but above that is not more than 1,6 - 1,7
      04-30-2024, 07:39 AM   #2
martinf31
martinf31's Avatar
Drives: 2013 F31 320d
Hey,
I have the same car, it was tuned few months ago. Currently it’s pushing 220Hp and 430Nm. I’m not an expert in these tunes but I’m pretty sure that is more boost than it should be. That 1,6 bar should be the optimal. If you really insist going 1,9 then check your whole turbo system, mainly the turbo pipe. It might have a leak.
Take care.
Pank0.00
      05-03-2024, 11:01 AM   #3
speedbirdblack
speedbirdblack's Avatar
Sri Lanka
26
Drives: f30 M-Sport
Originally Posted by Pank View Post
Hello guys
If you think it's boost leak, then check plumbing frist. Also HP figures varies dyno to dyno.
How do you feel about the XHP comparison to the factory map?
speedbirdblack
      05-03-2024, 11:50 AM   #4
Pank
Pank's Avatar
Denmark
HP was on the same dyno. 210hp 2 months ago and 200hp 1 Month ago
Xhp is really great. I Got a stage 2 xHP and in comfort little to no difference. But in sport it’s really fast and nearly instant shifts. I would say it feels close to DSG
      05-03-2024, 12:20 PM   #5
TurboWeasel
Drives: BMW 330D
1.9 bar sounds high. It maybe cannot sustain that at the higher revs. Same issue with gasoline turbo engines. They can't hold the same pressure to the redline unless the turbo is massive.
Check for oil sweating around the boost pipe connections and replace the O rings if there is oil. Replace them anyway for maintenance as they are cheap.
Did you set torque limits in XHP? In my 30d, I set all gears to 600nm, which removed some flat spots of the factory 8HP tune. Some of the gears are torque limited by BMW, 3rd and 6th I think.
XHP Stage 3 is too jerky in traffic. Stage 2 is the sweet spot.
      05-04-2024, 04:01 AM   #6
Pank
Pank's Avatar
Denmark
I checked alle pipes and no Oil leaking, exept the one from turbo. The first pipe connection there is a little but it’s not much
