10-12-2018, 05:12 PM | #1 |
Diligentia Vis Celeritas
558
Rep 1,477
Drives: 335i
335i at Watkins Glen
Here's some video from Watkins Glen a few weeks ago... last event of the year, sadly. I was having trouble all weekend with my GoPro, and when I finally got some good video, my external mic started to crap out! I spliced together a couple of laps where the audio wasn't cutting out too bad, so not a total loss.
It's been a few years since my I've been up to the Glen, so with the repave a couple years ago, and running the full course this time (last time was in the NASCAR short course config), it was like an entirely new track to me. But once getting up to speed, lap times settled in at about 2:18. I am absolutely loving the car in it's current form...actually thinking of breaking from my plan to leave it as is, and work a little bit more on "adding lightness" : )
sspade2464.50 Savageenterprise980.50 Polo088161610.00 SportySpice204.00 N26Ghost496.50 jmg18663.00 DarkStarBimmer208.00 Gospeedracer27.00 David0ff1056.00 jdg5495.00 |
10-12-2018, 05:34 PM | #2 |
Rep 5,457
Drives: F30
One of the best tracks in America. Very close to my hometown too... seen Nascar tons there over the years. Would love to get my F30 out there someday. I hear BMW CCA Genesee Valley Chapter is having an event there this month....
N26Ghost496.50 |
10-12-2018, 09:04 PM | #3 |
Rep 640
Drives: 2008 M3 (E93)
I would be down for a track day there. Not a bad drive from long island
"Hard times create strong men. Strong men create easy times. Easy times create weak men. Weak men create hard times."
10-13-2018, 11:13 AM | #4 |
558
Rep 1,477
Drives: 335i
Yeah, it's an amazing track...such great flow, and so fast. It takes some commitment to get it right, but worth the effort. Climbing the esses flat out, exiting onto the back straight at 125+ ... I was smiling every single session.
Polo088161610.00 |
10-13-2018, 01:03 PM | #5 |
Rep 1,127
How are your brakes holding up. I think the msport brakes are terrific at VIR, but heard Watkins Glen is really hard on brakes and to get track pad if I plan to run it someday there.
10-13-2018, 01:20 PM | #6 |
558
Rep 1,477
Drives: 335i
Absolutely get track pads for the Glen. I use PFC 08 pads with my M Sport calipers/rotors... and Castrol SRF fluid.
Polo088161610.00 |
10-14-2018, 09:09 AM | #7 |
Rep 3,946
What's your oil consumption like during your track weekends?
My stock 2014 N55 with 100,000 miles on it consumed about 1 quart of oil this past weekend with NJ Chapter at Shenandoah. I was sharing the car with my GF so it was being run in back to back sessions. Oil used: Castrol EDGE European Formula 0w-40 |
10-15-2018, 09:11 AM | #8 | |
558
Rep 1,477
Drives: 335i
My N55 is stock as well, and I use Castrol Edge 5w-40. I have always run the car hard; initial break-in was fairly aggressive, and I had it on the track with just under 1000 miles on it.
10-16-2018, 05:44 PM | #10 | |
Rep 1,127
10-16-2018, 08:35 PM | #11 | |
Rep 3,946
I'll monitor it for the next few weeks. Oil used was Castrol EDGE 0w-40 (European Formula) and the N55 has over 100,000 miles on it. |
10-18-2018, 02:55 PM | #12 |
Rep 988
Love how the car looks. Your car has been making a real compelling case to me for dual duty work
MHD | BMS | VRSF | APEX | RECARO | TC Kline | BERK | Turner Motorsport | Eibach | BMW Performance
10-19-2018, 04:09 PM | #13 | |
558
Rep 1,477
Drives: 335i
I thought I was done modding this car, but I will probably continue to pick away at adding "lightness" and maybe a tune for some more power.
11-07-2018, 12:19 PM | #14 |
Rep 14,108
Drives: G82 M4C X-Drive
Nice run! What overlay is that? Are you using Harry's? Also, where are you mounting your external mic?
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3 IG: Raging_G82 |
11-09-2018, 11:45 AM | #15 | |
558
Rep 1,477
Drives: 335i
I'm using RaceChrono, and importing the data file, along with the GoPro video file, into RaceRender. I clip the external lavalier mic to the rear tow hook; it has a long enough cable to run all the way from the GoPro on the windshield, hidden behind molding all the way to the trunk.
jmg18663.00 |
11-18-2018, 07:34 PM | #16 |
Rep 262
Drives: 2013 BMW 335i M-Sport
What size tires did you run?
11-19-2018, 04:59 PM | #17 |
558
Rep 1,477
Drives: 335i
265/35 RE-71R tires on 18x9.5 Apex ARC-8 wheels
11-19-2018, 10:49 PM | #18 |
Rep 1,934
Wow 265 sq? How much camber are you running front and rear? I was under the impression 255 on a 9J was about as wide and square I could go without severe camber front and rear!
11-20-2018, 07:08 AM | #19 |
558
Rep 1,477
Drives: 335i
I'm running between -3.0° and -3.2° up front. Also, I have a mild front fender roll (hard to even notice). At this point, I think I could squeeze in 275s on 18x10s... planning to try 275s next season, and if there's still some room, I may go to a 10" wheel.
11-20-2018, 10:08 AM | #20 | |
Rep 1,934
Do you run this config track only, or dual duty?
11-20-2018, 02:28 PM | #21 |
558
Rep 1,477
Drives: 335i
When I ran the car a lot on the street, I usually dialed the camber back to -2.0° ... these days, I just leave it.
05-18-2019, 11:05 AM | #22 |
Rep 928
What suspension are you running? Ohlins/swift?
2015 335i 6sp manual with MPK and sport pack
GPlus intercooler and CP. Stage 1. CG precision dp. Staggered 19?s. 275/35/19, 245/40/19 ps4s. |
