07-31-2019, 07:25 PM | #1 |
Rep 88
Run flat vs non run flat 20”
I have a 20” M 405 wheel package with run flats. Has anybody swapped out their 20” run flats for 20” non run flats? Was it worth the money? Was it appreciably quieter ? It is my wife’s car so performance Is measured by quiet..
Thanks for all opinions.
OVERDRAFT
1973 BMW 2002 Restomod 2022 Jaguar SVR 2018 Porsche GT3 Touring 2021 Porsche Targa 4S |
07-31-2019, 08:54 PM | #2 |
Rep 84
I swapped my 18" RFT for 20" non RFT and the difference was startling. Much softer and quieter. I thought all my rattles and squeaks were the norm cause I have a convertible. Really the problem was the RFT's. They suck.
08-02-2019, 04:08 AM | #3 | |
Rep 603
Much more quiet and much better handling. However, you need to have a emergency solution in case of a flat tire. I went for the BMW Mobility Set 71102333674. (never had to use it ) The only reason to go back to a RFT setup would be the "safety" of being able to drive a few miles with a flat tire. (No need to stop in the middle of nowhere. Especially when my wife has the car.)
335i F31 RWD in SB || Powertrain: Active Autowerke Flash Tune Stage 1 | AA Charge Pipe | AA FMIC | GFB DV+ | xHD Trans-Flash | Quaife LSD | Cyba 3.5" Carbon tips || Chassis: 20" 405M | Wiechers Strut Bar | Rear M-Diffusor || Brakes: 18" M-Perf Brake orange 370/345 | EBC YellowStuff pads all around || Various: LED bulbs: Fog-L. front | Turn Signal f&r | Brake L. | Reverse L. | Rear L. | Rear Fog L.
08-02-2019, 10:19 AM | #4 |
Rep 558
I don't understand how some can ride 20" with runflats. Risking chipped tooth.
Machinebuilder278.50 |
08-02-2019, 12:00 PM | #5 |
Rep 88
OK...you guys have me convinced...I will order a set of 20" Pilot Sport 4S...and put the run flats on the mart for sale. The tire guy says the slightly larger side wall will fill the gap a hair and maybe make the car look a little less on stilts which was bugging me too.
OVERDRAFT
