12-14-2018, 04:36 PM | #1 |
Rep 1,925
Gran Coupe M Sport Suspension Ride?
Hey all. I'm looking at a couple Gran Coupe w M Sport. However nothing local I can drive would need to place a deposit, then go out of state prior to purchase.
How is the M Sport ride vs. regular sport? This car will be a DD on terrible Michigan roads. I do like a sporty suspension but nothing rough. It might be better for me to lean towards a standard sport. I've driven a non sport 3 series and it was super floaty. I currently have a 320i m sport and I like the ride in the "sport setting". I've had a 15 M3 and the ride was unnecessarily harsh, M2 ride was spot on. Is there a diff between the M Sport and normal sport? I'll be searching threads in the meantime.
Current: 17 OG M2 / R8 Performance
Past Performance Cars: 01 M3, 05 M3, 06 M5, 08 M6, 08 M3, 11 M3, 13 M3, 15 M3, 911 C4S, 911 GTS, 17 M2,R8 V8, R8 RWS |
12-14-2018, 10:11 PM | #2 |
Rep 533
I've driven a 328i with m-sport and a couple of 435i GC non m-sport. I own a 435i GC M-Sport. The m-sport does seem to stiffen up the suspension but it's definitely not too harsh. This is a bmw after all not civic with cut springs. I think you will be fine. Also you can change from comfort mode to sport which I think makes a difference.
435i GC
12-14-2018, 11:11 PM | #3 |
Rep 4,325
if i'm not mistaken, RWD suspension options are base, adaptive, and the 704. if you don't have the base or adaptive, you have the 704.
for x-drives, there is no 704, so if you don't have adaptive, you have the base suspension. if both series have the same suspensions, i believe the 4-series chassis is a bit more rigid and a bit lower so it handles better than a 3-series. |
CalCarNut1060.50 |
12-15-2018, 01:14 AM | #4 | |
Rep 3,468
So basically, there's little chance it will be "too harsh". Even with a sport suspension (704) this is nowhere near a M3/4. As said above, the 4 is a little wider and lower and handles inherently a little better than the 3-series. Not a whole lot better, just slightly. In general, these are not very aggressive cars and with real sport (704) suspension you actually get a decently sporty suspension without it being ridiculous. Remember, BMW tuned this generation way back and it's far from "aggressive".
Current: 2018 Camaro SS 1LE, 2023 Colorado ZR2. Former: BMW 428i Gran Coupe.
12-15-2018, 04:32 PM | #5 |
Rep 337
I have the msport GC, the ride is never upsetting, although it is of course on the firmer side. It's about as good a compromise as you can expect really. My old F31 had adaptive dampers which were better in all regards - I would encourage you to find a car with that option if at all possible.
If you really can't find one with adaptive, then it's not the end of the world. Mine is on 20's and even then the ride really isn't annoying unless it's a seriously rutted road. |
12-16-2018, 11:59 AM | #6 |
Rep 10,256
Are you looking for xDrive or RWD vehicle?
My suggestion is to find a vehicle without M Adaptive suspension and get coilovers with individually adjustable compression and rebound controls to give you complete flexibility to tune the suspension behavior for Michigan roads. |
12-17-2018, 05:32 PM | #7 |
Rep 54
GC M Adaptive Suspension
I had a 2018 430xi GC with M Adaptive Suspension and 19” wheels. In comfort mode it was a very compliant ride. In sport mode it was definitely firmer, but still acceptable. I think with 18” wheels rather than 19s the ride would probably be even better. Of course the roads in Florida are better than many other places.
12-18-2018, 09:33 AM | #8 |
Rep 103
My GC has "sport" and "sport+"
It has adaptive suspension / dampers Comfort mode = great around town - light on the steering and softer ride Sport - ride firms up, steering firms up too - much more accurate. Sport+ as sport, but the traction goes into fun mode so the back is just a little more lively if you kick it. |
12-18-2018, 09:34 AM | #9 |
Rep 103
