09-21-2021, 11:45 AM | #23 | |
Rep 7,591
09-21-2021, 12:17 PM | #24 | |
Rep 2,639
09-22-2021, 09:22 AM | #25 | ||
Rep 190,597
CTS is very similar to MST I remember the 2 companies getting into a back and forth argument on Instagram about this
09-22-2021, 11:24 AM | #26 |
Rep 7,591
09-23-2021, 06:37 PM | #28 |
Rep 7,591
09-23-2021, 09:01 PM | #30 |
1296
Rep 3,529
so which inlet has the largest inside diameter?
09-24-2021, 12:39 AM | #31 |
Rep 7,591
Seems to be nearly identical to MST v2. I just looked back at my album and its 2.2225 in ID.
View post on imgur.com |
09-24-2021, 07:02 AM | #32 | |
1296
Rep 3,529
09-24-2021, 01:44 PM | #33 |
Rep 7,591
Yes, you would need to dig back through this thread to find the measurements. I only had OEM and MST v2 in my photo album since those are the ones i owned. https://f30.bimmerpost.com/forums/sh...1656337&page=8
I would say the MST is also a better overall design that pure for airflow, and the bench testing from VW (different platform, same idea) essentially proved this point. |
09-24-2021, 06:56 PM | #34 |
Rep 764
Keep in mind I used a very old school Vernier caliper. It requires skill and patience to read properly...Neither of which I have :-) It is at a minimum 2.21. The caliper was a bit loose inside, it's quite possible 2.2225 to be correct here as well. But that small a margin, you aren't losing out on anything.
I installed it today. It was a bit more a pain in the ass than I had anticipated. It's much easier to do some of the work from the bottom. |
09-24-2021, 07:38 PM | #35 | |
Rep 7,591
Driving impressions? |
09-25-2021, 04:38 AM | #36 | |
Rep 764
Driving impressions, honestly I didn't really crank into it yet. The day before I blew the charge pipe (22k on stage 2 93, 21psi spikes! unbelievable!) so I've been going easy on it for now. This weekend I'll get into it a bit more. |
09-25-2021, 11:53 AM | #37 | |
Rep 2,639
I could tell I lost a bit of turbo spool noises as going from aluminium inlet to silicon will kill some sound, but overall WGDC is nice, it's sitting around 55-60 on WOT at 16psi. Pretty sure they're identical if you put them side by side, but for sure the MST and CTS inlets are bigger than pures inlet.
09-25-2021, 01:23 PM | #38 | |
Rep 7,591
03-15-2022, 01:46 PM | #39 | |
Rep 488
Please can you let me know which fittings you thought were better quality? Was it the CTS or MST? I am just about to buy one of these - do you still rate your CTS? Thanks. |
03-15-2022, 05:28 PM | #41 |
Rep 190,597
same
03-15-2022, 05:53 PM | #42 |
Rep 369
03-15-2022, 07:26 PM | #43 | |
Rep 190,597
