12-13-2018, 04:13 PM | #1 |
Rep 25
Need some suggestions and advice
Well the wife gave me my Christmas present early - $ 1,000.00 to spend on modding my 2015 F33 M Sport.
I was thinking of getting: Cold air intake - Specifically the Dinan D760-0038 and Charge Pipe - Specifically the Evolution Racewerks N55 Charge pipe Together that should be just a little over my Christmas gift but I can add the difference (<$100.00) Would this be a good starting point? I'm looking at a tune, a catted downpipe and maybe a new exhaust system in March (my birthday month) Any suggestions and / guidance would be greatly appreciated.
2015 435i F33 M Sport Estoril Blue Metallic
CSF FMIC | ER CP & TIC pipe | Wagner HiFlow Cat Pipe | MPE | Momentum GT CAI | Epic Motorsports Tune | |
12-13-2018, 05:25 PM | #2 |
Rep 14,107
Drives: G82 M4C X-Drive
CAI and a Charge Pipe is too soon. A tune will be the most bang for the buck. So in a rough order, I suggest this:
1) Tune - more power for less money. 2) Tires - non RFT high performance summer tires-the BEST way to improve handling. 3) Suspension - Looks and handling, a good combination! 4) Brakes - If you running adorable little non-M Performance brakes you need to upgrade if you mean business and not want to die. Brakes mean business. Cute OEM "calipers" is like playing pretend at recess. Now that you have power, the means to put it down, and brakes and suspension that won't send you into a wall, you can start looking at all the high $ to small gains ratio items like a CAI, Charge Pipe and exhaust.
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3 IG: Raging_G82 |
N26Ghost496.50 |
12-13-2018, 06:24 PM | #3 |
Rep 4,315
i agree that a stage one flash such as BM3 would be the best thing to get 1st. you can adjust/update the tune as you add additional modifications. EDIT as stated hence, a charge pipe as well. both will be your $1000 initial budget.
if you are sticking to the route you're planning for engine mods on the upper half of the engine this is what i'd get... 1) while ER is generally regarded as best for CP i'd rather spend half the cost on one by cts turbo $190... http://www.ctsturbo.com/cart/product...-5043-116.html 2) for an aftermarket intercooler cts turbo $360... http://www.ctsturbo.com/cart/product...IT-4939-7.html 3)GFB DV+ diverter valve $125 4)FTP or MST turbo inlet pipe $180 an intake is the last engine mod i'd get since it provides the least (almost no) performance gain and most get them for a louder "pfssshhh" sound. however if you must have the dinan brand and carbon fiber that's your choice. personally, i'd rather pay $280 for the offering by cts turbo... http://www.ctsturbo.com/cart/product...-4922-699.html Last edited by alohasurftoad; 12-14-2018 at 01:34 PM.. |
12-13-2018, 06:28 PM | #4 |
Rep 2,653
Keep stock intake, it does a fantastic job. Spend that money elsewhere. Definitely CP, BM3 Stage 1 and IC.
12-13-2018, 07:22 PM | #5 |
#gotboost
517
Rep 861
Id do BM3, chargepipe and pony up the difference for a downpipe. no shame in getting a used one off of the marketplace here.
In march, you could get an intercooler and diverter valve and flash to the next stage
2018 F87 M2 (09/2020 - )
Dinan Cold Air Intake |Dinan Axle Back | VRSF 6.5" Intercooler | VRSF Catless Downpipe | VRSF Charge Pipes | BM3 | MST Inlet v2 | Turbosmart VR11 2013 F30 328i (12/2015 - 09/2020) SOLD! |
jh_f301306.00 |
12-13-2018, 07:51 PM | #6 |
Rep 3,679
I think a CAI and charge pipe would be the last two things I'd do Those are both small gain "extras" so to speak, so I would save them for last.
The above suggestions are all good ones. I think #1 should be a tune, BM3 is great. That'll leave you with around $400 which isn't enough for much, but could get you a set of springs with that, assuming you install them yourself. You could also get a downpipe with that $400, but that's usually paired with an FMIC, which would eclipse $1000. If you're willing to bolster your budget with some pocket change, a tune downpipe and intercooler is a possibility. Or, you could go a totally different route and a nice set of wheels.
12-13-2018, 08:01 PM | #7 |
Rep 10,473
Why anyone would not start with a metal CP before anything else is just amazingly naive imo.
Even stock, OEM CPs blow. Add in a tune and one is asking for trouble. Not to mention if those exploding plastic parts get sucked into the engine. Then see what your bill runs. OEM CP stock are ticking time bombs. Add in a tune and you are simply asking for disaster. |
jh_f301306.00 |
12-14-2018, 09:55 AM | #8 | |
Rep 1,827
Also, imo, CAI is completely unnecessary. Stock intake is not known to be a point of restriction. If anything, just drop in a a performance dry (non-oiled) filter. Do the CP instead of CAI.
