10-21-2019, 11:44 PM | #1 |
Rep 28
Adaptive headlight malfunction after adjusting height with screw
Hello,
I have a 2014 F36 with adaptive led headlights Last night after i came home i decided to try and aim my right low beam a bit higher, and i tried turning the screw on the headlight about 1 turn counter clockwise. I did this while the engine was off and ignition on, with the light switch tuned to adaptive position. Then i turned the ignition off, locked the car and left. Since my car was parked in a parking lot in front of other cars, i did not see whether turning the screw counter clockwise lowered or lifter the beam, so after a bit of googling i read that turning the screw clockwise raises the beam. So i went back to my car, opened the hood and with the car completely off i turned the screw clockwise a total of 2 full turns and then i locked the car and left, thinking that i will see what happened today. So today when i started the car i got 3 errors: Adaptive headlight malfunction Lighting system: Front right malfunction Headlamp vertical aim control malfunction My right angel eyes coronas are not working, as well as the right turn signal. Low beam is working, but both headlights are not turning anymore, they just stay still. Now i read that supposedly you should do this adjustment with the light switch in the full on position (non-adaptive). So i am thinking that by doing this adjustment with the car off i somehow messed up the calibration? Or is it something else? |
10-22-2019, 06:36 AM | #2 | |
Rep 464
I suspect you may be right re calibration and you will have to teach-in the adaptive headlights again. A bit of a long-shot... with the vehicle off, adjust the headlight back to the original height and disconnect/reconnect the battery to see if it clears the errors. Larry
2020 Black Sapphire M340iX
2014 Estoril Blue 435iX - sold |
10-22-2019, 09:59 AM | #3 | |
Rep 28
