BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Voice Command stopped working, after coding.
      12-24-2017, 04:59 PM   #1
PLuKE
Drives: n/a
I bought a V-Link dongle and Bimmercode.
I have followed some of the steps for coding in EBT, and the popular features. Which have all mostly worked! So that’s for peoples input.
I have however lost my Voice Command on the steering wheel, I think when I coded in Office. I have checked the CE Device Speech Recognition is “active”
Any ideas?
      02-04-2018, 07:14 AM   #2
bacanski
bacanski's Avatar
Drives: F30 320i M
Any progress? I noticed that long press is wotking but short dead.
      02-04-2018, 03:49 PM   #3
PLuKE
Drives: n/a
I haven't no.
I did send an message to the support team of Bimmercode, but they said that there not sure which setting has caused this.
I did do some searching and looked at the settings and mine as all active, so unsure!
Thanks
Luke
      02-04-2018, 03:53 PM   #4
bacanski
bacanski's Avatar
Drives: F30 320i M
I have contacted Stephan from bimmercode same result.
Have found 2 option that should be active, changed them...
Still dosn't work.
I think ill have to change to stock (dont know yet how) and do it again by esys...
      11-03-2018, 02:26 AM   #5
PLuKE
Drives: n/a
Hi,
Can anybody else add to this?
Thanks
      02-23-2021, 06:00 AM   #6
scunner
Drives: BMW f36
Hi I have the same problem I've reset the module but with no joy and bimmercode support are as much use as a chocolate tea pot.
There reply was well if you have done a reset and it's still not working its not the programming look on the Internet for a solution.
There is obviously a problem with the coding as there are quite a few people with the same issue after programming with bimmercode.
      02-23-2021, 05:26 PM   #7
Wires
Drives: 2016 340i xDrive
Ok, I've never used Bimmercode to code my car, but here is the notes I took off the forum when I used ISTA to code office into my car. I'd check if they are all "acktiv" after Bimmercode.
SINGLE_OR_MULTILINK werte = 01
Rest all aktiv:
CONTACT_BOOK_PICTURES
BLUETOOTH_2ND_HFP
MACRO_PIM
PIM_SPEECH_TO_TEXT
PIM_NEW_ELEMENT_VOICE_EMAIL
PIM_BILDER_EIN_AUS
CALENDAR_EIN_AUS
TASK_EIN_AUS
REMINDER_EIN_AUS
TEXT_NOTES_EIN_AUS
AUDIO_NOTES_EIN_AUS
SMS_EIN_AUS
EMAIL_EIN_AUS
PIM_NEW_ELEMENT_EMAIL
PIM_NEW_ELEMENT_SMS
PIM_NEW_ELEMENT_AUDIO_NOTE
      03-02-2021, 05:39 AM   #8
WHLew
Drives: BMW 330D X-Drive
I had the same issue when following instructions to code EBT on here. I got over it by changing the following two which were shown as nicht_aktiv in the instruction i followed (as below) to Aktiv.
HU_NBT > HMI 3000 > SVS = nicht_aktiv [Default]
HU_NBT > HMI 3000 > SYSTEM_TTS = nicht_aktiv [Default]
I also had CE Speech Recognition as Aktiv.
Hope this helps.
      03-18-2021, 07:30 AM   #9
scunner
Drives: BMW f36
Thanks for the help I tried the larger settings but no change, when I changed SVS to aktiv i now get voice will be available shortly but does not start
any other ideas?
Thanks
