08-19-2019, 02:33 AM | #1 |
Rep 10,473
As most know, BMWNA uses ATT for its communications data needs.
ATT has announced earlier this year its plan to discontinue its 3G Service in early 2022 to repurpose the frequencies for 4G/5G use. https://www.business.att.com/content...-messaging.pdf Many F3x BMW owners will remember what happened when ATT discontinued its 2G Service at the beginning of 2017. For reference, Apple first introduced 4G in the iPhone 5 which was released in the USA (and Worldwide) in the Fall of 2012. Likewise, BMW moved from CIC to NBT in the early ActiveHybrid 3 which was released about the same time. The NBT then replaced CIC in other 3/4 series cars with Navigation in the 2014 Model Year for the most part. And we all know BMW is certainly not as cutting edge as Apple. Looking at the TCB units, later units were described at 4G TCB, while earlier units have no band designation in their description. For several months I have tried to determine when 4G chips first went into the BMW TCB units. I've come up blank as most BMW related people either have no idea what I am asking about or have no idea of the significance. Does anyone know if the early TCB units have 4G service built in or when exactly were the 4G chips added to the TCB units? I am curious to know if we are about to see another group of BMW's lose Connected Drive/SOS/Traffic and other services in less than 30 months? EDIT: ALL NBT EVO units use ATM instead of TCB which has 4G Capability. F3x/F8x units started implementing NBT EVO/ATM in the 2016 Model Year (7/2015 Builds) providing the cars have Navigation. |
08-19-2019, 07:11 AM | #2 |
Rep 1,802
This is a great thought, because I was just researching this over the weekend. I know for sure mine is the 3G version.
I have been glancing around for the 4G version. RealOEM specifies which part number is the 4G TCB. Upgrading to a 4g TCB is easy, except with mismatched ICCID (SIM ID) and IMEI (hardware ID), you will lose remote services and some other connectivity. I can transfer the eSIM (hot air soldering), but IMEI is a bit harder.
08-19-2019, 10:06 AM | #3 |
Rep 1,802
09/2013 build 328d wagon, I see only 3G logo when using NBT to go online to see prices for services, etc. I don't have a 100% method to confirm that it doesn't go on 4G, but I can find out.
Any self swap with a used unit will require the ICCID and IMEI to be changed on the car. It's not just for TCB to ATM. BMW connected drive team stores the ICCID and IMEI connected to your car on their servers. If the numbers mismatch, you will lose at least remote services. When you buy a new one at the dealer, the connected drive department should receive your new ICCID and IMEI. If you simply swap in a used TCB (or ATM for that matter), your ICCID and IMEI will remain recorded as on the previous car, and some functions will not work. I've already gone through this when I swapped my original TCB with a used one of the same kind due to some damage, and I had to desolder the original eSIM (with hot air) and transfer it to replacement. This changed the reported ICCID. It wasn't enough to have remote services work, so I transferred the components that held the IMEI in as well. Then it restored all services as were originally intended. Changing to another TCB or ATM is no different. If doing it through dealer, then that may be ok, since they will update the info. I have a good friend at BMW HQ engineering dept and he confirms this exact info.
IK6SPEED4488.00 |
08-19-2019, 10:10 AM | #4 | ||||
Rep 10,473
First, if BMW "knows" you has a 3G TCB only, even if you have transplanted the SIM and IMEI into a new unit, there is no reason for BMW to maintain that account past the end of 2021 as their info is that you are on 3G which would not work at that time. Just telling them that they are incorrect probably will not get you anywhere as it will not match their info. And for clarification, I do not believe a Dealer can change from a TCB and ATM and make it work in the BMW System. Only TCB to TCB and ATM to ATM. Thanks for your response. |
08-19-2019, 10:16 AM | #5 |
Luxury at the redline :)
9105
Rep 7,563
Cars built 03/2015 and beyond all have 4G LTE, anything below that is 3G.
chowser512025.00 h1ghland3r0.00 |
08-19-2019, 10:25 AM | #7 | |
9105
Rep 7,563
https://www.press.bmwgroup.com/usa/a...language=en_US Anyone here with a 2015 F22 built in March or later? https://www.2addicts.com/forums/show....php?t=1143681 |
08-19-2019, 10:28 AM | #8 | ||
Rep 10,473
BMW implemented NBT EVO and ATM units in the F3x/F8x in cars WITH NAVIGATION in the beginning of the 2016 (7/2015) Model Year. Never a question about ATM units having 4G. |
08-19-2019, 10:33 AM | #9 | |||
9105
Rep 7,563
It was a big deal here, at the time, so if you do a search, you'll find more details on the specs. |
08-19-2019, 10:36 AM | #10 | ||||
Rep 10,473
08-19-2019, 10:39 AM | #11 |
Rep 1,802
My point is that if you do not go through the dealer, you will lose at least BMW Remote Services (app connection to car). So yes I agree with what you said, and that dealers do not do retrofits.
You may still retain features such as traffic info and whatever minor things there are left that you can do with the TCB system internet, but even some of those require custom hacks/coding once your module comes from a different car. Here is what a TCB 4G looks like on the label. I've only been able to find them from 2016 and newer. Maybe the 2015 ones just didn't specifically say 4G on them.
08-19-2019, 10:44 AM | #12 | |||||
9105
Rep 7,563
I don't know how else to convey this.. : |
08-19-2019, 10:47 AM | #13 | |
Rep 1,802
I will see if my friend can get a bit more info from the guys at connected drive.
IK6SPEED4488.00 |
08-19-2019, 10:52 AM | #14 | ||||||
Rep 10,473
We know that RealOEM lists a specific 4G TCB with a date starting 3/2015. As stated previously, the earlier TCBs (of which there were several) did not have any spec in the description. As seen many times with realoem, that does not necessarily mean that a previous unit does not have the capability....only a slightly different descriptor for the new part number. As the older part numbers extend past 3/2015, that also does not mean that all BMWs received the new part number on that date. |
08-19-2019, 10:56 AM | #15 | ||
Rep 10,473
But in your case, where you modified..... How did you obtain Connected Drive until 2024? Isn't it annual after the initial Factory Period? |
08-19-2019, 11:00 AM | #16 | |||||||
9105
Rep 7,563
08-19-2019, 11:10 AM | #17 | ||||||||
Rep 10,473
You also assumed in May that the MPerformance LSD would NOT work on XDrive, despite the FACTS I posted and your assumptions were proven incorrect after XDrive users lost their chance to purchase the unit at a deep discount. Made this thread to get facts, not assumptions. While your assumptions may eventually turn out correct, I am looking for facts. Last edited by IK6SPEED; 10-29-2019 at 06:28 PM.. |
08-19-2019, 11:13 AM | #18 | |||||||||
9105
Rep 7,563
Believe what you want.. |
Wires1645.50 |
08-19-2019, 11:14 AM | #19 | ||||||||||
Rep 10,473
I am trying to verify. |
08-19-2019, 04:22 PM | #21 |
Rep 10,473
08-19-2019, 07:52 PM | #22 |
Rep 4,876
If you really want to find out, go to your dealer and have them run your VIN. Heck, call the connected services number and ask them. They won't be able to renew if the hardware doesn't support the service.
There was a thread a year ago when this got announced that and if I remember correctly, you received a letter stating the EOL for connected services for your car if you were a subscriber. You might have to go past being an arm-chair quarterback on this one if you're not going to believe what anyone else is telling you..... |
Poochie9104.50 |
