BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic and Lighting Modifications (exterior & interior) > LHD headlights on RHD car and driving... bad ideaż
      04-29-2024, 02:11 AM   #1
rusty_sojah
Drives: 440
since i can't find any LED IKON-Style LCI Headlights for BMW F32/F36/F80/F82 for RHD like I need I am now wondering how bad putting some US spec LHD headlights would be for night-time driving??
i'm thinking to pull up to my carport wall and chalk where my tires are and where my current light cutoff is, then after installing the LHD LCI LED lights try to get the light cutoff to the same points via the up/down and left/right adjustments on the headlights themselves. anyone have any advice or experience with this??
i'm not sure if the manual adjustments will be able to achieve the same cutoffs, but i'm hoping i can get really close to it so that the difference if fairly negligible.
      04-29-2024, 10:17 AM   #2
Oksamit78
Oksamit78's Avatar
Drives: E39, F30 & F34
The beams' cut-off is significantly different between two types.
Do have a read here:
https://f30.bimmerpost.com/forums/sh....php?t=1644906
First several posts do discuss the mechanical differences between LHD and RHD headlights. The construction principles are the same, although the post talks about F87 M2.
2003 E39 530i 5-Speed w/ M Spec, Saphire/Black, M54B30, Active Autowerke Performance Tune
2010 Lancer GTS 5-Speed, Black Pearl/Black, 4B12
2015 F30 335i XDrive w/ M Sport Pack, Alpine White/Black, N55B30M0
2017 F34 340i XDrive w/ M Sport Pack, Azure II /Black, B58B30M0, Dinan Stage 1
      04-29-2024, 04:04 PM   #3
rusty_sojah
Drives: 440
Thanks. Guess thats a no. I found a set for 3000 USD is the best i can find on the Euro RHD side. It seems there are significantly less aftermarket parts suppliers for bmw rhd stuff than the more common lhd. Unless i just need to know some other languages. I even changed my IP address to some of these countries and searched and got a few additional web results but couldn't find many parts shops selling aftermarket, just oem.
