BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > BMW F31 330D - P0101 & P115D error codes
      05-17-2018, 08:01 AM   #1
craigbeal
Drives: BMW F31 330D
Question BMW F31 330D - P0101 & P115D error codes
Hi all
Had an engine warning light up the last 4 weeks.
Car is a 2013 BMW F31 330D - N57D3O/01
P0101 - Mass or Volume flow “A” circuit range/performance
P115D
Only seems to flag up when under load
Replaced with a new Hatachi MAF sensor and new air filter and all good for a few days and then same error code again with engine light back up.
Cables to sensor seem ok so what now? Air leak maybe or EGR valve. How would I test for an air leak?
Any sudgestions would be great
Attached are the fault codes and the engine state when the error code was thrown up via Auto Doctor App
      05-20-2018, 02:01 PM   #2
craigbeal
An update if anyone ever has the same issue...
I dismantled & checked all the inlet pipes from the air filter down to the turbo for leaks and all seem fine and in good condition, so the took off EGR valve and cleaned that using carb cleaner and although it had a little carbon build up didn't seem much.
Also took off the MAP sensor on the manifold which again I've cleaned using contact cleaner and had quite a lot of carbon buildup on it but not sure how much inside the actual sensor itself.
Took it for a drive and so far so good but will wait and see as the MIL P0101 is only triggered under certain loads and not very often. Fingers crossed as there doesn't seem much in the way of info for the N57D30 engine ....
      05-29-2018, 04:34 AM   #3
craigbeal
So the error light came back on. Booked in to a BMW specialist tomorrow too see if they can now get to the bottom of the issue.
      06-03-2018, 12:48 AM   #4
craigbeal
Was a crack in the EGR rear cooler pipe. Seems like a super common problem on both the 2.0d and the 3.0d versions with a recall on 2.0d versions to fix them.
I've emailed BMW to see if they can do anything as I've seen a lot of cases now that BMW have replaced it on a good will and just charged labour...
      07-01-2018, 04:33 AM   #5
craigbeal
Fix this today. Got a EGR cooler for a 520d as all the units seem the same across multiple cars, for £95 delivered off EBay. Took an hour to fit and some coolent.
The Cooler pipe had 2 large splits in the end.
      07-08-2018, 03:52 PM   #6
Wunder2644
Drives: BMW 335d xD f31
What did BMW say about fixing it on any good will? I just got the same problem on my 335d -14 model
      07-09-2018, 03:36 PM   #7
craigbeal
I called and they said to take it in, would have cost for the inspection and the service centre where quite upfront and said it would likely not be covered for a good will so didn't bother booking it in.
330d, bmw, code, f31, p0101
