BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > Sideways
      07-01-2019, 07:11 AM   #1
Lukelar1283
Drives: Bmw 328ixdrive
Sideways
Has anyone ever got there n20/n26 to get sideways on pavement with no snow? I’m unwilling to try it but I’m curious to see if anyone has done it lol. Post some videos of you got them.
      07-01-2019, 08:11 AM   #2
sspade
sspade's Avatar
Drives: F30
2016 BMW 320i  [7.87]
2014 BMW 328i  [6.83]
Not sure if this counts as sideways but I can definitely get the ass end to kick out if I juice it through a turn. Done that once or twice.
      07-01-2019, 09:13 AM   #3
Solidjake
¯\_(ツ)_/¯
Solidjake's Avatar
Poland
945
Drives: '13 328i Msport 6MT
We're not 16 years old, sorry.
Apex SM-10/DWS06+ | 400m/X-ice Xi3 | Injen Exhaust | Stoptech SS Lines | 335 Front Brakes
Hawk HPS 5.0 | RBF600 | ER Charge Pipes | Wagner Evo Comp 2 FMIC
Billfitz8209.50
      07-01-2019, 09:24 AM   #4
Lukelar1283
Lol I don’t think it’s about being 16 years old. Like I said I wouldn’t do it. I was just wondering if these things even have the power to get sideways at all. But hey you do you lol
      07-01-2019, 12:23 PM   #5
RMachuca3d
RMachuca3d's Avatar
722
Drives: F30 328i Msport
Depends on what tires your rolling on and the surface conditions, you REALLY have to be forceful to get it to go sideways, a little scandinavian flick works, but since our cars are so underpowered once the initial phase of rotation lessens the tires just grip again and the engine doesnt have enough umph to keep them spinning. And if you are on grippy asphalt forget it, needs to be old and dirty road to be able to do it.
In the rain its much easier.
This is for RWD, for Xdrive i imagine its practically impossible in the dry.
      07-01-2019, 07:52 PM   #6
MONSTAR
#gotboost
MONSTAR's Avatar
Drives: 2018 M2
I'd actually disagree....with DTC completely off, it isnt too difficult to get sideways if you gas it during say a u-turn or the like
2018 F87 M2 (09/2020 - )
Dinan Cold Air Intake |Dinan Axle Back | VRSF 6.5" Intercooler | VRSF Catless Downpipe | VRSF Charge Pipes | BM3 | MST Inlet v2 | Turbosmart VR11
2013 F30 328i (12/2015 - 09/2020) SOLD!
sspade2463.00
      07-01-2019, 09:22 PM   #7
RMachuca3d
RMachuca3d's Avatar
722
In 1st gear, you might get a little slide, anything after you really have to coax it into a slide which will be short lived due to low hp\tq.
      07-03-2019, 05:14 AM   #8
rjd_F30
rjd_F30's Avatar
Drives: 2013 335i 6MT
I have xDrive, so my car has never been sideways when there's no snow on the ground. But with RWD and a skilled enough driver, you can get almost anything to slide. It'd be even easier with 3 pedals...
However, you'd probably have to be more forceful with your inputs because of the lower power numbers. Just do it in an empty parking lot, don't be the idiot that tries to slide his car anywhere where there's even a remote chance of hitting someone else or damaging anything that is not your own.
      07-03-2019, 08:29 PM   #9
Relax19
Drives: car
Here's an old video of me sliding around in a stock 328i after screwing up the first section.
Open diff FTL...
      07-04-2019, 01:51 PM   #10
fcbrandon
Guy
Drives: 20 X3 M40i
Done it several times I my xDrive, dry or wet, full tread OE tires, zero mods. Waaaayyy, easier in the wet, and of course needs to be in Sport+/traction-control off. Even with stability control still on, the system gives you a lot to play with before kicking in.
Can be done at totally reasonable speeds too - <50mph in the dry, <30mph in the wet. The car is heavily RWD biased, so it drifts quite well. Coming from pure RWD, it's pretty cool to feel the AWD work through a drift, but it's nothing like a Subie or EVO.
@Relax19 is right about the diff, it really hampers things, but these aren't exactly drift-missiles, so it's OK
      07-11-2019, 02:43 PM   #11
Icarium81
Drives: 2018, 330i xdrive
What I'm seeing is a lot of pansy asses who aren't willing to push their rides...
Haven't had it sideways yet, I've only had it a month, but pushed it pretty hard on a cloverleaf and at about 85 kmh it started to step out. Wasn't wet and I was just seeing what it would take to make it squeal a bit.
      07-11-2019, 11:24 PM   #12
Gen13 F36
Gen13 F36's Avatar
Drives: 428i Gran Coupe
Go to the track.... high speed turn with proper setup to oversteer than indersteer.. you need both.. then you can drift thru the long fast sweeper. Those where the days with my underpowered 240sx ... before the Silvia transformation.
Yes, its possible.
      07-11-2019, 11:27 PM   #13
RMachuca3d
RMachuca3d's Avatar
722
Its highly dependant on the tires. When i had my 437's with the stock michelins that are useless when its chilly outside, i was sideways everywhere until they warmed up.
      07-16-2019, 11:57 AM   #14
drk92
Drives: Alpine White 428i F36
Like others have said, it depends heavily on what tires you're using. Stock 400m staggered setup with 235/45/18 fronts and 255/40/18 rears. With the stop RFT I was able to get sideways all the time, even on warmed up tires. I later switched to Pilot Super Sports, much much more difficult to get it to go sideways. Later switched to Pilot Sport 4s, the rear tires now have so much grip I can't even do a burn out cause my front brakes won't keep the car from moving forward, let alone making the car go sideways.
