10-16-2018, 07:13 PM | #1 |
Rep 51
Do I need an Alignment or something else?
Hello,
I got my F30's tires rotated this weekend and the guy at the tire shop showed me 3 out of the 4 tires wearing on the onside. I've had the car for almost 18 months and this was the second rotation I've done on it. The first rotation I did it myself but did not checked for this type of wear since it was dark. The guy at the tires shop say he sees that often on BMWs. Have you guys seen this on your cars and would an alignment do the trick? Thanks |
10-16-2018, 08:19 PM | #3 |
Rep 3,535
BMWs tend to have excessive negative camber in the rear. An alignment can help that, however since the excessive negative camber is in spec, you'll have to specify (and get them to agree to) a more reasonable number (like -1deg). If you just have them align it to spec, then you might end up with the same as before...
10-16-2018, 09:07 PM | #4 |
Rep 16,054
It looks like a camber issue, but if there's any cupping the toe is bad too. You can reduce the wear on the inside of the tire by adding a couple more pounds of air pressure, shifting the load bearing more towards the middle of the tires.
10-16-2018, 09:15 PM | #5 | |
Rep 26
328i spec:https://www.newtis.info/tisv2/a/en/f...ement/Ht47pkMD HTML Code:
https://www.newtis.info/tisv2/a/en/f30-328i-lim/repair-manuals/32-steering-wheel-alignment/32-00-steering-measurement/Ht47pkMD HTML Code:
https://www.newtis.info/tisv2/a/en/f30-328i-xdrive-lim/repair-manuals/32-steering-wheel-alignment/32-00-steering-measurement/Ht3ZC466 |
10-16-2018, 10:41 PM | #6 | |
Rep 3,535
11-09-2018, 12:27 AM | #7 | ||||
Rep 51
Thanks a lot for the info. I'll look around for a local shop in San Diego that will be able to adjust the camber a little bit more than the bmw says. Any of you know a good shop in the San Diego area? |
11-09-2018, 06:56 AM | #8 |
Cheapskate
4445
Rep 4,993
Just keep in mind the camber is for your safety. The more you reduce the rear camber, the easier the car is to rotate and makes the rear more lively. Measure the grooves left to right to see how much camber wear you're actually getting. If the outside is similar, then i personally would leave the camber as is. From the picture, it doesn't seem like you have that much life on the outside either.
