BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Coding Speed Limit Info
      09-03-2021, 02:47 PM   #133
Neil420gc
Drives: 420d gran coupe
Great info cheers
If it makes you happy own it
      09-05-2021, 05:41 AM   #134
andikarre
Drives: F31
How can I coding the Speed Limit Info?
      09-05-2021, 05:42 AM   #135
andikarre
Drives: F31
And what Camera do I need?
      09-06-2021, 01:50 AM   #136
Dang3r
Schmollbraten
Dang3r's Avatar
Drives: M4CPC // HP4 Comp.
Read the thread, dude, plenty of infos are listed here
Question solved by reading the thread!
Citizen of ///M - Town, where too much is just right
Some say, that my scrotum has its own small gravity field and when Im slowing down that brake lights come on at my buttox
      09-09-2021, 05:33 PM   #137
ashm1420
ashm1420's Avatar
Drives: Bmw 330e
Originally Posted by greb View Post
Yes, so if anyone needs any FSC codes please let me know!
I know it’s an old post, any chance I could get the code? F30 2017 330e.
      09-19-2021, 09:56 AM   #138
SPMR
Drives: BMW X3 2021 LCI
Hi Folks, long time follower here. I’ve recently brought a BMW 5 Series Touring 520D 2021 (G31) and wondered if anyone could help me in activating the SLI on it? I would be ever so grateful - thank you in advance.
      11-06-2021, 07:44 PM   #139
AlirezaTaghizadeh
Drives: f10
I have the KAFAS camera already and driving assistent but no speed limit info. I already tried to order the FSC code through the dealer, but every time they say that Munich will check if it's compatible with your car and then they will or not send me the FSC code. But the option isn't on the list, so I ain't getting any FSC code.
Is there some other ways to get this code? I know it's easy to code this with E-Sys.
Thanks!
can u please send me the instructions to buy the Fsc code
      11-09-2021, 06:27 AM   #140
ceramicax
Spain
Drives: BMW X6
Yes please. PM me
      11-19-2021, 04:34 AM   #141
hajar
Drives: BMW X3 F25
I just wanted to share my experience of coding SLI with BimmerTech here. Definitely don't use their service. They charge significantly more than some people recommended by Shawn. But thats not the worst part. The worst part is that they don't get you an OEM FSC code. Instead they code some fake generated FSC code and then somehow make it accepted. It works just fine, but only until your next trip to BMW service. As soon as you go there or you do errors reset in ISTA yourself that fake FSC gets rejected and you have to pay BimmerTech to code fix again, which lasts only until your next trip to BMW.
So from personal experience:
1)I don't recommend to use BimmerTech, its expensive and short lived
2)When you code SLI make sure you get an OEM FSC for the VIN of your car if you don't want it to get rejected by your car in future and you having to fix it via another coding session again.
      12-06-2021, 02:50 AM   #142
StofDD
Belgium
Drives: Bmw F15
@Greg Could you still help me to get the FSC code. My dealer doesn't seem to know how to order the code.
Thanks!
      12-07-2021, 06:04 AM   #143
Siki78
Siki78's Avatar
136
Drives: F30,G30
@StofDD
I can help you too first time when you reach 4 post because I can`t send you PM
Successfully retrofit on BMW F30 335xi 248,302,3AG,430,5AG,5AS,6NS,8TH and IHKA3
      05-05-2022, 03:07 AM   #144
5aa7mg
Drives: bmw
sli code
Thanks!
hi
sent me sli code
      05-06-2022, 03:28 PM   #145
Rale92
Drives: BMW F36 428i XDrive
FSC code for Speed limit info
Hello everyone,
Can somebody please help me with ordering of Original FSC code to unlock 8TH (SLI)?
I already have KAFAS2 in my car.
If there is someone who can help me with this topic, please write me PM, or leave me you contact.
Thanks in advance! 🤝
      05-24-2022, 08:38 AM   #146
Wojti_
Drives: BMW F11, G30
Originally Posted by Rale92 View Post
Hello everyone,
PM sent
      06-01-2022, 01:53 PM   #147
blackcat06
Drives: BMW 330e F30
Originally Posted by daMANiack View Post
Hi,
Just to be sure, I went through the process of deleting 8TH first then coding the HU_NBT2, KAFAS2 and KOMBI ECU’s. After doing this, I checked HUD and Main Display (Kombi) settings through iDrive menu and all SLI options had been removed.
