BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Mechanical Maintenance and TSBs: Break-in / Oil & Fluids / Servicing / TSBs and Service Bulletin > 120k miles, what should be replaced?
      03-01-2023, 10:36 AM   #1
ViewsOfTheVI
Drives: BMW 435i, Mitsubishi Evo 6
Smile 120k miles, what should be replaced?
Hey gang, new-ish owner of a 435i xDrive, im at 120k and that’s quite high so im wondering what should be or should have been replaced by now. I see that im leaking a bit of oil from some tube that goes through my valve cover, not sure would someone be able to help me with the name of it? I’m going to replace the water pump/thermostat and am ordering off FCP from Canada, might as well get a bunch of other stuff as well. Would appreciate any help, thanks team
      03-01-2023, 12:44 PM   #2
F32Fleet
F32Fleet's Avatar
Drives: 2015 435i
I would star looking at the coolant hoses which attach to the thermostat/water pump. Specifically the hose leading from the front of the engine to the thermostat. This hose it attached to the front of the engine with a plastic flange. Just replace with a dealer part. You can buy a metal flange and break the flange on a new hose but that'll double your expense for a part which will last 100k miles.
Coolant expansion tank. Inspect it and thin coolant hose which runs from it across the front of the engine bay into the radiator
ATF fluid (pan drop) if not already done.
Front xfr case fluid,
Rear diff.
"Drive more, worry less. "
435i, MPPK, MPE, M-Sport Line
      03-02-2023, 07:52 AM   #3
ViewsOfTheVI
Thank you for the help!
      03-02-2023, 08:16 AM   #4
lens
lens's Avatar
2191
Drives: 2018 340i xDrive
If you've done your coolant/brake fluid flushes regularly, I'd just replace the hoses and keep the thermostat and waterpump on the side.
My 335i had 286,000km on factory water pump and it's still going without an issue, I've replaced my coolant hoses twice, and thermostat once.
      04-07-2023, 10:40 PM   #5
BRK
Drives: BMW 428i F36
Basic maintenance.
Spark plugs if not already done. You will need a very thin wall plug socket if dyi and the rear plug is a challenge - so knuckle joint sockets and a few extensions in 3/8 or even 1/4 drive tools needed. (Plus patience - generally not a thing that is off the shelf...)
Inspect drive belt for cracks and replace if they are apparent.
I also did the diff oil on my 428i at 105,00 kms because its not hard for dyi and the oil is cheap. The "lifetime" fluid debate has been done many times - its a personal choice imo.
      04-08-2023, 10:53 AM   #6
ooshnoo
ooshnoo's Avatar
Drives: 2014 428i and 2018 X5
2018 BMW X5  [0.00]
2014 BMW 428i  [10.00]
New spark plugs and coils
New drive belt and tensioner
New transmission fluid and pan/filter
New differential fluid
New transfer case fluid (if Xdrive)
Check valve cover and oil filter housing gaskets for leaks
Oil change with engine flush
5000 mile oil changes thereafter
___________________
2014 F32 428i M-Sport
2018 F15 M-Sport
cfm56d7b6358.00
      05-05-2023, 04:32 PM   #7
cfm56d7b
Adding to the nice list:
- Charge pipe; replace it if you plan to keep the car. Suggest Evolution Racewerks as a top candidate (not a commercial endorsement; just experience)
- Suspension; replace all items with rubber components
      05-10-2024, 09:04 PM   #8
ViewsOfTheVI
You guys are amazing!
      05-16-2024, 06:40 PM   #9
ADHD
ADHD's Avatar
Drives: F30 328i
21 M540i  [0.00]
07 e90 335  [0.00]
any suggestions on the belt and tensioner? Is the INA product same as OEM. ive read a few different opinions. Seen a Gates kit as well for 80$ on amazon.
      05-17-2024, 03:50 PM   #10
scubajim
scubajim's Avatar
50
Drives: 16 BMW 435 F33 Stg 2
I used a few INA products on my E39 sometime listed as OE. No issues.
      05-17-2024, 04:43 PM   #11
thatgarrett
thatgarrett's Avatar
Drives: 2012 335i Sport
2012 BMW 335i  [8.60]
I used the INA kit (with a continental belt) that FCP Euro sells last year and it’s been great, looks just like the one I took off, seems high quality
      05-24-2024, 04:19 PM   #12
ADHD
ADHD's Avatar
Drives: F30 328i
21 M540i  [0.00]
07 e90 335  [0.00]
Good to know.. Thank you.
