06-19-2019, 12:21 AM | #1 |
Rep 191
Was wondering if these rims and tires would work on my 435i xdrive? I'm doubtful but the shop selling them says they'll fit and will not interfere with xdrive. They're HRE ff04sizes:
Front: 20x11 ET43 tire 285/30 Rear: 20x9.5 ET20 tire 265/30 Will the rims be better fitting with a smaller tire or are they not optimal for an f32? |
06-19-2019, 06:13 AM | #2 |
A family of bimmers
2747
Rep 7,742
no way. that front wheel will poke out from under the fender by like 2CM and the rear may hit on the inside of the wheel well. Those may be better suited for an F8X not the F3X
jimmy8904563.00 |
06-19-2019, 02:20 PM | #3 |
Rep 8,942
Even as someone who is very confused by wheel math I can tell you nope. Honestly I'd think about finding another shop that seems like very poor counsel unless you've got something screwed up in what you posted.
2022 Macan S
2016 F31 328i xDrive Sport Wagon 2006 E46 330ci ZHP Convertible |
jimmy8904563.00 |
06-19-2019, 06:47 PM | #4 |
Driver
200
Rep 516
pretty bad advice from the shop - concerning.
Use a tire size rolling diamater calculator like this https://tiresize.com/calculator/. The rolling diameter difference should be within 1% for xdrive. The shops suggested set-up makes the rolling diameter difference 1.5% This is aside from the other concerns mentioned about the rubbing. |
jimmy8904563.00 |
06-20-2019, 12:13 AM | #5 |
Rep 1,523
not even close to fitting, shops these days have no moral value. All they want to do is move on their deadstock or make a quick sale and say too fucking bad to you after.
jimmy8904563.00 |
08-06-2019, 11:11 PM | #9 |
Rep 381
You want HRE you need 20x8.5 et30 20x10 et40 for your car. 235-35 275-30
2020 M550 bsm cognac 668 20's M-performance rear diffusor