1. I then added 8TH to FA, then coded HU_NBT2, KAFAS2 and KOMBI ECU’s and checked HUD and Main Display (Kombi) settings through iDrive menu and all SLI options were there.
2. I then selected the certificate file in Options –> Settings –> FSC tab –> Certificate field. Loaded FSC Code Certificate file (xxxxxxx_007E0001.der)
3. In Comfort –> FSC tab and browsed to the FSC file (xxxxxxx_007E0001.fsc)
4. In FA Field, Read FA
Entered the following:
Diagnostic Address (hex) = 0x5D
Application Number (dec) = 0x7E
Base Variant = KAFAS2
Upgrade Index = 0x01
5. Select "Upgrade FSC" to Import and Activate FSC Code. NOTE: I tried WRITE as well
6. Select "Check FSC Status", and I get:
--> Read the state from "1" ECU(s) <--
KAFAS2[DiagAddress=93(0x5D)]
WBAXX52060xxxxxxx
RootCertStatus not available
SWSigStatus accepted
SWTApplications
AppID 126(0x7E)
UpgradeIndex 1(0x01)
SWTType SWTclassic light
FSCStatus accepted
FSCCertStatus not available
AppID 190(0xBE)
FSCStatus accepted
AppID 191(0xBF)
FSCStatus accepted
It doesn’t seem to be accepting the certificate file.
Any ideas greatly appreciated seeing you got yours working that you purchased through greb and living in Australia?
Kind regards, Ken
Hi Ken,
I’m from NZ and would like to get 8TH on my 2016 F30 as well.
If you inject the FSC with esys and get everything else working would BMW be able to recognise the car has been retrofitted with 8TH or will their computer wipe out the settings and FSC if you went in for a service?
Thanks
      06-01-2022, 06:04 PM   #148
daMANiack
daMANiack's Avatar
Australia
Drives: BMW F26 X4 35d
Hi,
My SLI I installed using the FSC files has been working for 3 1/2 years and it has been into BMW Adelaide numerous times for services and vehicle inspection and SLI is still working.
Now, BMW haven't had to program or software update my BMW so I don't know if the SLI would be removed as it wasn't standard.
My wife's F48 X1 had to have a rear DRL LED light replaced and her car was coded and it did loose the coding for the SLI emulator and others but I don't think I had to go through the whole process again, just enable SLI with some e-sys coding.
To get my 2016 F26 to see and use the FSC files and enable SLI via cameras, I did have to update the firmware of the KAFAS2 ECU.
Cheerz
Originally Posted by blackcat06 View Post
Hi Ken,
Thanks
2016 BMW F26 X4 35d, H&R spring lowered 30mm, QUAD exhausts
      06-07-2022, 04:56 AM   #149
blackcat06
Hi,
Cheerz
Thanks,
That’s really helpful information. I will try coding SLI on to my car then, I also have the SLI emulator installed at the moment, but would like the actual BMW option better.
Cheers
      06-09-2022, 10:57 PM   #150
blackcat06
Hi,
I purchased the FSC SLI files from greb and had the same thing, updated KAFAS2 and KOMBI Ecu's and could only get the round circle with 3 ---.
After investing with greb, I was advised that I needed to update the Kafas2 ECU firmware, I got the v.4.14.14_PSdZData_Full files from ShawnSheridan and now get the SLI round circle with speed detected from navigation maps that is updated when Kafas2 camera reads a speed sign.
My vehicle is a 2016 F26 X4 35d and I live in Australia.
Cheerz
Hi daMANiack,
When you added the FA did you write FA to FP or read FA to FP?
I saw somewhere where shawnsheridan advised that if we want the dealership to be able to see the added FA when they are working on the car then 8TH will need to be written to the car or else the entered FSC may get deregistered or something?
      06-11-2022, 02:02 PM   #151
antsh
Drives: BMW F15 + E46
I need FSC code for SLI, who is selling those nowadays?
      06-14-2022, 03:46 AM   #152
Wojti_
PM vin, I can help
      06-23-2022, 07:47 AM   #153
Am1nHaq
Drives: BMW M4
Hi there, also looking to get a FSC for my 2018 M4. I have KAFAS2 already due to having the lane change warning system option.
I am UK based.
      07-04-2022, 05:07 AM   #154
gru
Drives: BMW G30
Hey Wojti_ can you PM me please - I'm not able to as just recently registered to the forum. I have a G30 I'm looking to get the SLI FSC for
Cheers
coding, esys, kafas, speedlimitinfo
