BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Fix: annoying door creaking - bmw 3M tape solution
      11-20-2017, 07:39 AM   #89
Ladhaan
Drives: 2018 430i xDrive M Sport
Originally Posted by neo61uk View Post
I think I acctually used this one
http://www.diy.com/departments/t-rex...1200206_BQ.prd
But it was black.
Not at home now to check but both should do if black colour.
It was on a car for months and it was perfect and not visible.
Is This an issue on the 2018 i430 gran coupes? Picking mine up on Saturday, so just want to know.
      11-20-2017, 07:54 AM   #90
gspannu
Drives: F10 535, F82 M4
I don't think it is very model specific. Over the years, the general consensus has been that cars with 'Shadow Line Trim' are more prone...
      11-20-2017, 08:03 AM   #91
Ladhaan
Thx
      11-20-2017, 08:25 AM   #92
neo61uk
neo61uk's Avatar
Drives: F31 340i Performance Edition
Thanks.
I notice these are simple tapes. I thought we needed tapes with some felt (cushion) on them. But hey, if these work, then why not !
Thanks, once again....
Trust me no cushion or teflon is needed.
Problem lies in Shadow Black trim we have rubbing on a door seal.
As soon as you put something in between its quiet as should be.
Good luck
gspannu199.50
      11-22-2017, 03:36 AM   #93
gspannu
Originally Posted by andrew 330i View Post
~ I know many have discussed the annoying creaking noises that come from the door areas as a result of the upper door felt/rubber rubbing against the black shadow line trim (typically sounds more like the noises are around the door pin/striker area). Cleaning and waxing the area always seemed to help for a short while but not long term.
I brought the bulletin to the attention of the dealer and they ordered a roll of the 3M Teflon tape.
<Missing Photos>
All and all - fairly easy to do with the attention to detail and prep. Total install time 45 minutes.
Finally no more door creaking on uneven pavement. Problem solved.
(Bulletin: SIB 51 28 10)
The photos from your original post have disappeared. Could you put these up again.... Your post is extremely helpful, many thanks.
      11-22-2017, 04:10 AM   #94
Ikester19
Ikester19's Avatar
Australia
2124
Drives: G20 M340ix; F30 328i msport
2018 330i LCI  [0.00]
2020 G20 M340ix  [0.00]
I had the same problem. Got some Gummi Plfege Stift by nextzett, it conditions rubber seals. I applied this to the seal around the top of the door frames and voila!! Fixed the problem completely!
      11-22-2017, 05:14 AM   #95
gspannu
Gummi Plfege does work - but only for a short duration; depending on the weather. Best case scenario is it lasts 2 months, worst case it lasts a week - and then the annoying rattle is back.
I am looking for a more permanent solution and the Tape (Teflon or otherwise) seems to be the way to go. This has been confirmed in other forums as well.
Hopefully, the original poster will put up the photos again.
      11-22-2017, 10:29 PM   #96
geddylee
Drives: 2021 X7, 2019 X5
I only noticed this on 2016 3 series, several people at my office have them and they all do it. Does anyone know if this was fixed on the 2017's?
      11-24-2017, 04:46 AM   #97
Ikester19
Ikester19's Avatar
Australia
2124
Ok, will see if the creaking sound returns, although for me it’s now been over 7 months without any issues at all
      03-31-2018, 09:52 AM   #98
fishmonger6
Drives: BMW 340i MSport
Sorry about bumping old thread but does anyone have photos of where the tape goes? The original post’s photos are gone. Thanks in advance!
      04-02-2018, 10:16 PM   #99
sspade
sspade's Avatar
Drives: F30
2016 BMW 320i  [7.87]
2014 BMW 328i  [6.83]
Originally Posted by fishmonger6 View Post
Sorry about bumping old thread but does anyone have photos of where the tape goes? The original post's photos are gone. Thanks in advance!
I was thinking the same thing (cant see pics). Been experiencing this more and more lately and would like to see exactly where to place the tape within each door frame goes. Also, where are people ordering the tape? Is a $250 roll really necessary? Hoping the value has dropped since this thread was created.
