09-22-2021, 01:11 PM | #1 |
Rep 532
ZF-8 un-commanded downshift
First time this has happened.
Car in Sport plus, ZF-8 in manual mode, entering a slow corner under braking I downshifted to M4, M3, M2 then accelerated out of the corner. Shifted to M3 then to M4 when suddenly the transmission kicked down to M3 un-commanded pegging the car to redline. I hit the upshift again and it bumped back to M4. I'm new to the ZF-8, I know the trans will upshift even in manual mode but I've never heard of one downshifting under load. Now, one of my buddies (not a BMW person) speculated maybe I could have knocked the shifter out of manual mode. I didn't think to check when it happed but driving back I noticed the ZF-8 was back in auto mode and I don't remember changing it.
09-23-2021, 11:04 AM | #3 |
Rep 3,533
Is kickdown still active in the configuration you were using?
FlorinQCK-2.50 |
09-23-2021, 12:13 PM | #4 | |
Rep 532
I really don't know. Kickdown usually happens when you go full throttle in too high a gear then the ZF-8 drops down to optimize the power band. The kickdown in this instance was abrupt and startling.
FlorinQCK-2.50 |
09-26-2021, 12:28 PM | #5 |
Rep 131
I believe in the 328s the transmission is programmed to always have this behavior regardless of mode. I remember reading this was changed with the LCI and my 340i certainly does not exhibit this behavior. In Sport+ and manual mode (with shifter in sport mode) I can hit the rev limiter and be in whatever gear I want and the car won't do anything about it. The only thing it still does it auto select 1st gear when at a stop.
erickonphoenix1708.50 FlorinQCK-2.50 |
09-26-2021, 06:55 PM | #6 |
Alexander Hartunian
58
Rep 95
Drives: 2018 BMW 440i
My 440i only downshifts when I click the kickdown trigger in auto or S/A. But never in M/S
2018 F32 440i - Black Sapphire Metallic - KW Suspensions V1 | VRP Intake | VRSF Catless Downpipe | Dorch Stage 2 HPFP | MHD OTS Stage 2 E40
