09-26-2019, 01:10 PM | #1 |
Rep 122
Switching from Dinan stage 2 to BM3
I have a Dinan tune stage 2 (piggyback) on my n55 435 and I just got the BM3. I want to remove the Dinan and flash Bm3 instead but the thing is I don't have a torx 47 at the moment to physically remove the tune. I was thinking of maybe switching to Base map on the dinan on my phone (which means it's disabled) and run bm3 until i get the t47 and remove it, what do you guys think?
on the Dinan app, i can switch between base (disabled), stage 1 & stage 2. if the Dinan tune is disabled isn't it the same as if it was removed? I'm just too excited to try the bm3 and don't wait to wait to get a T47
Dinan Stage2 | Fabspeed High Flow DP | Dinan Carbn Air Intake | Remus Exhaust | H&R Sport Springs | 19" Savini Wheels | Continental ExtremeContact Sport Plus | Rear Diffusr | M4 Carbn Mirror Caps | Smoked Sequential Mirror Signls | Lip Spoiler | **PREVIOUS VEHICLE: 2013 BMW F30**
**INSTAGRAM: aphotic_f32 ** |
09-26-2019, 02:06 PM | #2 |
Rep 252
Drives: 2017 Model S P100D
Make sure the battery is disconnected first and just snip the wire right at the torx. I disconnected the dinan tuner at home and realized that I didn't have a torx after everything was disconnected when I switched from the dinan to bm3. A little ring crimp terminal won't harm anything being left on
09-26-2019, 03:07 PM | #3 |
1297
Rep 3,536
Youre gonna be so much happier
2015 335i xDrive 10.95@124.99mph w/bm3 - SOLD 2015 X3 x35i pwg 12.96 catless w/bm3 stage 2 93 ots IG: @n55david For pics and updates! Youtube: @ n55david For videos or Racing etc |
09-26-2019, 11:42 PM | #6 |
Rep 122
Thanks for your input,
I just watched a video from Bryan (Kies Motorsports) and he says that if you have a jb4 connected you can just put it in map0 (disabled) so I guess it's fine disabling the dinan and keeping it connected it for now. I will add my feedback about bith 2 tunes in the next couple of days after trying the bm3
09-27-2019, 09:43 AM | #7 | |
Rep 252
However, I had no way of disabling the piggyback tuner since it didn't come with an app, that's why I just cut the power wire at the terminal when I realized I didn't have a T47 and removed the entire tuner before going bm3. Having a little crimp terminal that's left in there for another day feels a lot less invasive than having a unit that is breaking a connection between a bunch of different harnesses inside my engine and being told not to transmit anything. What if it doesn't pass through the rest of the normal OEM data that is meant to be going through? What if for some reason it resets and starts broadcasting and adds another 4-6PSI to the system when I'm WOT? Must be the e.eng. in me |
09-28-2019, 06:38 AM | #8 | |
Rep 122
I love the burbles with the BM3 as for power, I feel it's a bit more powerful than Dinan stage 2 but not a lot but you definitely feel the difference. If it wasn't for the added burbles I probably wouldn't have done it, but again for the price, increase in power + burbles, very much worth it!
10-01-2019, 11:00 AM | #9 |
Rep 5
I also have the Dinan stage 2 and bootmod3. I just put my dinan to 0 and sofar everything is working fine. I have not have the time to unplug the dinan.
10-02-2019, 07:14 PM | #10 | |
Rep 191,028
10-03-2019, 05:35 AM | #11 | |
Rep 932
10-03-2019, 03:53 PM | #12 | |
Rep 5,378
Hmmm....there's an M235 6MT dynojet plot showing 383whp and 394wtq with the Dinan Stage 2 and downpipe and the run being in quite hot weather no less. I have a hard time seeing a BM3 Stage 2 exceeding those numbers, by much, as every BM3 Stage 2 dyno I've seen isn't much higher, if at all. https://www.2addicts.com/forums/show....php?t=1122931
10-04-2019, 12:37 AM | #13 | |
Rep 932
10-04-2019, 07:36 AM | #14 |
Rep 1,499
I put down 381 whp, 429 wtq on BM3 stage 2 with shitty California 91 octane two yrs ago, several map revisions earlier than current. I'm in NC now with 93 octane and E85. Installing meth this weekend then plan to dyno sometime before the end of the yr with meth and the stage 2 E30 map. Hoping to get into the 400+ whp club.
10-04-2019, 11:29 AM | #15 | |
Rep 5,378
I don't believe the M235 Dinan Stage 2 run to be a "glory" run at all. Posted below is an M235 Dinan Stage 1 Dynojet run in 90 degree weather pulling 340whp/365wtq with no other mods. It's totally reasonable to think that a Dinan Stage 2 EWG N55 with a DP should pull 380+whp and 390+wtq as linked above. Both of these N55s should show slightly higher numbers in cooler and denser air. https://www.2addicts.com/forums/show....php?t=1126138 Sure, you can get slightly more HP and a bit more torque from a flash tune and even a JB4. However, much of that gained torque is below 4,000rpms. That doesn't do you a whole lot of good during an all out run because all shifts are landing at 5,000+rpms. Only for a fraction of a second in 1st does the extra torque help and likely makes you slower as it can induce traction issues. The old school Dinan piggyback is laughably expensive, but they did go to great lengths to make the power linear rather than a sledge hammer in the low end and having power cut issues on shifts because of momentary boost spikes (i.e., JB4s and other piggybacks). For performance driving, you want linear power and not a massive surge in power that overwhelms the tires with little notice. Dinan definitely focused on driveability above all out power. I think the flash tunes are a great option, but I also don't feel like they are remotely as "smooth" in power delivery as many originally proclaim given the number of issues reported in power delivery hiccups on this forum, the 2 series forum, and the M2 forum. Perhaps it's because many of those flash tune owners came for JB4s. BM3 is constantly revising their maps for better and smooth power delivery and in some cases, has reduced power/boost because it turned out to be bit too much for certain cars/DMEs. I feel like BM3 is using it's users as the guinea pigs. MHD seems to take a more conservative approach to power delivery and driveability much like Dinan and BM3 has become the BMS of the flash tuners where all out power is the goal.....because they know that's what most want above all other things.
Poochie9104.50 |
10-11-2019, 12:48 AM | #16 | |
Rep 122
I did not remove the Dinan because I didn't have the right Torx bit to disconnect the positive. Then a few days ago, I got the torx bit at night and disconnected the positive but didn't feel like removeing the dinan at the time so left it connected but without power thinking it disconnected in the first place. Next day I get a driveterrain malfunction and the car drove like shit, rpm was high , car wouldn't go faster than 80km/hr. later on I figured out what i did wrong. I should've removed the didnan fully and plugged back the 2 original sensors back in to the dme because the dinan was with no power it was not sending the signal back to the dme. Lesson learned!
10-11-2019, 09:48 AM | #17 | ||
Rep 252
05-31-2023, 02:01 PM | #18 | |
Rep 191,028
05-31-2023, 02:17 PM | #19 |
Rep 7,616
AmuroRay2305.50 mike@x-ph.com24317.00 |
05-31-2023, 02:42 PM | #20 |
Rep 191,028
OH
05-31-2023, 03:43 PM | #21 |
Rep 122
