03-02-2020, 09:02 AM | #1 |
Rep 40
Help: Car won't start after valve cover (VCG) job
Hello all,
So just finished replacing my Valve cover and gaskets on my X1 2013 with the N20 engine 82k miles. Tedious job but pretty straightforward. I have done all VCGs on all my bimmers E30, E46, E92, and never had a problem. However, the car won't start. It cranks but it won't start. Battery was disconnected before the job and fully charged with my battery tender overnight after the job. I double checked all connections, bolt torques, etc. and all seems to be ok. I read the codes with bimmerlink and the only one I get is: Code A10A EWS4_Timing_Chall_Resp_Fehler Symptom: No signal". Any suggestions? -appreciate any input.
BMW CCA 475714
03-02-2020, 11:15 AM | #2 | |
Rep 188
Drives: 2013 328i xDrive
03-03-2020, 03:16 AM | #3 | |
Rep 54
CandyRedRC46242.00 smallba74.00 |
03-05-2020, 09:11 AM | #4 |
Rep 40
SOLVED: When reinstalling the High pressure fuel pump (HPFP) it is very important to MANUALLY crank the engine so that the exhaust camshaft is at bottom dead center (lowest point). I did not do this and broke the HPFP. Also the fuel rail needed to be primed. New HPFP kit was $300 OEM Bosch.
BMW CCA 475714
