03-06-2021, 09:26 AM | #111 |
Rep 1,313
I can't seem to figure out my issue on a 2016 X4. My wheel is short circuiting. I don't know if I need a new clock spring, something isn't properly plugged in or I need additional coding?(Steering column light works).
05-30-2021, 06:07 AM | #115 | |
Rep 5
12-30-2021, 03:58 AM | #116 |
Rep 78
This thread is fantastic! What a find Hugrov. Followed everything said here, and now I have a toasty warm steering wheel. Being a bit of a noob to this BMW modding malarkey, I really struggled to find information on getting the steering column cowling off. So I ended up making a short video of the whole process, including using Bimmercode over bluetooth to do the coding…
12-30-2021, 06:05 AM | #117 | |
Rep 1,502
Drives: F36 435xd
I actually have the parts for this lying here. But has never come around to fit it. Looking at your video it looks like you actually don't need to remove the steering wheel or?
Brgds
Allan ‘15 F36 435xd Gran Coupé Ex: E46 330d, E91 330dA |
12-30-2021, 06:07 AM | #118 |
Rep 78
I couldn't seem to pull it away without removing the wheel, as it kind of "tilts" forward. That doesn't mean it can't be don't without removing the wheel and is absolutely worth a try 😀
12-30-2021, 06:09 AM | #119 |
Rep 1,502
Drives: F36 435xd
Hmmm will give it a try after New Year's Eve 😊.
Good video by the way👍
Brgds
moppity93.00 |
12-30-2021, 11:12 AM | #120 | |
Rep 644
moppity93.00 Techno 9000518.00 |
01-01-2022, 07:40 AM | #121 |
Rep 1,502
Drives: F36 435xd
Hi there
Got mine installed and coded today. Works like a charm. Managed to fit it without removing the steering wheel. Nice little feature😄
Brgds
01-17-2022, 04:45 PM | #123 |
Rep 180
01-24-2022, 04:23 AM | #124 |
Rep 30
Hey all, cold weather has piqued my interest in this retrofit for my pre-LCI.
I've got the traditional sportline wheel, no KAFAS / blindspot / lane departure (as it's pre LCI, think these were all post, right?). I've popped the cowling off today to check the slip ring. How can I tell if I've got the power cabling from the fusebox/FEM? Keen to work that out so I can price up the parts. Are these the only items I need?:
thanks |
01-24-2022, 08:38 AM | #125 | |
Rep 6
I did everything the same, and everything works great! but when I make a diagnosis with Carly it gives me the following : Fault code: 030351 Steering column switch cluster (SZL) (LIN): wrong version installed / Steering column switch cluster (SZL) (LIN): wrong variant Something to worry about? Tnx |
04-09-2022, 08:35 PM | #127 |
Rep 246
has anyone used the button with silver trim like the LCI models? I am wondering if they have the same functionality. PN is 61319384363, compared to the all black PN 61319201736
04-10-2022, 02:57 PM | #128 | |
Rep 1,659
But mines an LCi anyway. If I had known the difference, I'd have had the black. |
DLag30103.50 |
04-10-2022, 04:31 PM | #129 |
Rep 246
Thanks for the reply, I had an pre lci f30 with the heated steering wheel and my wife always had a hard time seeing the black button. This time around, I'm leaning towards the silver trimmed button.
04-11-2022, 02:03 AM | #130 |
Rep 1,659
@DLag30 I presume your switch is on the left of the cowl - mine is, but being right hand drive, it's quite visible to the passenger - you need to be a contortionist to see it from the drivers seat! Just use the fingers to feel. The little LED is a waste of time!
DLag30103.50 |
09-04-2022, 02:53 AM | #131 |
Rep 26
Thanks for this thread!
The car I’m hoping to get has the LDW with the kafas camera in the front window so hoping it’ll have the hardware. Wouldn’t feel confident removing the steering wheel so hopefully can be done without like others have. |
12-29-2022, 07:41 AM | #132 |
Rep 5
This is a great thread - I’m new to the forum, but have just completed on 2019 F36 440i. I had lane departure warning, so was fairly sure the heating elements would be there (didn’t check as didn’t want to fiddle with the air bag).
I ordered the parts without reading the entire thread - as previously discussed it turns out that some of the parts were updated with LCI, but I got the pre-LCI parts. I can confirm they work just fine - I actually prefer the all black surround for the switch, rather than chrome, so worked out well. I used the following from LLLParts. I’m UK based, but couldn’t get LLLParts to quote me in GBP, so just paid in USD. 61316823468 (BMW/MINI WAREHOUSE 2) $57.53 61319201736 (BMW/MINI BM) $73.12 For those looking to do this mod, can also confirm you don’t need to take the steering wheel off. Where possible I really don’t like playing around with airbags, so was pleased it worked fine. To remove the lower cowling, adjust the steering wheel to its outermost and upper position. Then get your fingers around the lower cowling, and pull (hard). It will come off, you might need to give it a good tug (oo er). I used White Rose Drive’s video for the rest. Putting the cowling back on with the wheel in place was tricky - in the end, I lined it up and gave it a firm bang in place with my fist to get the clips to engage. Needn’t be hard, sort of similar as you might have done to an old TV. For the coding, some of the bimmercode entries were already active (activ). Assume this might be some options I already had. Worked a charm, any questions let me know. |
moppity93.00 |
