04-13-2017, 07:26 PM | #1 |
Rep 178
Spark plugs F30 335i
Hey everyone,
Got a flat tire the other day, and when I took the car in the dealership says my spark plugs are due. So I'm sure many of us know the stealerships want around $450 to replace them, then they want to do your oil change and eventually get your bill to around $600,000,000. Put simply, I'd like to know if anyone can post a video/or instructions on how to change the plugs for a 2014 335i. I hear it's a simple process, so I'd rather not pay $400. So here are my questions: 1) Does anyone know how to change the spark plugs, and how often do you typically change your spark plugs? 2) What exactly will I require as far as tools go? Thanks in advance!
2014 335i | 6 MT | M-Sport | X-Drive | MPE | Black Sapphire Metallic | Coral Red | MHD 2+ | DP/CP | KN Intake
04-14-2017, 12:12 PM | #2 |
Rep 1,573
see this thread: http://f30.bimmerpost.com/forums/sho...55+Spark+plugs
It's fairly simple as long as you take your time. the thread includes directions from the Bentley manual. |
04-17-2017, 11:17 AM | #3 |
Rep 709
All you need is the spark plug socket, which in many cases is included in tool sets.
As for changing them, it is quite simple after you get all the wires and plastics out of the way, here is a video from youtube that should be helpful. I would most definitely do it yourself as the plugs will cost you around $70 and labor maybe an hour max.
Current: 12' E70 X5D | 04' Yamaha Warrior
Past: 13' Audi S6 | 13' E70 X5M | 13' E92 M3 Comp | 14' BMW 335xi GT | 95' E36 M3 | 84' BMW 733i | 06' Porsche Boxster S | 15' Jeep Grand Cherokee | 06' Acura TL | 85' Honda Shadow VT700 | 05’ Yamaha R6 | 12’ Triumph Tiger |
kevinjt151.50 |
04-18-2017, 07:53 AM | #4 | |
Rep 367
Polo088161614.50 |
04-19-2017, 03:33 PM | #5 |
not good, but bad
333
Rep 361
I have a detailed tutorial up on my blog if you need very detailed step by step instructions.
http://*************/2013-f30-335i-sp...-instructions/ The dealership quoted me the same price, the change isn't hard at all but does take some time.
They are spelled BRAKES not breaks!!!! Oh FFS, not another spark plug thread!
BreadsBMW on Youtube |
04-20-2017, 10:27 PM | #6 | |
Rep 2,825
04-20-2017, 10:43 PM | #7 | ||
Rep 5,776
I replaced them on my e90 which I found to be surprisingly easy--from bad breads blog the F30 looks to be a few more steps. But, still this engine is so much easier than a transverse V6. Make sure you have the socket( I ordered from BMS) and proper Torx socket.
Last car: 2011 335i Msport. JB4. Vrsf CP |
badbread332.50 |
04-21-2017, 11:31 AM | #8 |
not good, but bad
333
Rep 361
Yea, it's due to the rear two plugs being covered by... covers. It's easy as heck once they are out of the way.
jgoens3787.50 |
04-23-2017, 07:38 AM | #9 | |
Rep 368
so is everyone doing plugs at 60k? I just passed 60 in my 2013 |
04-23-2017, 07:44 AM | #10 |
Rep 6,036
You can also bring it to an independent mechanic if it's only $70 worth of Bosch spark plugs you can buy at auto zone. They probably won't charge you $450 if you're jittery about DIY.
11-25-2017, 10:55 PM | #12 | |
Rep 178
Costed about $200 with parts/tools and it was indeed a very simple process. The back two plugs are a little harder to work on but nonetheless an easy process, as long as you have the right tools |
01-04-2018, 04:35 PM | #14 | |
Rep 2,211
Good luck!
01-04-2018, 04:41 PM | #15 |
Rep 279
I did mine last week
I followed this video |
Carbon.F3070.50 1QuikWS61621.50 |
01-05-2018, 01:46 PM | #17 |
Rep 1,573
It will depend on the labor rates in CA (pretty high, I imagine). Here in Melbourne, FL the Dealer charges $30.80 p/plug which is about $196 w/tax. Dealer labor rate is $125. Figure they will probably charge 1.5 to 2.0 hrs of labor. (They go by the labor flat rate book for a jobs regardless how long it takes, unless complications occur). A decent BMW Indy labor rate around here is about $80-$90 with 1 hr of labor and he can get the plugs for about $20 from an autoparts store or his distributor for less. https://www.fcpeuro.com/ sell them for around $10 ea.
So a dealer here will probably charge between $350-$400. An Indy between $200-$275. Doing it yourself with plugs from someone like FCP Euro and 1 hr of your labor less than $100. (Disclaimer: Your mileage may vary depending on your driving style and the phase of the Moon) |
02-15-2018, 10:04 PM | #19 |
Rep 178
This video is great, thanks for posting! I could't find much on the F30 4/335's with those back two plugs but this answers most of the questions I had for next time.
03-17-2018, 07:21 PM | #20 |
Rep 529
Thank you so much for posting this video and thanks to whoever made the video! Why would anyone remove the strut bar and replace the strut bolts, seems pretty straightforward all u need is the right length extension to get that back plug out, I was all set to have to take the strut bar off up until seeing this video!
2013 F30 335i xDrive M-Sport 6MT (FBO/BM3 custom tune by HCP, 91 oct, 550i clutch, xDelete)
03-18-2018, 09:11 AM | #21 |
Rep 1,573
The issues with the strut bar bolts are BMW considers them a "single use" stretch bolt. The F30 Bentley Manual also reflects that. In reality, the local dealer only replaces them if they appear damaged. i reused mine on my first plug change, but will probably replace them on the next one as a "piece of mind" item.
Regarding the back 2 plugs, on my 13 335 N55, you need a universal adapter to get the correct angle on the back plug(s). The problem, in my case with a 3/8" drive set, is the plug is not centered in the shield so you are offset just enough that I could not get the socket seated on the plug. The universal was needed or if you have a 1/4" drive set you have have enough clearance to get sufficient access. |
03-19-2018, 07:34 PM | #22 | |
Rep 529
diy 3 series f30, maintainence, spark plug change |
