04-30-2019, 02:11 AM | #353 |
Rep 55
It's Sygic. I managed to get on the beta last year so it didn't cost anything. The realtime traffic updates are really accurate (I think it uses data from TomTom). I think they've overpriced it for general users - shouldn't charge at all for the CarPlay feature IMO.
ooshnoo880.50 |
04-30-2019, 10:33 AM | #354 |
Rep 560
Installed the Unique-AD wireless solution last Friday and had 4 days testing
It's installed on my F30 with pro nav and i've used wired and wireless Currently using wireless now and had a few problems getting both the BT paired ( Idrive and Carplay ) They appear to have delayed the WiFi sync which allows the iPhone to pair with idrive BT first. Then it detects the Carplay unit via WiFi and then fires up Carplay So currently able to use Carplay audio and BT idrive for telephone. When using the telephone in Carplay its using the BT idrive and so using the BMW MIC You only then need the new external mic for SIRI |
theblues86.50 |
04-30-2019, 10:52 AM | #355 |
Rep 64
Does that mean when you make or receive calls you leave the CarPlay interface and go into the i-drive interface? Does the phone app in CarPlay still initiate the calls? Is this the recommended setup or is it recommended to only pair it to the unichip box and not i-drive bluetooth (like the wired versions)?
04-30-2019, 12:26 PM | #356 | |
Rep 212
What is the current status of the issues you are experiencing if you are not using Carplay MIC? There is an ongoing post regarding Unique AD (and Joyeauto) if you don't mind to continue the discussion over there. |
04-30-2019, 12:58 PM | #357 | |
Rep 560
The iPhone rings and it comes up using CarPlay If I press the Idrive wheel down on the green answer icon it answers but I can't hear anything. The other person can but when I look at my iPhone screen its showing that the audio output is CarPlay, but I cant hear anything Remember I'm using both the BT Idrive and CarPlay wireless both paired. So when the phone rings whilst in CarPlay it also shows on the dashboard and I just press answer on the steering wheel and that answers the phone call using Idrive and the output is Idrive BMW BT and works perfectly The carplay shows that I have answered the call and its going via the BMW BT and using the OEM mic I can drop the call with CarPlay red icon. I can make calls with either Idrive or steering wheel. You can also make calls using CarPlay |
ooshnoo880.50 |
04-30-2019, 12:59 PM | #358 |
Rep 560
What thread is that please
04-30-2019, 01:30 PM | #359 |
Rep 212
04-30-2019, 02:19 PM | #360 | |
Rep 1,696
Drives: 2014 428i and 2018 X5
04-30-2019, 05:48 PM | #361 | |
Rep 560
But you can have both BT paired which is good news. I wanted to use the OEM mic and this works. Looks like the external mic is only for SIRI |
theblues86.50 |
04-30-2019, 06:00 PM | #362 | ||
Rep 1,696
04-30-2019, 06:19 PM | #363 | |
Rep 212
Would "Hey Siri" work if you enabled it on the phone which probably then uses the phone's mic? |
05-01-2019, 03:11 AM | #364 | |
Rep 560
Takes 5 minutes to install and push cable down the A pilar I wasn't keen on using it and when I heard that the unit came with an external mic it put me off. But honestly its fine and installed correctly it doesn't show You can still use the OEM BMW mic for phone calls and that was noise cancellation so much better and cleaner sound for the other person on the call |
theblues86.50 |
05-02-2019, 04:49 PM | #365 |
Rep 1,696
I got it installed and have a couple issues. was curious if you had them as well. I posted them in this thread...
https://f30.bimmerpost.com/forums/sh...9&postcount=37
05-02-2019, 06:55 PM | #367 |
Rep 1,696
Thanks for the advice Mr. Moderator. I clearly didn't think of that when I posted in it's own "unique thread."
05-03-2019, 04:37 PM | #368 |
Rep 439
05-03-2019, 04:39 PM | #369 |
Rep 1,696
Yeah, re-directing people to my thread in the Unique CarPlay discussion. Or can't you read that?
06-05-2019, 01:20 PM | #370 |
Rep 439
Anybody have any luck reaching unichip tech support recently? Have not been able to get help since an update they gave me caused the “menu” button on the i drive controller to stop working I. CarPlay.
06-06-2019, 02:30 PM | #371 | |
Rep 38
06-07-2019, 03:06 PM | #372 | |
Rep 439
also, their support is very hit and miss. I was getting emails, not the only way they reply is via the website. Edit: some buttons stopped working but after the car went to sleep for the night, the buttons are all working now. Most stable release I’ve had for my unichip. They sent me some janky betas riddles with problems. Last edited by lemonchicken; 06-08-2019 at 02:50 PM.. Reason: Buttons working!! |
06-07-2019, 03:07 PM | #373 |
Rep 439
also, I'm about ready to give up on this unichip box and switch over to the joyeauto wireless CarPlay box when it is released for CIC, which should be any day now.
06-08-2019, 07:19 PM | #374 |
Rep 119
I just installed the unichip CarPlay for my 2015 with entrynav (and 10.25" screen from x5). I also installed a rear view camera to it as well. Overall I'm very happy with it (got it used for cheap). Does what it is supposed to do. Sound quality is a lil crappy in comparison to idrive. I think it's the aux cable, but I feel any system that uses the aux will sound the same. My rear view camera works well too ($30something on amazon), but the lines are too narrow for the car. This may be because of my larger screen? Anyone know if the lines can be disabled or even adjusted??
carplay |
