06-13-2017, 01:07 PM | #133 |
Rep 955
I finally got around to putting the module where it belongs... On the bottom of the car near the diff.
BTW : Its possible to do this without lifting the car. I did it without lifting the car. It took way longer then it would have had I lifted the vehicle but I was able to get the module attached where it belongs, and the wire routed in a way where its not going to hit anything moving (eg: the rear axle). Also, I tapped into where I had it setup before. I drive controller. Same with voltage, took it from there too. Its possible to route the cable under the rear seat, under the small bit of carpet between the rear seats (go in the middle, thats the easiest way) and through the center tunnle up to the idrive controller. After moving the module where it belongs, and resetting the TPMS... The wheel positions are now of course correct. Before when I had the module just sitting under the idrive controller, the rears would show on the front and the fronts on the rear. Not no more. Thanks for all those who helped make this happened. I find this retrofit quite useful. Had a trip a few weeks ago with 2 guests in the rear and a trunk full of luggage. I run 2.5bar up front and 2.6 in the rear... With the guests and all the luggage... 2.9 and 3.0. Thanks to this retrofit I knew to get out and let some air out of the tires |
07-22-2017, 12:15 AM | #135 |
Rep 40
Another successful RDC conversion on a 2016 F31.
Bought new Sensors off ebay from slovakia around $200AUD, $80 to get sensors fitted to wheels. 2 hours playing to code correctly, then re-enter all my existing codings and its all working. Only difference I can see is my Display is 2 dimensional aerial view, rather than the 3D view i've seen in others threads. I only get one option, display and reset in iDrive, not the second one showing all in 3D glory. |
07-24-2017, 05:56 AM | #136 |
Rep 1,772
07-24-2017, 05:58 AM | #137 | |
Rep 1,772
The newer sensor seems to be cheaper on eBay and I'm looking to pull the trigger soon if this newer part is ok. |
07-24-2017, 06:11 AM | #138 | ||
Rep 1,772
Edit - Never mind found it on page 2! |
07-28-2017, 09:17 PM | #139 | |
Rep 40
I also used either realoem.com or www.genuinenewparts.com to lookup and verify part numbers before searching |
08-23-2017, 05:51 AM | #140 |
Rep 1,772
08-23-2017, 06:17 AM | #141 |
Rep 1,291
I could not see any difference, i think i left it this way.
All i can say is that it definitely worked as the system detected a mild pressure drop and threw a warning a few weeks after the install, due to a nail in my tyre. |
08-24-2017, 04:46 AM | #142 |
Rep 1,772
Had mine installed today and initially it did not work.
I went through the coding and in the dsc module I changed c funktion rdc to aktiv instead of nicht aktiv which is what is posted in this thread. Happy to report all works now! I used the latest tpms with part number ending in 890. |
Lancelot567.50 |
08-25-2017, 06:17 AM | #143 | |
Rep 1,772
When set to active and you do a tpms reset there is now a progress in % 0-100 of when the reset is done. |
Lancelot567.50 |
02-18-2018, 08:29 AM | #144 | |
Rep 81
Hi Everyone I’m desperate to get rdc tpms to work, I’ve added the module and sensors in the wheels and coded as above using BimmerCode apart from FEM as I can’t see it in my F06 GC I realize this not the same model forum but the same topic. It’s a Europe spec car my 14 with rpa all I get is rdc failure message I wired the model as per TIS k_can to reverse camer video module. Parts used are are Module 36106881474 Sensors are 36106856227 What am I missing?? Please help Side note I reversed the k_can wires and got pressure reading then rdc failure showed up rechecked all wiring was correct so I switched them back. |
02-18-2018, 11:21 AM | #145 |
Love to Drive
197
Rep 602
02-18-2018, 01:31 PM | #146 |
Rep 2,302
02-18-2018, 01:38 PM | #147 |
Love to Drive
197
Rep 602
02-19-2018, 02:48 AM | #148 | |
Rep 1,772
02-19-2018, 02:50 AM | #149 | ||
Rep 1,772
02-19-2018, 05:26 PM | #151 | |
Rep 1,772
However, worse case scenario if it's still needed it should be easy to buy and not too expensive. Seems like a few members have done the install so might be able to help you there if it's needed. |
02-20-2018, 05:33 PM | #152 | |
Rep 106
03-29-2018, 12:57 PM | #153 |
Love to Drive
197
Rep 602
Hello Guys...
I am looking at going forward with this... Install on a 18 M240i Sensors I am looking for are 36106856209 that are supposed to work with models after 2014. So installing this sensors + coding should work right? Is there someone here that could help me with the coding part for some cash? Thanks! JC |
04-12-2018, 12:26 PM | #154 |
Rep 58
Hello everyone. I notice that in this thread you are getting fabulous things with the rdc. I have a problem but my rdc has stopped working after installing the reversing camera and the kombi 6wb. At the same time, the door remote control has stopped working. I have to press very close to the car to make it work. My car is a cabriolet F33 of July 2014, and it has a receiver antenna, so I suppose that the ecu ddc is integrated into the dsc.
The error in ista says: missing message emitter rdc in receiver icm. Since the failure of the rdc and the remote control has been simultaneous, it is clear that the rdc sender is the culprit. But it's fine because I exchanged it with another one and it still did not work. The following steps have been: Update NBT, KOMBI, ICM and TRSVC, but everything remains the same. I have left to think that the problem is in FEM and DSC that coding can be solved or it would have to be updated. If someone can help me, I'll thank you very much. I am very lost and tired of seeing the failure notice in the kombi. Thank you very much. |
