06-22-2016, 04:43 PM | #10539 |
Rep 106
Hi all,
I have a little question. I've been around a here since November looking around, and finally done my first coding to retrofit Rain/Light Sensor yesterday. However, my question is the acronyms. What is: FA And what's the difference between VO coding and FDL coding? And what does each stand for? I've acquainted myself with module names, and I believe I have a good understanding of how things work. From what I understand if I VO code let's say Rain Sensor, it will automatically apply the required changes to all ECUs without me looking around for which modules and which sections need to be modified, is that correct? Appreciate your input |
06-22-2016, 04:49 PM | #10540 | |
Rep 40,666
For VO Coding you select the ECU itself, not the CAFD File. VO Code = Coding of all FDL's (100% of the ECU) to predetermined settings based on the Vehicle Order. Connect => Read FA (VO) => Activate FA (VO) => Read SVT (VCM) => Right-Click on ECU (the ECU itself not the underlying CAFD) => Select CODE. FDL = Function Data Line FDL Code = Coding of individual FDL's in an ECU, overriding the VO Coding. Connect => Read FA (VO) => Activate FA (VO) => Read SVT (VCM) => Right-Click on the ECU CAFD and select Read Coding Data => Expand the CAFD Folder by clicking + symbol => Right-Click on the CAFD file and select Edit => Edit CAFD as desired => Click the Blue Floppy Disc Icon to Save CAFD => Click the green back arrow icon => Right-Click on the CAFD file => Select FDL CODE.
06-22-2016, 07:58 PM | #10541 |
Rep 10
Shawn, Master
[QUOTE=shawnsheridan;20146025]FA = Fahrzeugauftrag = Vehicle Order (VO)
May i have the links for coding? thank you, i really appreciate that |
06-22-2016, 08:44 PM | #10542 | |
Rep 10
06-22-2016, 09:26 PM | #10543 | |
Rep 40,666
06-23-2016, 05:16 AM | #10544 |
Rep 4
Hi all,
Has anyone attempted to enable Park Assist through coding? I have the reverse camera, front and rear sensors on the pro nav screen but wasn't given an option to specify Park Assist (pre-built) as part of the advanced parking package. Wondering is this feature can just be activated or whehter additional hardware is needed for it to work? Thanks |
06-23-2016, 06:08 AM | #10545 |
Rep 215
shawnsheridan would you be able to PM me the links to the latest and greatest software and pzData please? I had a laptop crash and lost all of it!
You wouldn't think I'm a consultant backup engineer
Rich
Current : 2022 G05 X45e Previous : G30 520D SE / F10 520D SE / F31 320 M-Sport Touring / E92 320D SE Coupe |
06-23-2016, 06:10 AM | #10546 |
Rep 40,666
PM sent.
06-23-2016, 06:18 AM | #10547 |
Rep 215
Rich
06-23-2016, 06:56 AM | #10548 | |
Rep 10
06-24-2016, 09:02 AM | #10550 |
Rep 40,666
06-24-2016, 07:31 PM | #10552 |
Rep 40,666
PM sent.
06-24-2016, 09:19 PM | #10554 |
Rep 40,666
06-25-2016, 08:08 AM | #10555 |
Rep 135
Hi Shawn, could you please share the D/L details for e-sys etc by PM.
Thanks in advance. John.
Past Previous: E92 335i, CIC retrofit, JB+, Perf Exhaust Last Car: MB ML350CDI, X800D-ML Retrofit, AMG Steering wheel, Brabus tuning box Current car: F31 335d - NBT EVO ID6 retrofit, 3AG retrofit, Coded EBT, Deleted RFTs!! |
06-25-2016, 08:56 AM | #10556 |
Rep 2
Hi,
I'm new to this forum. I have a 2015 mini cooper F56. My car was just at the dealership so I'm sure they put in the latest software. I would like to try doing some coding. I have the appropriate cable. Where can I get the correct software for my car? Also any instructions would be greatly appreciated. |
06-25-2016, 08:58 AM | #10557 |
Rep 1,076
Hi Shawnsheridan, I am trying to retrofit LCI tail lights on my f31. I saw you mentioned VO code Ho-wort HELC for an f80 when that LCI led tail light is done in another post. Is that the same for f30/f31 as well? And then VO code REM.
Also what is HELC? |
06-25-2016, 09:05 AM | #10558 |
Rep 40,666
PM sent.
06-25-2016, 09:07 AM | #10559 |
Rep 40,666
Yes, shoudl be the same. HELC is the After-market Fitment (HO-Wort) Code to add to FA and then Code REM.
06-25-2016, 09:09 AM | #10560 | |
Rep 40,666
