02-06-2019, 08:23 AM | #45 | ||
Rep 129
Good to know! |
02-22-2019, 09:39 AM | #46 |
Rep 579
Yes, but keep in mind, without an LSD you will shred your inside tire if you really push the car. With DSC off. Im on Ohlins coilovers and before the LSD I would smoke the inside tire on long sweeping turns.
Current: 2021 M340i
Previous: 2020 X3M Comp BM3 E30 & 2016 340i 8AT DME Stage 2 | FBO/Catless Meisterschaft Catback | Ohlins R&T |
05-06-2019, 07:31 PM | #47 |
Rep 129
DSC fully off will disable the rear braking in corners? (fake torque vectoring).
05-07-2019, 02:45 PM | #48 | |
Rep 891
Only way to stop it is to code off eLSD.
328i RWD | MW on CRed Slick Top | 6MT | BM3 | MPE | GPlus FMIC | CSF Radiator | Millway Street Camber Plates & Monoballs | KW V2 6k/18k Swift Springs | F80 LCA/TS | SPL Bump Steer Kit | APEX SM-10 | R-S4 | DS2500 | RBF600 | SS Lines | Past: E36 328is & E38 740i |
05-12-2019, 09:15 PM | #49 | |
Rep 579
Current: 2021 M340i
05-13-2019, 12:22 PM | #50 | |
Diligentia Vis Celeritas
558
Rep 1,477
Drives: 335i
In Sport+ the stability control parameters are significantly reduced; with a mechanical LSD, I almost never feel it intervene, even on track.
Polo088161593.50 |
05-14-2019, 03:10 PM | #51 | |
Rep 182
05-16-2019, 09:00 PM | #52 | |
Rep 129
08-17-2019, 09:09 AM | #53 |
Rep 54
My 2 cents. I've experimented with both Sport+ and DSC off. In Sport+, I feel traction control kicking in and hurting my drive off some corners, which is why I tried DSC off. With DSC off, my rear tires were just spinning more off the corners, so that didn't improve my drive either. My lap times between the two were about the same, so now I just keep it in Sport+ mode for that added bit of spin protection. Maybe that will change the more track driving I do though.
08-20-2019, 02:22 PM | #54 | |
Rep 14,085
Drives: G82 M4C X-Drive
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3 IG: Raging_G82 |
08-21-2019, 11:00 AM | #55 |
558
Rep 1,477
Drives: 335i
eLSD only comes on with DSC fully off; Sport+ has reduced thresholds, but no eLSD.
08-21-2019, 11:07 AM | #56 | |
558
Rep 1,477
Drives: 335i
Well, I learned something recently when working with a tuner... long story short, back in 2016 when I had my eLSD coded out, the coder apparently coded out all stability control in Sport+. So all this time running in Sport+, I had no stability control at all active... which of course explains why I never felt it intervene : ) Oh, and along with killing Sport+ DSC, they also disabled ABS. Which makes sense thinking back to the occasional brief lock up on track over the years. (Nothing dramatic, as I was always able to manage it... but I always wondered how I occasionally overcame ABS when threshold braking!) So I guess I have no idea how invasive Sport+ DSC might be...all this time I thought it was great because it seemed to be sophisticated enough to let me drive at the limit and leave me alone when I didn't need it!
08-21-2019, 04:35 PM | #57 | ||
Rep 204
Drives: 14 F30 335i xDrive
08-22-2019, 06:58 PM | #58 | |
Rep 210
SCCA & Midwestern Council W2W, '91 Spec Miata, '07
NASA TTD Champion, Midwest, '99 M3, '09 Midwstrn Council TT Champion, BS, '10 GTI, '10 &'11 Midwestern Council TT Champion, BS, ‘17 BRZ, ‘19 Last edited by JMK007; 08-22-2019 at 07:20 PM.. |
08-25-2019, 02:00 PM | #59 | ||
Rep 1,934
Max slip with the Mp LSD is ~30%, so eLSD would trigger somewhere above that as no coding is needed to go to the Mp LSD.
09-02-2019, 09:10 PM | #60 | |
Rep 1,125