      04-03-2018, 01:40 AM   #100
IAmATeaf
IAmATeaf's Avatar
Drives: 2015 F30 335i
2015 BMW 335i  [0.00]
On my f30 the dealer replaced all the window guides which for me solved the annoying squeaks.
      04-03-2018, 06:16 AM   #101
EricVR4
EricVR4's Avatar
604
Drives: 2023 X3 M40i
For anyone looking for pictures on how to apply the tape, see this thread as well....it links to another guide with pictures too. I just ordered some tape off Amazon and will be doing this over the weekend:
[UPDATE 11/17/2016] *SQUEAK* and the 'Teflon' tape deal explained with pictures.
Door Seals Tape Guide
      04-03-2018, 06:46 AM   #102
7iM3less
7iM3less's Avatar
Drives: F80 M3 ZCP
I had a similar challenge myself and it went away after I 3m vinyled my trim to satin black.
Mine use to be chrome.
2016 BMW F80 ZCP
Instagram : 7IM3LESS
https://instagram.com/7im3less?igshid=YmMyMTA2M2Y=
      04-03-2018, 10:09 PM   #103
The Airman
Drives: 2021 i3s
By gently lifting on the door handle and the underside of the mirror, I could get my doors to squeak, and it seems to be coming from the top seal just as the other thread shows where to mount the tape.
Too me it sounds like when you move around on an old leather sofa or chair.
And the top rubber seal itself seems to be that felt backed rubber instead of a plain rubber seal. So maybe BMW was trying to fix the issue with the different type seal. But it is still unacceptable.
I think I'll try some pure silicon spray I have before I go to the dealer for the tape job.
2021 i3s AC Schnitzer
BMW CCA #67486
      04-04-2018, 04:01 AM   #104
fishmonger6
Thanks EricVR4!
EricVR4603.50
      04-06-2018, 11:37 AM   #105
Chrisupra
Chrisupra's Avatar
41
Drives: 2014 328i F30 N20
I noticed this only during the very cold temperatures on one of my rear doors.
      04-07-2018, 02:24 PM   #106
EricVR4
EricVR4's Avatar
604
I taped the shadowline trim last night using this tape (TapeCase 423-5 UHMW Tape 3/4" x 5yds). I bought two rolls and used a little bit of the second one and it worked perfect....for now anyway, let's see how long it lasts.
Silence is wonderful thing though
      04-07-2018, 02:40 PM   #107
Kafkaesque328
Kafkaesque328's Avatar
Drives: 2016 328i M Sport
Unless your car is out of warranty there is no reason you should be trying to solve this yourself. Gummi Pfledg, while good on rubber seals will not solve your problem. This is a well known issue and their is a TSB (Technical service bulletin) on the issue and the dealer will do it right. My car had this issue and I brought it in after the 2nd week I had it and they installed the teflon tape, which is black and not really visible unless you're looking and its dead silent, and has been for the past 18 months.
2016 Black Sapphire 328i | M Sport Pkg. | JB+ | Premium Pkg. | Heated Seats | Driver Assist Pkg. | Navigation | Misc. Coding | 35% Ceramic Tint
Past: 2014 Black 320i | Sport Pkg | BMS Stage 1
      04-08-2018, 11:14 AM   #108
EricVR4
EricVR4's Avatar
604
Agreed, my schedule has just been really busy and I didn't feel like messing with making an appointment and all that. The tape was cheap, plus it's clear so you can't see it, and it took 5 minutes to put on. If it eventually stops working then I'll just have the dealer fix it, but for now this was the quickest solution.
      04-08-2018, 02:00 PM   #109
Kafkaesque328
yeah, the visit to the dealer is a drag
      04-08-2018, 10:46 PM   #110
The Airman
Drives: 2021 i3s
So, you put clear tape on the top of the trim where the top door rubber seal touches. Correct?
BMW CCA #67486
