BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > M performance suspension fit on 340i sportline?
      02-11-2018, 09:42 AM   #1
wrk.eat.drive.rpt
Drives: 2016 340i, 08 e92 m3
I’m in the mist of a full blown m performance makeover and I’m getting all kinds of confusion from dealers, web and forums on whether the m performance suspension fits on the 340i or not. Anyone know definitely?
Thanks !!
      02-11-2018, 10:56 AM   #2
Jim E.
Jim E.'s Avatar
92
Drives: Individ: 99 M3, 11 X5d, 16 F31
Thanks !!
This should be your kit: http://www.realoem.com/bmw/enUS/show...diagId=03_3994
Easier if I have the last 7 of your vin.
You will also need to replace your sway bars. I recommend going with H&R rather than the factory m sport ones.
More info attached.
      02-11-2018, 11:44 AM   #3
wrk.eat.drive.rpt
Thank Jim!! IVin: na92734
I saw that kit but for some reason it popped up as the kit for the f32 430/440..
      02-11-2018, 11:47 AM   #4
wrk.eat.drive.rpt
Do some reason when I put that part number from real Oem into getbmeparts it shows 4 series https://www.getbmwparts.com/partloca...catalogid=4462
      02-11-2018, 12:20 PM   #5
Jim E.
Jim E.'s Avatar
92
OK that's the correct kit - the one I posted.
It is a retrofit for many different models. http://www.realoem.com/bmw/enUS/part...&q=33502409928
Sway bar kit here: https://www.tirerack.com/suspension/...kg+Non-Runflat
http://www.hrsprings.com/application...s/4/1776/2016/
Kit number 72878-5
You will also need the following springs plus pads.
FRONT: 31 33 6 860 631
Upper spring pad 31 30 6 791 712
Lower spring pad 31 33 6 787 114
REAR: 33 53 6 860 622
Upper sprint pad 33 53 6 764 419
Lower spring pad 33 53 6 791 709
Good luck.
      02-12-2018, 03:38 PM   #6
wrk.eat.drive.rpt
So I just got a quote from a local reputable Bmw mechanic shop in OC (bullet- in case anyone knows)
They quoted me the following to install the full M performance suspension kit with front and rear sway bars (which are required if you don’t have a m sport 340i)
Does $1310 sound reasonable !??
Breakdown
$ 750- spring/struts and the front sway bar
$ 400- rear sway bar
$160 - for the alignment
      02-12-2018, 06:48 PM   #7
MacklinUSOB
Drives: f30 328i 6MT Sport
Breakdown
This really depends on where you live. For reference, I live in CT and I got several quotes to install just coilovers and align (no sway bars) between $800-1000 OTD. That job I was quoted 6.5 labor hours by every shop independently (kind of uncanny). The sway bars do require the subframe to be dropped for install to an F30, I haven't been quoted, but a three hour labor charge makes sense. Alignment looks pretty standard.
328i RWD | MW on CRed Slick Top | 6MT | BM3 | MPE | GPlus FMIC | CSF Radiator | Millway Street Camber Plates & Monoballs | KW V2 6k/18k Swift Springs | F80 LCA/TS | SPL Bump Steer Kit | APEX SM-10 | R-S4 | DS2500 | RBF600 | SS Lines |
Past: E36 328is & E38 740i
      02-12-2018, 06:54 PM   #8
cfm56d7b
Breakdown
Nice to see another OC forum member. PM me for a recommendation of a shop that I know very well. They do great work.
      02-12-2018, 08:31 PM   #9
wrk.eat.drive.rpt
appreciate all the help. Man I was really hoping to do this for less than $800-$900 but the whole dropping the subframe just to swap out sway bars is really destroying the pros of installing this suspension.. ugh. $1900 for the kit and $1300 to install doesn't feel right.
      11-09-2018, 02:46 PM   #10
3SeriesDriver
Drives: 2013 335i Mineral Grey
Can someone please explain to me, why is it necessary to install the sway bars for this suspension install for a non-M (sportline) F30?
340i m performace
