08-18-2019, 10:55 PM | #1 |
Rep 34
Need some key help. Found it in the dishwasher
2016 F34 w/ comfort access.
So after searching for 2 days, I found my key in the dishwasher. Unfortunately we ran a load of dishes before we noticed it. After much drying and hot airflow, the remote buttons still do not work. However, the vehicle still starts when I hold the key to the ignition. Is there any series of steps I can do to get the remote to function to at least start the car normally with the comfort access, other than buying a $420 key from bmw? Thanks guys |
08-18-2019, 11:09 PM | #2 |
Rep 2,808
Drives: F33 430 and F39 M35i
Make it the spare and use your other one for comfort access?
Does everything inside look ok? New battery too? Clean your battery contacts inside the fob and try again? https://f30.bimmerpost.com/forums/sh....php?t=1455537 Last edited by chowser51; 08-18-2019 at 11:18 PM.. |
08-19-2019, 01:48 AM | #3 | |
Rep 10,473
Last thing to check. |
Medic-NY25.00 |
08-19-2019, 08:50 AM | #5 | |
Rep 165
08-19-2019, 09:05 AM | #6 |
Rep 2,808
$371 + tax for a new key with blade cut to your car. Order it from a dealer. Don't let them "program" it. You can sync it yourself. Never know when you need a spare.
But definitely try a new battery first. I think the key requires a certain voltage for NFC stuff. |
08-19-2019, 10:49 AM | #7 |
Rep 34
Put in a new battery, and surprisingly, it works!!
But yes, I'll be ordering an extra one soon! |
BeerHerder250.50 tex26702411.00 |
08-19-2019, 09:40 PM | #8 | |
Rep 10,473
Still not a bad idea to bury in white rice (not cooked) for several days to get all the excess moisture out. |
MmmmmM22586.00 |
08-19-2019, 09:56 PM | #9 | ||
Rep 1,827
2013 F30 335i RWD ZF Melbourne Red
~Remus Sport Axleback~VRSF Chargepipe~VRSF Catless Downpipe~GPlus FMIC~HR Sport Springs~Active Autowerke OBD Flash Tune Stage 2~ |
SportySpice204.00 |
08-20-2019, 12:24 AM | #10 | |
Luxury at the redline :)
9103
Rep 7,563
Impurities from dirty liquid or soda can cause the buttons to become stuck but it would not have any affect on the actual electronics within the remote. |
08-20-2019, 01:16 AM | #11 | ||
Rep 10,473
08-20-2019, 01:27 AM | #12 | |||
9103
Rep 7,563
Correct me if I'm wrong but I never heard or seen the innards of any keyfob rendered disabled due to oxidize corrosion build up.. |
08-20-2019, 02:08 AM | #13 | ||||
Rep 10,473
Guess you're the only one to never see battery corrosion on a battery and contacts. |
08-20-2019, 02:22 AM | #14 | |||||
9103
Rep 7,563
If the battery leaks and corrode the connectors, that has nothing to do with the engineering behind the remote, you're overreaching in an attempt to spike my claim. I win no prize if I'm right or wrong, just wanted to share what I know, as I would hope someone would of educate me, had I been oblivious. My whole point to this is the remote is designed to resist liquid. If it didn't, 1/2 the people here would need new key fobs, by now. Trust me, I tried to destroy one in the name of science and it would not budge; it's built Ford tough. |
SportySpice204.00 |
08-20-2019, 02:52 AM | #15 | ||||||
Rep 10,473
Just because the PCB is sealed, that DOES NOT mean all the moisture is out of the FOB itself. In fact, no matter how well the PCB is sealed, moisture from the other NON SEALED areas of the key fob will be attracted to the battery causing corrosion. That's why I stated that it should be put into white rice as a safety measure. And again, you must be the only person who's never seen a corroded battery leak. |
08-20-2019, 10:14 AM | #16 | ||||||
Rep 1,827
08-20-2019, 10:26 AM | #17 |
Rep 426
Why is nobody asking the real hard hitting question here... HOW did the fob end up in the dishwasher?
Glacier Silver Metallic 335i X-Drive - Can't leave well enough alone... Fabspeed DP, Wagner Evo Comp II IC, ER CP, BM3 Stage 2 93 OTS, Bimmertech Amp (more to come... always more) Graphite Metallic X3 (nothing yet, but... you know) |
08-20-2019, 11:05 AM | #18 |
Rep 2,432
Drives: 2021 M2C
BeerHerder250.50 |
08-20-2019, 11:25 AM | #19 |
Rep 1,641
BeerHerder250.50 |
08-20-2019, 01:12 PM | #20 | |
Rep 5,984
08-20-2019, 01:53 PM | #21 |
Rep 2,808
Yes they sell them without the blade but I thought he would want a complete key since he only has the one. I bought my car used and it had one key so I went and bought the complete key. Synched it myself. Wasn’t paying the dealer.
