05-25-2015, 06:32 PM | #1 |
#ladydrivenamerica
Rep 12
F30 335i Track Setup
I have taken my stock 335i msport to the track now twice.
I've been driving with my stock 19" Wheels & Eagle F1 tires: 225/40x19 Front 255/35x19 Rear I know I need to get a new set of wheels and tires if I want to continue my new hobby. I was wondering if anyone currently tracks their F30 and what their set up is like? Any suggestions to improve the performance of my car would be greatly appreciated! |
05-26-2015, 12:11 AM | #3 |
Rep 766
There are plenty of discussions on this in the track and autox forum.
http://f30.bimmerpost.com/forums/forumdisplay.php?f=459 FWIW I've been slowly modding my car for better track/autox performance. ie upgraded the brake pads (Hawk Street/Race) and stainless brake lines are pending install along with a flush and new fluid (motul 600). I'm still on the OEM 400M wheels with the Pirelli rfts. However will be switching to an 18" rotary forged wheel, current contender is the TSW Bathurst 18x8.5 square and 255/40/18 Michelin PSS.
Well weathered leather, hot metal and oil, the scented country air.
Sunlight on chrome, the blur of the landscape, every nerve aware! 2014 328ix EBII - Sport AT, Light Pkg, Blk Dakota, Moonroof, Navigation, Heated Seats, HK Audio, Driver Assist, Sport Pedals, Dinan Springs, Bilstein B8s, M-Performance BBK |
Tobz_au245.00 |
05-26-2015, 11:30 AM | #5 |
Rep 693
I just tracked my F31, does that count?
That was my assumption as well, but I guess OP should clarify since car setup varies greatly. Generally, if someone says "track" I assume a real track, roadcourse of some kind. If they are drag racing I usually refer to that as the "Strip". If it is road courses OP then suspension and brake upgrades will make the biggest difference before adding more power. Stay away from the fancy drilled rotors, they look nice on the street but on the track they just reduce braking area. Think about the last professional race team you saw with drilled rotors.........
2018 M240i X-Drive | Sunset Orange Met
2015 328d X-Drive Touring M-Sport (Traded) 2015 Audi S4 Sepang Blue P+ | DSG | Tech Package | Adaptive Suspension | B&O 2015 Audi S3 Misano Red | 19" Sport pack w/Mag Ride | B&O 1983 Porsche 944 All stock |
05-26-2015, 12:40 PM | #6 |
Rep 3,258
Drives: 2015 F36 Jet Black Sport Line
Ok. Given what the OP said, it can be read both ways and I know there is quite a few here that participate in one or the other.......
2015 BMW F36 428i JetBlack. Sport Line Edition
25% 3M Tint| |
05-26-2015, 05:55 PM | #7 | |
National Championship #17 and Counting!
793
Rep 1,508
Also fully agree about the suspension and brakes advice. Drilled rotors are indeed mostly fashion. When braking at high speed you want the biggest brake area possible and tires that grip like all hell. Sometimes this is still not enough, but every little bit helps. If she gets the M performance brakes or some other Brembos, and upgrades the suspension components, that would make a big difference. Reducing roll is the primary concern. The M Sport suspension is already solid. |
05-26-2015, 08:22 PM | #8 |
Rep 10,346
Limited Slip Differential (BMW M Performance LSD or Wavetrac)
Your brakes might be fine but maybe getting good a changing out brake fluid. Spend money on driving schools (BMWCCA HPDE etc.) Have fun!
"Drive more, worry less. "
05-26-2015, 09:09 PM | #9 |
Pace Car Driver
1547
Rep 3,163
Mod the driver, not the car.
Get some 18 inch wheels and some sticky tires ( not slicks). Lots of track time before you start modding the car elsewhere. |
05-28-2015, 06:08 AM | #10 | |
Pace Car Driver
1547
Rep 3,163
Here are the 18" wheels you need for the track. Sell the RFT tires and get some track rubber. http://f30.bimmerpost.com/forums/sho....php?t=1131023 |
05-28-2015, 07:25 AM | #11 |
Rep 150
Mods in order of importance
1) Continuous driver improvement. 2) Make the car stop. 3) Make the car turn. 4) Make the car go. Joel
That's a lot of white |
05-28-2015, 09:22 AM | #12 |
Rep 141
I would upgrade your brake pads only for the fact that there has been instances where people's car's have gone into limp mode while tracking due to excessive brake heat. This would allow you to run longer on the track and have a safer experience.
If you have the m sport brakes, I believe the majority of the forums recommend porterfeild pads.
2014 BMW 435i xDrive M-Sport "Elphie" | Mineral Grey Metallic | Coral Red Interior | M Performance Package I | Premium Package | ConnectedDrive | bootmod3 OTS Stage 1 93 Octane Tune | M Performance Exhaust | M Performance Stainless Steel Pedal Covers | Dinan Performance Spring Set | Dinan Supplemental Ride Quality | Precision Raceworks N55 Ignition Kit
05-28-2015, 09:37 AM | #13 |
Rep 5,316
Drives: G80 M3 6MT
Apex racing wheels with PSS
Scott, Partner
Insight Automotive Consulting Click HERE for all discounted BMW New Car Pricing Click HERE for all BMW In Stock Inventory Specials Call/Text: 516-416-5481 Email: scott@insightautoconsulting.com |
05-28-2015, 11:12 AM | #14 | |
Rep 1,730
And changing pads will do nothing in terms of heat. You will create the same amount of heat with either pads because you are still converting kinetic energy into heat. Proper track pads will continue to function at higher temps, whereas street pads will cease to grip at high temps and could possibly melt/glaze/crumble. On the track, a major purpose of the brake system is to dissipate the brake heat, and prevent the fluid from boiling. This is where larger rotors with proper pumping vanes make a big difference. The rotors essentially function as heat sinks. Also cooling ducts or anything to redirect cool air to your rotors. The fancy slots and dimples have a marginal effect on improving performance, maybe the slots help in the rain...dimpled rotors are bad for a DD track car because they can crack after being significantly heat cycled. 2 piece fully floating rotors are nice for the track because the iron rings have less chance to crack due to the expansion/contraction the heat cycles put on them.
UNDRSTR
05-28-2015, 11:19 AM | #15 |
#ladydrivenamerica
Rep 12
Thank you all so much!
Yes, by track I mean road course. I have an OEM big brake kit with drilled rotors that I do not plan to replace for this car. I also plan to keep everything OEM since everything is covered under warranty. I agree that it is driver experience that is most important! Thank you for all your suggestions |
