04-23-2019, 12:40 PM | #617 |
Re-Builder
17
Rep 43
Tony Twoclicks Great thread, thanks for providing an update to your script, I keep getting the below error when running the script, any ideas how I get around this error?
Code:
Determining OS architecture... - Windows is 64-bit Finding installed components... - Found E-sys Launcher Premium 2.8.2.155 installation in: "C:\Program Files (x86)\TokenMaster\E-Sys Launcher Premium" - Found E-sys 3.27.1 installation in: "C:\EC-Apps\ESG\E-Sys" Rearming E-Sys Launcher Premium... - Removing soft-token path from E-sys configuration - Deleting Launcher configuration - Deleting RSA keys - Predating system (please wait) ----------------------------------------------------------------------- WARNING: Cannot redate file or folder ----------------------------------------------------------------------- There was a problem redating "C:\ProgramData" Rearm may be unsuccesful. Close all programs before running this script to minimize file or folder locks. Reboot if the problem persists. Avast Antivirus users should temporarily disable the Self-Defense module by going to Menu -> Settings -> Troubleshooting and unchecking the corresponding box. Re-enabling this settings after succesful completion of this script is highly recommended. ----------------------------------------------------------------------- Completed, but with warning(s)... See "ReadMe.txt" for Launcher-specific valid date ranges and other notes. Happy coding and consider donating to a charity for all the good work Tokenmaster has done! Your current system date is: 23/12/2018 Press any key to continue . . . I've fixed this by uninstalling Avast... Last edited by Rich84Ts; 04-23-2019 at 03:05 PM.. |
04-23-2019, 04:17 PM | #618 |
Rep 274
04-23-2019, 04:23 PM | #619 | |
Rep 274
Cheers, Tony |
04-24-2019, 05:15 AM | #620 |
Rep 2
Hi Everyone
I'm new on the forum and to Bimmers world. I've just made acquisition of an F20 116d Ed and I'm trying to gather as much information as possible before starting to handle coding. Before going further in installing Esys and Esys Launcher, I had question : Is it necesary to get an activation code from TokenMaster to have the Launcher work for the first time we install the Launcher ? Because if so I think it's useless to get the Esys installed at once . Thanks for your support |
04-24-2019, 03:57 PM | #621 | |
Rep 274
Good luck and have fun coding. Cheers, Tony |
Amazingh0.00 |
04-25-2019, 04:24 AM | #622 |
Rep 2
Hi Tony
Thanks so much for your prompt reply . Actually I was not looking for advice for coding here.I know there are many other threads handling the topic.I came across the discussion on the Launcher Script and I wanted to know more about it. I'll follow your instructions and see what will happen. To sum up, I need first to revert the Windows 10 system date to the timeframe mentionned in the script, before installing the Launcher , then install the Launcher and after run the script ? Cheers Last edited by Amazingh; 04-25-2019 at 04:31 AM.. |
04-25-2019, 05:03 PM | #623 | |
Rep 274
Cheers, Tony |
04-27-2019, 04:13 PM | #625 |
Rep 274
04-27-2019, 04:24 PM | #626 |
Rep 332
It shouldn't require rearm every time but it probably depends on what's been happening on your PC since the last time you used ESys. It doesn't seem to matter if you do the rearm, and it's pretty quick so I see no problem with it. An important requirement is that the date remains reverted for the whole of your session. Disconnecting the PC from any internet connection before you start should avoid any problem with this.
04-28-2019, 03:53 PM | #627 |
Rep 103
I get the error message that "esys" is not found when trying to rearm.. can someone help?
M140i Mineral Grey 3door 09/18 - Supersprint Catless Downpipe / Stage 2 MHD
04-28-2019, 06:13 PM | #628 | |
Rep 274
Whoops, my bad... I just realized that I was incorrect in my reply to Amazingh the other day: E-sys has to be installed before running my rearm script as its folder needs to be redated for the rearm to be succesful. Sorry about that, it's a check I added to the script recently and forgot all about it. So to answer your question: install E-sys first. Cheers, Tony |
04-28-2019, 08:50 PM | #629 | ||
Rep 103
04-30-2019, 12:56 PM | #630 | |
Rep 274
Cheers, Tony |
05-02-2019, 12:54 PM | #632 |
Rep 73
Any modification ideas for a 420d coupe mineral grey ?
Hi guys ,
Thought I'd ask you guys for some mod ideas I've got a 420d coupe mineral grey with a performance pack on it. want it to look meaner and more modified.... Any suggestions |
05-03-2019, 11:38 AM | #633 | |
Rep 274
Did you see the title of this thread? This has nothing to do with that. Stop being lazy and do a search or create your own thread. |
05-03-2019, 11:42 AM | #634 | |
Rep 274
Did you right-click the file and choose Run as Admin in the menu? Cheers, Tony |
05-05-2019, 01:50 PM | #636 |
Rep 4
hello TOny, this is my first post and I would like to thank you in advance for your answer.
I use Launcher Premium 2.8.2.155 and Esys 3.27.1_RC_b44813 and pszdata 63.3.003- when I proceed to the rearm with 2.0.4 the procedure is successful (completed succesfully) with the green screen and the date set 01.07.2018. When I start the premium launcher the window comes out where it asks me for the activation code (request code CS43A500007A0EFA83) and not the screen with the pin request. What could be the problem? I state that the language of W10 is English, English time zone English keyboard. sorry if there are imperfections but I use google translate because I'm Italian |
05-05-2019, 02:19 PM | #637 | |
Rep 332
05-05-2019, 04:23 PM | #638 | |
Rep 274
Other than that, I don't know why you're getting the activation screen, although I'm pretty sure it's got something to do with the regional blacklist Tokenmaster build into the Launcher. There was a document about this on Google some time ago. The check involved more than just the system language, timezone and keyboard settings, but I don't remember the details. Maybe you can do a search and let us know Sorry I can't help you further. Cheers, Tony |
clock, date, esys, launcher, premium |
