01-17-2022, 08:36 AM | #1 |
Rep 198
New battery
I replaced my F32 battery with a new Bosch 019AGM and registered it. When charged it reads 12.56V.
After a day of not driving the car it drops to 12.03V Doesn't seem right, anyone had similar, or is this normal with all the electronics? With the engine running it's charging at 14.8V |
01-17-2022, 09:51 AM | #2 |
Rep 1,993
Drives: F30 335d
Well it is a 12V battery isn't it?
01-17-2022, 09:55 AM | #3 |
Rep 198
Yes, although I thought that a good, charged AGM battery should read 12.5V or more
https://www.bmwatlanticcity.com/how-...antic-city-nj/ |
01-17-2022, 11:04 AM | #4 |
Rep 1,993
Drives: F30 335d
The battery in mine is a Varta AGM which I've had for about 3 years, just checked it now and it reads 12.28V at rest.
How long have you had the battery?
if I've helped - an Appreciate would be, er, very appreciated!
01-17-2022, 11:42 AM | #5 | |
Rep 198
Had you recently driven yours? After driving mine sits at 12.5V but after a day without use it had dropped to 12.03V Multimeter records same values as OBD 2 reader. The 12.03V would recover if I wait the 10mins for all the things the car turns on by default to turn off! |
01-17-2022, 11:55 AM | #6 | |
Rep 15,858
Any warnings? BTW, why did you replace? |
2JPW55.50 |
01-17-2022, 12:23 PM | #8 | ||
Rep 198
01-17-2022, 12:59 PM | #9 |
Rep 15,858
01-17-2022, 01:03 PM | #10 | |
Rep 15,858
I suggest you most likely have a parasitic drain. Anything not been working correctly? Fitted with Comfort Access? Is the car going to sleep? |
2JPW55.50 |
01-17-2022, 01:15 PM | #11 | ||
Rep 198
I'll disconnect those two the next time I park and see what the difference is. |
HighlandPete6658.50 |
