10-11-2018, 10:43 AM | #353 |
Rep 2,382
Punch it. But yeah, if it was in the 50s, you should have been lower.
2013 F30 328i: MHI Big Turbo, GFB DV+, Mishimoto CAI, ER TIC/CP/Catless DP, AWE Touring Quad Exhaust w/ Resonated Midpipe, NGK LI Plugs, BM3 with PTF Stage 2 91 AGG Tune, Fuel-it Stage 2 LPFP, Solowerks S1 Coilovers, and DEPO/M-Sport Retrofit |
10-11-2018, 11:04 AM | #354 |
Rep 3,679
10-11-2018, 12:58 PM | #355 |
Rep 482
Drives: 2014 Glacier Silver F30 328i
Swung by the garage that did my install. He wants me to send him the logs so he can take a look. Most likely a smoke test will be scheduled.
Ran 5 new logs on the way home Stage 2 Test 2 Tune: http://www.bootmod3.net/log?id=5bbf8c46d10b434f3ca85d41 http://www.bootmod3.net/log?id=5bbf8c48d10b434f3ca85d43 http://www.bootmod3.net/log?id=5bbf8c47d10b434f3ca85d42 http://www.bootmod3.net/log?id=5bbf8c44d10b434f3ca85d40 http://www.bootmod3.net/log?id=5bbf8c48d10b434f3ca85d43
2014 GLACIER SILVER F30 328i * Wheels:18" VMR V801 Titanium Black Shadow * Springs: DINAN 1" Lowering Springs * Tune: BM3 OTS E30/93 OCT * Engine: Evolution Racewerks Catless DP/CP/FMIC * Intake: AWE S-Flo Carbon Fiber Intake * Exhaust: AWE Exhaust Suite + Mid Pipe * Go Fast Bits DV+ Diverter Valve * Plugs: NGK LI Plugs * Lights: Depo Angel Eyes W/ Morimoto HID's * Hood: Seibon Carbon Fiber Hood
10-11-2018, 01:39 PM | #356 | |
Rep 3,679
That being said though, those logs do look a bit better, looking just at boost deviation without the actual boost target being shown. Before your peak boost deviation was about 6psi consistently, now it's down to about 5psi consistently. 5psi below target is still too large and still indicative of an issue, but at least it's better. Perhaps PTF maximized the amount of boost you're able to generate with whatever mechanical issue you've got with their test maps.
10-11-2018, 01:46 PM | #357 | |
Rep 482
10-11-2018, 01:54 PM | #358 | |
Rep 482
I may not be able to grab new logs this evening as the rain has moved in. If we get a small window where it lets up I'll try to sneak a few runs in. If not I'll have to wait until tomorrow. Last edited by fate_f30; 10-11-2018 at 02:19 PM.. |
10-11-2018, 02:58 PM | #359 | |
Rep 3,679
Don't worry if you can't get them tonight. It's no pressing matter, as your car's not in danger or anything, just being annoying lol
10-11-2018, 03:47 PM | #360 | |
Rep 482
http://www.bootmod3.net/log?id=5bbfb5f4d10b434f3ca85db6 http://www.bootmod3.net/log?id=5bbfb5f4d10b434f3ca85db5 - I think this one looks better but the boost maybe too high?
rjd_F301999.50 |
10-11-2018, 04:00 PM | #361 | |
Rep 3,679
The boost discrepancy looks about the same as the last logs aka still not making enough, but at least now we can see the target. And yah 36psi!? They really put it on kill with these test maps... lol, it's measuring absolute pressure rather than relative. I've made the exact same mistake before . In other words, it's combining ambient pressure with boost pressure to give you that number. If you subtract ambient pressure from those numbers, you'll see the actual boost pressure/target/MAP psi etc. If the car actually made 36psi (if the turbo could do it which it can't) it would've died and thrown a rod into the stratosphere while it was at it. In the same settings that you adjust what is logged and what isn't you can change from absolute to relative pressure. Ya must've switched it on accident
10-11-2018, 04:03 PM | #362 | |
Rep 482
10-11-2018, 04:05 PM | #363 |
Rep 3,679
I don't think they could do anything with them, it's out of their hands and it's very likely that the issue is being caused by a mechanical issue with your car, likely a boost leak. The only way to fix it at this point is to get a smoke test, find the leak, and fix it.
10-11-2018, 04:10 PM | #364 | |
Rep 482
10-11-2018, 05:18 PM | #365 |
Rep 3,679
It must've recorded in absolute then for some reason, that's weird. If you do the math, subtracting the ambient pressure from the target, you'll get 22.49, which is exactly right. If the car made 32psi of boost it wouldn't have made it home. Also, I don't think the stock turbo couldn't generate that amount of boost anyway. Try going to the about page, and hit reset settings. After that, go back into log settings and make sure it's on relative and try again.
This little anecdote aside, we're still at the same place: you've probably got a boost leak and need a smoke test done.
10-11-2018, 05:23 PM | #366 | |
Rep 482
Speaks the statement that you've been saying all along. I won't be able to get a smoke test until next week. Hopefully I'll get some answers then. I'll keep you posted.
10-11-2018, 05:39 PM | #367 | |
Rep 3,679
10-11-2018, 06:50 PM | #368 |
Rep 482
10-11-2018, 06:56 PM | #369 |
Rep 3,679
10-11-2018, 06:58 PM | #370 |
Rep 482
10-11-2018, 08:52 PM | #371 |
Rep 325
Drives: 2016 F36
It's easy for me to say, but don't sweat it. Like you said early...car is running strong. You just have this little glitch of a boost leak somewhere. You'll get it figured out. I know it's frustrating and will be on your mind until it's resolved, but at least you don't have a blown turbo or tranny that will take her out of commission and cost thousands.
◊ 2016 F36 xDrive N26 ◊ Black Sapphire Metallic ⁞ Dakota Black ◊
║ VRSF HD FMIC ║ ER DP custom paint ║ AWE cat back Exhaust Suite ║ NGK Plugs ║Bootmod3 Stage 1 93 ║ GFB DV+ ║ BMS 10mm Front ⁞ 12mm Rear Spacers ║ P Style BSM Rear Spoiler ║ Smoked Front Reflectors ║ Madico Onyx 20 Tint ║ LCI Lighted Trim Bezel ║ Opti-Coat Pro+ ║ |
10-11-2018, 09:48 PM | #372 | |
Rep 482
10-13-2018, 08:20 AM | #373 | |
Rep 482
Bunker: Can you post the link where you took this screen shot of my data log you used in this example? My mechanic would like to see it. On another note. I scheduled a smoke test on Wednesday and I got a reply back from PTF "Could be the diverter valve starting to fail, but it keeps boost pretty OK at 5000RPM. I don't think it's a boost leak, if it should it's very small." Strange because the DV valve is brand new. Talking with a few other people they said the diaphragm could be dried out or not seated correctly. We'll look closely at that during the smoke test. I'll keep everyone posted. The plot thickens....
rjd_F301999.50 |
10-13-2018, 09:11 AM | #374 | |
Rep 3,679
