10-13-2018, 09:49 AM | #375 | |
Rep 482
Drives: 2014 Glacier Silver F30 328i
http://www.bootmod3.net/log?id=5bc165a9d10b434f3ca8631d http://www.bootmod3.net/log?id=5bc165aad10b434f3ca8631e http://www.bootmod3.net/log?id=5bc165abd10b434f3ca8631f Looks like I'm still dropping a lot when shift changing... If it's the DV Valve I'm not to worried as those are pretty easy to get a hold of and not to costly. I guess we'll have to wait until Wednesday. Until then...
2014 GLACIER SILVER F30 328i * Wheels:18" VMR V801 Titanium Black Shadow * Springs: DINAN 1" Lowering Springs * Tune: BM3 OTS E30/93 OCT * Engine: Evolution Racewerks Catless DP/CP/FMIC * Intake: AWE S-Flo Carbon Fiber Intake * Exhaust: AWE Exhaust Suite + Mid Pipe * Go Fast Bits DV+ Diverter Valve * Plugs: NGK LI Plugs * Lights: Depo Angel Eyes W/ Morimoto HID's * Hood: Seibon Carbon Fiber Hood
10-13-2018, 10:19 AM | #376 | |
Rep 3,680
10-15-2018, 09:06 AM | #377 | |
Rep 2,382
That's your log from the photo.
2013 F30 328i: MHI Big Turbo, GFB DV+, Mishimoto CAI, ER TIC/CP/Catless DP, AWE Touring Quad Exhaust w/ Resonated Midpipe, NGK LI Plugs, BM3 with PTF Stage 2 91 AGG Tune, Fuel-it Stage 2 LPFP, Solowerks S1 Coilovers, and DEPO/M-Sport Retrofit |
10-16-2018, 05:00 PM | #378 |
Rep 482
Just curious did either one of you use the Main Piston Spring or leave it out on your DV Valve? I'm scheduled for the smoke test tomorrow morning and we were considering pulling the DV valve out and checking it. I also picked up a 2nd DV valve if it looks like this one failed.
10-16-2018, 05:27 PM | #379 | |
Rep 2,382
10-16-2018, 05:59 PM | #380 |
Rep 482
Just so we're correct. The circled spring in the photo is what you're talking about? The provided "main spring".
10-16-2018, 07:03 PM | #381 | |
Rep 5,456
Drives: F30
We all decided to use it. Technically, you can operate without it and your DV will act as an OEM unit. |
10-16-2018, 07:59 PM | #382 | |
Rep 3,680
10-17-2018, 10:14 AM | #383 |
Rep 482
Found the boost leak! Smoke test found it within 5 mins. Looks like when my chargepipe was installed the gasket was seated incorrectly near the throttle body and stretched a little. Just to be safe we changed out the gasket and we’ll be buttoning things up in a few minutes. Resmoked it and the leak was fixed. Hopefully this solves the problem. I’ll run some new logs when I get home this evening. 😀
10-17-2018, 10:22 AM | #384 | |
Rep 2,382
10-17-2018, 10:29 AM | #385 |
Rep 482
10-17-2018, 11:16 AM | #386 | |
Rep 3,680
10-17-2018, 12:22 PM | #387 |
Rep 482
Thank you! Thank you! I'm sure you'll all be glad to not hear about my ride anymore...LOL It's been a long 2 months of diagnosing. After the fix, we ran some quick logs and the only thing we see is target boost may be set too high. It's showing 28psi of boost but we're not sure if that's the DME learning now that the boost leak is fixed or something that PTF made in the adjustments in the tune to over compensate for the loss in boost. I'm going to run some new logs this evening on the current tune to see where I stand now.
10-17-2018, 12:33 PM | #388 |
Rep 2,382
Yup! I've yet to try it out but I'll probably migrate over eventually. It's a pain to keep an E30 mix all the time but worst comes to worse, I have my agent in my car and can swap in 30 sec.
10-17-2018, 01:50 PM | #389 | |
Rep 3,680
At this point, I would just try the normal OTS Stage 2 map and take some logs and post 'em up. Since the problem is fixed, it should take well to the OTS map.
10-17-2018, 02:46 PM | #390 |
Rep 482
That’s actually the same thing the kid said today after he fixed my boost leak. Go back to the OTS map and see what happens.
10-17-2018, 03:37 PM | #391 | |
Rep 2,382
http://www.bootmod3.net/log?id=5bc79343d10b434f3ca8722c
10-17-2018, 03:44 PM | #392 | |
Rep 3,680
How's it feel on E30?
10-17-2018, 04:03 PM | #393 |
Rep 2,382
Amazing. I only got to do one pull but oh man, she kicked hard.
10-17-2018, 04:52 PM | #394 |
Rep 3,680
Damn, that nice huh? That's cool to hear. So is it an OTS map? I don't see it...
10-17-2018, 06:04 PM | #395 |
Rep 482
Yes, OTS MAP
10-17-2018, 06:12 PM | #396 | |
Rep 482
I flashed back to the Stage 2 OTS 93oct map and ran some logs. http://www.bootmod3.net/log?id=5bc7bbc2d10b434f3ca87309 http://www.bootmod3.net/log?id=5bc7bbc2d10b434f3ca87308 http://www.bootmod3.net/log?id=5bc7bbc1d10b434f3ca87307 Looks like to much boost deviation coming out of 3rd gear and going into 4th but 5th gear looks pretty good. Not sure if that's something PTF can tweak in the tune? Most likely? Take a look at Ignition timing 3 (deg) it seems to be running a lot lower than the other 3 points. Not sure if that's normal? You can follow along pretty clear in this log: http://www.bootmod3.net/www/index.html#/drawer/logs