2013 F30 335i RWD ZF Melbourne Red
~Remus Sport Axleback~VRSF Chargepipe~VRSF Catless Downpipe~GPlus FMIC~HR Sport Springs~Active Autowerke OBD Flash Tune Stage 2~ |
IK6SPEED4486.00 |
12-14-2018, 10:51 AM | #9 | |
Rep 14,107
12-14-2018, 11:09 AM | #10 |
Rep 1,953
Drives: 2013 328i xDrive
I thought I saw someone selling a used BM3 license on here for $350. Add in a CP and depending on brand and how much you have left over, you can still get something else. CAI does nothing for performance. You will notice a tune the most, and you need that CP to support the tune. You could do an FMIC with it after since those 2 are typically installed together, and pay the difference.
12-14-2018, 11:18 AM | #11 | |
Rep 3,679
IK6SPEED4486.00 alohasurftoad3072.00 |
12-14-2018, 11:21 AM | #12 | |
Rep 10,473
12-14-2018, 04:36 PM | #13 | |
Rep 25
I also have the M Sport suspension and the blue M Sport brakes. I should have mentioned in my OP that I still have 12,000 miles and 6 months left on the factory warranty and was wondering if I should do nothing until the warranty runs out. That's why I was looking at the Dinan CAI as it wouldn't affect my warranty. Not sure what to do now.
CSF FMIC | ER CP & TIC pipe | Wagner HiFlow Cat Pipe | MPE | Momentum GT CAI | Epic Motorsports Tune | Last edited by GatorRob; 12-14-2018 at 04:47 PM.. Reason: additional information |
12-14-2018, 07:58 PM | #14 | |
Rep 4,315
https://www.dinancars.com/warranty/ regardless, putting $600ish towards any intake would be a pity when there are other things which would provide more "bang for the buck". however if that's what you want you should get it. there someone selling one in the member classifieds now. it may be worth taking a look at to save some $$$ |
12-14-2018, 10:35 PM | #15 |
Rep 604
Even though I added performance mods after I got done doing lights/cosmetics.
Nothing beats bm3 stage 1. I am not even kidding, it's day and night difference in car's behavior! I'd highly suggest just tune it and add CP for sure if you do tune it. I blew my CP on stage 1 so do it before you tune it
2021 G80 M3C - Current
2017 G30-B58 - Sold 2013 F30-N55 - Sold |
12-15-2018, 11:10 AM | #16 | ||
Rep 10,249
12-15-2018, 12:24 PM | #17 | ||
Rep 14,107
12-15-2018, 02:15 PM | #18 |
2020 Z4 M40i - 2022 M4C Convt
3126
Rep 5,264
Drives: 2020 Z4 M40i - 2022 M4C Convrt
Garage List 1965 COBRA (FFR rep ... [8.57]
2023 Jeep Wrangler ... [9.50] 2009 Yamaha V-Star [0.00] Cars 2-BMW, 2-FORD, ... [0.00] 2023 Ford Expeditio ... [0.00] 2020 Z4 M40i [10.00] 2022 BMW M4C [7.25] 1998 FORD Ranger 4X4 [0.00] |
As mentioned an aftermarket CAI will not do squat till you are over 400WHP. Ran 12 flat with stock BMW intake which BTW is a CAI.
Charge pipes can be a problem, mine on a N54 started to fail at 18PSI. At the time got a BMS alloy unit to replace the stock version after the warranty replacement of the original also failed. Never had another failure. Had/have 2 N55's one 135is JB4 running an easy map, one 435i MPPK & have not lost a charge pipe or even had one disconnect on either car. If I was upgrading over a base performance install would add one. Personally my first two N54 parts were a JB4 & an FMIC. The stock Air 2 Air units on the N54/55 will heat soak very quickly in warm weather. The FMIC will not make power but will preserve the power the tune is making. BMW bailed out on the Air 2 Air units for the B58 340/440 & installed Water 2 Air inter-coolers. The Carolina summer will suck the power out of your car faster then you can put it in. Also agree that HPDS is the best first place to spend your money. BMWCCA Tarheel chapter runs a number of schools a year at Virginia International Raceway.
Kevin
Dravit Gray, Black Leather, Moonlight Roof, Red Calipers 2022 M4C - 2020 Z4 M40i - 2023 FORD Expedition XLT Max 4X4 400BHP - 2009 V-Star - 1998 Ranger 4X4 5MT - 1965 Cobra (R) 5MT - 2023 Jeep Wrangler Sport S 6MT Last edited by BEAR-AvHistory; 12-15-2018 at 02:30 PM.. |
