02-21-2016, 08:43 AM | #45 | |
Rep 821
Not sure of the correct spelling. |
02-21-2016, 10:31 AM | #46 |
I want to drive a Zamboni
1131
Rep 5,557
Drives: 13 E93 M3 18 F80 M3 16 K71
According to my SA the shadow line trim is most common with squeaking noise problem, took mine back for three times and could not get rid the problem. Dealer replaced the tapes twice and problem keep coming back.
18 F80 Imola Red 6MT
16 K71 F800GT Montego Blue 13 E93 M3 Melbourne Red 2000 E46,2006 E90,09 E82,13 E93 328i,14 F30 335i,18 F80 M3 My next vehicle would be a Zamboni |
02-21-2016, 06:40 PM | #47 |
Rep 2,744
Doesn't make sense; what tape were they using? This isn't exactly a difficult or tricky fix. One of these lubricating tapes should make the squeaking stop immediately/permanently.
02-22-2016, 09:56 AM | #49 |
Rep 1,739
It sounds like a rubbing/creaking sound to me. Think of rubbing Styrofoam against something...then tone it down quite a bit. It's like that.
And I tried silicone grease and like JBrock...it didn't help me. It was worth a try though. Let me see if I can find this gummi phelge stuff. Edited to add.. Here it is. I'll try it. http://www.amazon.com/einszett-91480.../dp/B004B8GTQG |
02-22-2016, 11:26 PM | #50 |
1131
Rep 5,557
I believed it's Teflon tape but I couldn't tell by the brand.
02-23-2016, 04:45 PM | #51 | |
Rep 72
Personally, I'd just order the tape and be done with it. |
03-05-2016, 02:05 PM | #52 |
Rep 26
I bought the $30 3M knockoff version from Amazon as another poster did. Definitely solves the problem. Unfortunately, it doesn't look that good IMO. I'm a little annoyed that I have to put tape on my trim to solve this.
03-06-2016, 07:56 AM | #53 |
Rep 2,744
Agreed, but it's only visible when staring at the trim with the door open. I.e. NO ONE sees it. Yet everyone hears the squeaks without it.
04-06-2016, 09:14 PM | #54 | |
Rep 18
Drives: 2013 335xi M-Sport
Next, I tried the tape and got annoyed with trying to make it look good...(no wrinkles or anything) While the noises were mostly gone, it did not exactly look legit So just today I applied some DuPont Krytox grease on the seals. After going for a quick ride on some known noisy roads, it did the trick as well as the tape if not better. I also noticed that it seemed to cut out a bit of the wind noise as well. All the bros with convertible tops seem to use this stuff to stop the squeaks from the seals... Standby for how long the grease lasts, Ill keep y'all posted. I have read some other posts with good results from it as well. |
04-07-2016, 10:05 AM | #55 |
Rep 603
I also started experiencing the dreaded noise (which my wife's 335i does have as well) on my new week old 340i. I think the tape solution is probably best but to avoid taking my brand new car back to the dealer already I grabbed some of the WD40 Silicone specialty lubricant I have and applied it to the top felt portion of the rubber seal. All of the noise is immediately gone; we'll see how long this lasts but it only took a couple of mins to apply.
04-08-2016, 05:53 PM | #56 | |
Rep 100
04-08-2016, 09:50 PM | #57 | ||
Rep 140
05-18-2016, 11:52 AM | #58 | |
Rep 65
05-18-2016, 06:11 PM | #59 | ||
Rep 140
05-18-2016, 07:24 PM | #60 | ||
Rep 821
05-18-2016, 07:32 PM | #61 | |
Rep 821
05-18-2016, 10:00 PM | #62 |
e90noob
1588
Rep 1,862
I took my '16 328 in twice for the creaking noises
First time I was given the "could not duplicate concern" bs excuse Second time, I had more time so I drove with a service tech He said he knew exactly what the cause was and that the solution was to use a tape on the window seal Did not mention that there was any service bulletin for it Got my car back and now the creaking is gone Are the people buying their own tape outside of the free maintenance period? Or you just like doing your own maintenance? While I am covered, I plan on making sure the dealer takes care of every conceivable repair item |
05-27-2016, 02:12 PM | #64 |
Rep 1,739
Mine has suddenly gotten worse over the past couple days. Both driver and passenger doors are creaking. Will try the Griot's Rubber/Vinyl conditioner first, then the Gummi Phlege if that doesn't work (I have both). This has to be something that happens to the rubber over time. I never had this for two years.
05-27-2016, 05:30 PM | #65 |
Rep 199
My 340i started making noise a couple weeks after delivery. Drove me mad. Cleaning the shadowline trim would last a week or so. Finally brought my car to my local dealer and they did a great job with the Teflon tape. Spoke to the tech about it and he said he hadn't seen too many issues as of late but said he saw many issues with the e60. He did an awesome job and obviously took his time. No bubbles and not visible with doors closed. Will only notice it with doors open because you know it's there. Hopefully it lasts.
06-01-2016, 03:12 PM | #66 |
Rep 1,056
My 6 months old 340i is having the door creaks after 3500 miles.
Ironically it started few days after I washed/cleaned the car. I might have applied Aerospace 303 to the rubber seal and trim. Ordered the $10 and see. Had the 328i M sport for 3 years and no annoying creaks like this.
