BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > Need advice...
      01-15-2022, 01:02 PM   #1
sNICKa
Drives: '18 340i
Need advice...
The front passenger side run flat that my car came with blew out with a small tear in the sidewall today. The tires only have about 17000 miles on them. In a spot where it feels wasteful to buy one brand new one as the tread difference would be about double on the current tires. Thought about just buying a used run-flat for the time being. Thoughts? Thanks.
      01-15-2022, 02:06 PM   #2
weehe126
Drives: 2017 340i
Definitely better to get 2 new ones. They normally only last 20k miles anyways. How much tread is actually left on the other front?
      01-28-2022, 01:40 AM   #3
abayramov
Azerbaijan
Drives: F30 330i, E34 525i
Sell your one tire and buy two new.
      01-28-2022, 12:43 PM   #4
thejeremyman9
thejeremyman9's Avatar
4364
Drives: 2015 BMW 335i
Or take this as an opportunity to get 4 new non-runflat tires
      01-28-2022, 02:14 PM   #5
hybrid90
hybrid90's Avatar
Drives: 2021 X3 M40i
2021 BMW X3 M40i  [10.00]
This would be my advice as well. Better to have a matching set, especially on the front.
      01-28-2022, 05:38 PM   #6
CajunBMW
CajunBMW's Avatar
Drives: BMW 340i and X1, Chrysler Van
Definitely get two. That has happened to
me a few times after taking a few construction nails in the tires.
There are some new Michelin Pilot sport 4zp run flats that seem at least to me worlds better than anything I have run in the past. In case it matters they are also star bmw rated.
I have also noted that the tire pressure on the door does not work well with oem run flats. My dealer recommend different pressure and on my second set of tires I doubled the mileage on them. The door says 32/35 for my 340. The dealer said 36 square and that has worked great. I would probably even go to 36/37 as the backs wore just a slight bit faster. For me, the first set of rfts were all worn on the edges, not the middle using the 32/35 setting; with the 36 square I had even wear on all four tires for the most part (maybe a little bit more on the back. I have a staggered set up so I can not switch from front to back. Anyway I hope that might help?
      02-19-2022, 05:02 PM   #7
n55david
n55david's Avatar
2017 m240i xDrive  [0.00]
2015 X3 x35i  [0.00]
2015 335i xdrive  [0.00]
You never said if the car is rwd or xdrive... js
2015 335i xDrive 10.95@124.99mph w/bm3 - SOLD
2015 X3 x35i pwg 12.96 catless w/bm3 stage 2 93 ots
IG: @n55david For pics and updates!
Youtube: @ n55david For videos or Racing etc
      02-19-2022, 06:05 PM   #8
OM
Drives: BMW 428i Gran Coupe F36
Best way to go may be to replace both tires w New
      02-20-2022, 12:47 PM   #9
sNICKa
Drives: '18 340i
Hey everyone appreciate everyone's input. I know some time has passed but wanted to give a little update. At the moment when I had made the post I needed to be able to drive the car asap since I had a family member in the hospital. All local shops did not have tires in stock and needed to have them shipped which would have taken too much time given my situation. I went ahead and just replaced the front with a used run flat. I have bought a new set of tires and am going to be replacing all 4 of them soon enough
