09-22-2016, 07:12 AM | #1 |
Rep 2,152
M5 M6 6 Pot brakes
Has anyone fitted the M5 M6 6 port front brakes?
i want to upgrade but the standard m sport 4 pots are not really any different to what i have on a 435d. so looking at the next potential upgrade and what is involved cheers lee
Current: BMW M4 F83 - Mods : Pedal Covers, LCI Stereo facia Retrofit and Carbon Rear corner covers
Old: F32 435d M Sport - Mods : HR Sport Springs, 20" Veemann V-FS23 in Gun Metal, M Performance Body Kit, Pedal Covers, Eurspec CF Mirror Caps, More-BHP remap 364 BHP 741 NM, M4 Under Chassis Brace, 15mm Rear ARB, 8.8" Screen Retrofit and LCI Stereo facia Retrofit |
09-22-2016, 09:40 AM | #3 |
Rep 2,152
well i cant seem to find prices for either kit but i suspect it wont be cheap lol
i believe this is the Brembo 6pot slotted disc part number - 1M2.9041A i believe this is the AP 6 pot grooved disc part number - CP8522Z1003R2.GA i have asked the UK suppliers for prices and will have to wait but i suspect sourcing and fitting the m5 m6 caliper will still be cheaper. especially when looking at the design of the m5 m6 caliper as the bolts looks like they need carriers so should be a case of getting 2 custom carriers made up to fit.
09-22-2016, 11:49 AM | #4 |
Rep 5,140
Custom brackets for F10 in the link below, I guess it will be similar on F30/F32.
f10.5post.com |
09-22-2016, 07:04 PM | #5 |
Rep 2,152
Cheers gave it a good read. So looks like I need customer carriers making and then m6 caliper. Disc and pads. Dust shield and hose.
Hmm not sure what is best to do |
09-23-2016, 02:23 AM | #6 |
Rep 2,152
the AP 2 kits are as follows
CP8522Z1003R2.CG12 £2365.00 + VAT CP8522Z1003R2.GA £2400.00 + VAT
09-23-2016, 10:29 AM | #7 |
Rep 10,256
Trying to retrofit brakes not intended to be used on your vehicle is ... well ... an idea which carries risks no matter how small or large. Get the right brakes designed by a team of people specifically made for your car.
12-19-2016, 04:26 AM | #10 |
Rep 4,516
Smee
BMW must have lug mount to radial adapters for F8x CCB retrofit for M2/3/4, apart from the colour the calipers are identical to blue M5/M6 6 pots. No idea how you'd source part #'s for adapters and the bolts only though.....Maybe talk to Evolve as they retrofitted CCB on their M2 so may have parts listed on a sales invoice from BMW ??? BP
Current '22 X3M LCI.. |
12-21-2016, 12:48 AM | #11 |
Rep 1,291
You can check out Bavarian they have a 6 pot kit available, call or check out their facebook. https://www.facebook.com/BM.Performa...69695369755053
12-21-2016, 03:18 AM | #12 |
Rep 2,152
ok soooo BMW do not sell the radial adapters separately but actually the costs of the gold ceramic calipers isnt that much more than buying a recon set of m5 calipers and making carriers
im guessing a caliper is a caliper and i can use normal pads and steel discs with carbon ceramic caliper?
04-29-2017, 12:58 AM | #13 | |
Rep 1,015
If F30/F32 brakes and F80/F82 brakes are not compatible, you want to seriously consider M5 or M6 used brakes because of cost? ROFLMAO Hooe to never be on same road as you. Do it right or leave it alone. |
04-30-2017, 11:13 AM | #14 | |
Rep 4,516
Yes CCB caliper will work fine with steel discs and pads
04-30-2017, 11:26 AM | #15 |
Rep 2,152
Yea so the problem I had was they don't sell the bracket separate which is funny in its self when I see the kits on ebay for £4000 no brackets which means they are useless to anything other than a m5 m6
The calipers new are about 700 each. But I can't find discs to fit. I know when you got the 380mm m4 calipers to f2x f3x you lose 10mm so they become 370 so effectively the ccb would become 400mm down to 390mm. But i would still need to source pads. Discs and correct offset bells. Headache I gave up and fitted 20s in stead lol |
Logicoeur991.00 |
