BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Photo, Video, Media Gallery, Journals > ronanz's F32 EBII Build Thread : Update 10/27/18
      07-23-2019, 07:16 PM   #177
ronanz
Gettin It Figured Out
ronanz's Avatar
Drives: 435i FBO PS2 bm3 w/ options
Originally Posted by chaungo View Post
Nooooooooooo, I have CIC too
LOL! The Android unit I have works perfect for what I need it to do. Primarily WAZE
My Build Thread can be found HERE
      07-24-2019, 10:45 PM   #178
lens
lens's Avatar
2070
Drives: 2018 340i xDrive
I just need spotify, and fast navigation like the NBT.
      07-25-2019, 01:17 AM   #179
ronanz
ronanz's Avatar
I'm pretty sure Spotify is integrated with WAZE now....ZERO issues with Nav, either via CarPlay or native WAZE app.
Using CarPlay, audio is played through AUX, using app - audio is played normally
      07-25-2019, 08:33 AM   #180
lens
lens's Avatar
2070
so if you car came with nav and bluetooth and backup camera and the such, would you need to add any of the extra options they have on the site? I might get your thing since it's cheaper and no need to code, though they have the extra options like backup camera or microphone and stuff, is it legit plug and play? or do I have to change the wires and stuff?
      07-27-2019, 11:23 AM   #181
ronanz
ronanz's Avatar
Only extra options I added was CarPlay. I believe if you have Nav, you'll need the MIC splitter....EVERYTHING including OE BU camera is PnP. You'll need to transfer the green "optical cable" from OE side to provided harness as well...
Also, once installed, download bm3 Android app to head unit, log in and run your dash gauges ..
Gauges shown: 10.25 Android screen and iPhone X
Install Video
      08-04-2019, 06:03 PM   #182
ronanz
ronanz's Avatar
2020 C8 Corvette Configurator
Although I'm waiting for the Z06 (still 16-24mo's out), here's my Build...
      08-08-2019, 06:02 PM   #183
ronanz
ronanz's Avatar
M Performance LSD
Coming in hot!
May have snagged the last one available anywhere, via getBMWparts dot com...thanks for the heads up Blocke ! .
      10-17-2019, 06:05 PM   #184
ronanz
ronanz's Avatar
Drove back to NM to get my M Performance LSD installed as I have a relationship with Service manager and Master Tech. All my local dealers wanted 4.5 to 5.5hrs labor...a few Inde's were about the same (figured they wanted higher rate to purchase 1/2 shaft tool and wrench), I didn't want to be their guinea pig.
Did my prelim clutch break-in (20-25 figure 8's and 20-25 left/right circles). Will have a nice 530 mile drive back to AZ to complete break-in...
      10-17-2019, 08:26 PM   #185
F30_SixSpeed
F30_SixSpeed's Avatar
1171
Drives: 335i M Sport
Awesome. I am looking forward to your thoughts on the LSD
335i M Sport 6MT || PS2 Turbo, FBO, XDI-35 HPFP, BM3, KW, MP BBK, OEM+
INSTAGRAM || BUILD THREAD
      10-19-2019, 07:49 PM   #186
ronanz
ronanz's Avatar
NM to AZ...550 mile LSD break-in ✔️
      10-26-2019, 09:38 PM   #187
ronanz
ronanz's Avatar
LSD Thoughts
Having now spent a few days of spirited twisty driving through Northern AZ, I can definitely state (as most everyone else has) the LSD is worth the $$.
As suspected (and stated by many), lateral power along with entry/exit control is FAR more predictable...adding confidence through the twisties (perhaps foolishly)
My opinion, anyone planning on exceeding 450whp MUST invest in one....whether M-Performance or 3rd party. If you plan on keeping the car, you gotta have one. . . 🍻
      12-02-2019, 12:36 PM   #188
ABQ
Drives: 2017 BMW 340i
Very curious about this...
3 stage candy. Kind of a pain to get right as CF is hard to paint clear. If you're going EBII, it has to be mixed lighter than paint code or it'll dry almost purple.
I'm looking at adding a CF performance lip to my EBII 340 and am trying to decide between painting vs. leaving plain CF. Is the shop you used in Albuquerque? If so, which one? If not, would you be willing to let my shop talk to your shop about the painting process?
Thanks much!
      12-02-2019, 03:01 PM   #189
ronanz
ronanz's Avatar
Thanks much!
PM sent
      12-04-2019, 12:36 PM   #190
ABQ
Very much appreciated!
      12-27-2019, 10:59 PM   #191
F22ryan
Drives: 2016 BMW m235i xdrive
do you have any information on how to remove the dinan tune?
      12-28-2019, 07:45 AM   #192
ronanz
ronanz's Avatar
Since you didn't specify which tune, I'll assume you have the "Sport Tuner" which is the easier install of the two. Box is plugged in between TMAP and factory TMAP plug
1. Disconnect Neg. terminal on battery (DO NOT CLOSE TRUNK!!)
2. Locate TMAP sensor on your charge pipe (tuner is plugged in here)
3. Unplug tuner from TMAP & Factory plug
4. Replug factory plug back into TMAP
5. Reconnect battery Neg terminal
Dinan instructions HERE
      01-12-2020, 11:37 PM   #193
ronanz
ronanz's Avatar
Dorch Engineering S2 Coming in hot!! .
Looking forward to the install .
Dorch Engineering info can be found HERE
      01-14-2020, 01:46 PM   #194
Randy Johnson
M340i
Randy Johnson's Avatar
Drives: BMW M340i
2021 BMW M340i  [10.00]
Op,
Would love to know what the cost of mods has been up to this point.
      01-14-2020, 08:03 PM   #195
ronanz
ronanz's Avatar
Originally Posted by Randy Johnson View Post
Op,
Don't think I'll share the exact amount...but, this is the video I used as a guide .
FrankDK170.00
      01-31-2020, 09:12 PM   #196
ronanz
ronanz's Avatar
Dorch Engineering S2 HPFP
Gotta love package delivery days!
Thank you Chris Dorch Engineering ! .
      02-15-2020, 04:06 PM   #197
ronanz
ronanz's Avatar
Definitely going...depending on how quickly Cary can get a tune turned around will determine whether I'm a spectator or participant .
If there's any local guys going, PM me so we can meet up and convoy down
      02-25-2020, 10:45 AM   #198
coach_jb
Drives: 2014 BMW 435i
PM sent
I'm in ABQ as well and would like to know who did the tint on the CF pieces.
Thanks in advance
