05-22-2020, 10:36 AM | #1 |
Rep 65
Higher Oil Temp After Oil Change
Changed my oil yesterday. Manual and underside of the hood both say 0W20 so that's what I put in and hopefully is the same thing the dealer had put in. My oil temp is reading 15-20 degrees higher than it did before. Is this normal?
05-22-2020, 10:40 AM | #2 |
Rep 16,079
What's normal? The oil weight shouldn't affect engine temperature, as it's thermostatically controlled. Driving conditions do. The car runs hotter on the highway than in town. Hotter is more efficient, but can cause knocking when accelerating, so the oil is cooler when the car anticipates acceleration rather than cruising.
05-22-2020, 10:46 AM | #3 | |
Rep 65
05-22-2020, 12:25 PM | #5 |
Rep 3,752
Summer is here .... woohoo
floridaorange10144.00 |
05-23-2020, 09:23 AM | #6 |
Rep 125
Drives: 2024 BMW 228i Gran Coupe
And, you should see what the track does to oil temperature. When I was running Porsche Caymans, I would show about 195-200 in Sport Mode on the highway at 70+. On the track after 2-3 laps, I would show 235+ (of course I was doing a tad more than 70+. And that was an engine running 8+ quarts of oil.
05-23-2020, 12:45 PM | #7 | |
Rep 909
05-24-2020, 12:00 AM | #8 |
64-bit
598
Rep 814
Drives: 2018 BMW 340i xDrive
I have the M Performance Electronic Steering Wheel and it shows an digital reading of 226 degrees. This is just normal driving in comfort mode. Now that summer is here it is showing a little higher at 228. If I'm driving in sport mode i am seeing 232 degrees. Funny thing is when I'm on Eco Pro it drops to 210, 215 and 220 degrees.
05-26-2020, 05:20 PM | #9 |
Rep 338
Ah, so glad someone cleared this up i was also worried that my temps putting around town was sitting at around 210 ish and then when i go blitzing on the freeway it goes to around 230 ish and no more...
2013 320ix N20 8AT|BM3 stg1|Muff Res Delete|HPB-LED-Amber-DRL's
IG: DadzBmer_N2o |
05-27-2020, 05:36 PM | #10 |
Rep 1,045
wow, my temp has never reached that high ever, even under heavy acceleration pulls after pulls, weird. For me in town it never pass 194F ever, no matter how long I drive or stuck in traffic. On highway, i get up to 210F after 30 mins, but I have to floor it hard for a good 10 mins to get near 220F. And this is during summer nights too which is about 74F outside. Do you have the factory oil cooler ? You can see it behind the front bumper before the tires.
Mods: Dinan Tuned, Intake, Catless DP
05-27-2020, 06:13 PM | #11 | |
Rep 2,499
Temp gauges have been designed to have the needle pointing in the middle in normal operating conditions or one tick below. Last edited by upsidedownfunnel; 05-27-2020 at 06:21 PM.. |
rob.james.arias4.50 |
05-27-2020, 07:13 PM | #12 | |
Rep 338
IG: DadzBmer_N2o |
05-27-2020, 07:15 PM | #13 | ||
Rep 338
IG: DadzBmer_N2o |
