05-30-2016, 01:35 AM | #1 |
Rep 232
Vacuum on N20 with electronic wastegate
Hi,
Hopping someone can help. Where can I locate a vacuum source for 2014 328i equiped with electronic wastegate? I don't really want to be tapping into the brake boosted. Any help will be much appreciated. Cheers |
09-15-2018, 04:40 PM | #2 |
Rep 1
Hey everyone, I have this same question. Has anyone answered this yet? The only vacuum source I’ve found, as well, is the brake booster, straight from the vacuum pump on the back of the head. Any help would be appreciated.
Thanks in advance. Been researching for quite some time. |
09-19-2018, 12:31 PM | #3 |
Rep 325
Drives: 2016 F36
What is your need for vacuum? What is the demand and do you know the min and max inches of mercury needed?
There are 12V DC engine-independent vacuum pumps. This might be a best-fit option for you guys depending on what your needs are and have room to mount. If this sounds like an option just look for Street Vacuum Pumps. I know Summit Racing and Jegs carry them.
◊ 2016 F36 xDrive N26 ◊ Black Sapphire Metallic ⁞ Dakota Black ◊
║ VRSF HD FMIC ║ ER DP custom paint ║ AWE cat back Exhaust Suite ║ NGK Plugs ║Bootmod3 Stage 1 93 ║ GFB DV+ ║ BMS 10mm Front ⁞ 12mm Rear Spacers ║ P Style BSM Rear Spoiler ║ Smoked Front Reflectors ║ Madico Onyx 20 Tint ║ LCI Lighted Trim Bezel ║ Opti-Coat Pro+ ║ |
09-20-2018, 09:15 AM | #4 | |
Rep 2,382
2013 F30 328i: MHI Big Turbo, GFB DV+, Mishimoto CAI, ER TIC/CP/Catless DP, AWE Touring Quad Exhaust w/ Resonated Midpipe, NGK LI Plugs, BM3 with PTF Stage 2 91 AGG Tune, Fuel-it Stage 2 LPFP, Solowerks S1 Coilovers, and DEPO/M-Sport Retrofit |
