BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Front end suspension help
      05-20-2024, 08:57 PM   #1
Hradillukas
Drives: 2014 328i
Hi guys, need some advice whats going on. I recently replaced control arms, sway bar links, tie rod ends and struts. Had it aligned. Drove nicely again like new. But for last couple weeks steering feels so soft, steering wheel is slightly to the left and sometimes when I hit bumps or potholes I can hear loud knock from the left.. I was thinking go the the shop where I did the alignment to have them check it out but asking for ideas here first. I was thinking if strut mount coz I didnt put new ones. That could be the knock noise over bumps but dont thnks so about soft feel steering. Thank you in advance for ideas
Edit. Forgot to mention its 2014 f30 328i 140k miles on it right now
      05-20-2024, 10:41 PM   #2
im_an_alien
im_an_alien's Avatar
1252
Drives: 2016 340i
Generally strut mounts should be replaced with struts, they take all the weight of your front end and all the abuse that goes with that.
      05-21-2024, 12:38 PM   #3
Hradillukas
Drives: 2014 328i
Yea sh*t 😡🤦*♂️ I am hitting myself to the head because of that now.. dont really want to do that again.. 😂 but you think it could be the culprit even for the soft feel in the steering? I did some research and maybe the steering rack thrust could be the reason. With 140k miles 🤷*♂️
      05-21-2024, 02:58 PM   #4
keithyo88
Drives: 340i msport rwd
I got you beat: put on the brakes backwards on an old chevy, and lucky to be here. be Kind to yourself
      05-22-2024, 06:22 PM   #5
bconleyf30
Drives: 2014 bmw 328i xdrive
https://f30.bimmerpost.com/forums/sh....php?t=1603926
https://www.ebay.com/itm/40449233160...mis&media=COPY
If you didn’t replace this thrust piece already then this should take care of your knocking problem. Easy fix. This piece puts pressure on the steering rack and will get worn down hence the light steering. Also after all new parts and an alignment and your car is still pulling…. check your wheel bearings for play, make sure all tire treads are equal or very close(I changed one tire on my f30 and I have a pull to the right now on that side), also I didn’t see inner tie rods on your list I think so that could be something to address as well 🫡
      05-22-2024, 06:24 PM   #6
bconleyf30
Oh and check to see if your sway bar links are tight! They will sound like a terrible crash when not tightened fully!
      05-23-2024, 07:36 AM   #7
Hradillukas
Drives: 2014 328i
Will check on sway bar links. Also gonna start with thrust piece. Easier than removing and changing struts mounts. Hopefully thats gonna be it.. thank you you also gave me and idea why it is pulling. I did change all the parts and did aligement but after maybe one month I got new tires at the front. Left tire was very bad on the outside. So I think thats why.. so will do aligment again and we will see. Thank you again
