08-15-2018, 11:14 PM | #45 | |
Rep 107
My extra burbles on Stage 1 non AGG on my N26 are only on SPORT or SPORT+. On comfort/eco the car feels stock as fuck lol. http://www.bootmod3.net/log?id=5b7454c7d10b4335f7a35658 anyone wants to look at my log? everything seems fine to me, wondering if IAT temps are always over 120? |
08-16-2018, 09:21 AM | #46 | |
Rep 2,382
Okay, so my first recommendation will be to turn off half of those values. You can turn on some for a specific log but otherwise you won't need things like battery temp and such. Secondly, you probably don't want to take them as long. So, your log appears fine and you seem to be driving through the city or a neighborhood(given the low gears), so high IAT is normal since it also appears to have been 80~ degrees. With an upgraded FMIC and on the highway or doing a pull, you'll see the IAT drop drastically. Otherwise, everyone's IATs will be high at slower driving speeds.
2013 F30 328i: MHI Big Turbo, GFB DV+, Mishimoto CAI, ER TIC/CP/Catless DP, AWE Touring Quad Exhaust w/ Resonated Midpipe, NGK LI Plugs, BM3 with PTF Stage 2 91 AGG Tune, Fuel-it Stage 2 LPFP, Solowerks S1 Coilovers, and DEPO/M-Sport Retrofit |
08-16-2018, 09:48 AM | #47 | |
Rep 107
Since i live in NYC i usually don't ever drive past 40 mph. LOTs of stop and go here. Yesterday was my first time datalogging spent hours on google researching normal values of cars. I can't turn off all the values because i literally can't scroll on BM3's website I read that i need a mouse since trackpads usually don't work. I usually just zoom out to find anything. |
09-20-2018, 07:17 AM | #48 |
Rep 3
ER Catted Downpipe Safe burble Settings
I’m thinking about getting a catted downpipe. If I go onto stage 2 non-agg 93 OTS, will the burbles on that map mess up my cells inside my catted downpipe?
Also will going onto stage 1 or stage 2 non-agg setup my burble settings for me where it doesn’t give my (stock cat/high flow cat) a huge beating or do I have to do that myself? Also if I lower the slider on the burble settings will it still ruin my stock ca or high flow cat? |
09-20-2018, 07:52 AM | #49 | |
Rep 325
Drives: 2016 F36
1. Stage 1 program / Stage 1 appropriate burble settings 2. Stage 2 program / Stage 2 appropriate burble settings or 1. Stage 1 program 2. Stage 2 program 3. Burble settings
◊ 2016 F36 xDrive N26 ◊ Black Sapphire Metallic ⁞ Dakota Black ◊
║ VRSF HD FMIC ║ ER DP custom paint ║ AWE cat back Exhaust Suite ║ NGK Plugs ║Bootmod3 Stage 1 93 ║ GFB DV+ ║ BMS 10mm Front ⁞ 12mm Rear Spacers ║ P Style BSM Rear Spoiler ║ Smoked Front Reflectors ║ Madico Onyx 20 Tint ║ LCI Lighted Trim Bezel ║ Opti-Coat Pro+ ║ |
09-20-2018, 09:04 AM | #50 | |
Rep 2,382
Noelified228.00 |
09-20-2018, 10:31 AM | #51 | |
Rep 3,680
The burble setting is largely independent of what stage tune you are on.
Noelified228.00 |
09-20-2018, 02:38 PM | #52 |
Rep 325
Drives: 2016 F36
Since we're on the subject of burbles and tunes, I want to point out my observations with respect to exhaust system and burbles. Just so we don't assume all BM3 burble settings will give standard results. I understand the physics of whats happening and it makes perfect sense but I just wanted to mention what I have observed even prior to running a tune on a 2016 N26.
1. Catless DP, stock N26 mid-pipe and muffler
Again this is without a tune and burble settings. So having the AWE mid-pipe and axle-back resonator has made the biggest difference in burble, this will most likely be true for anyone who has muffler delete. The catless DP only made a significant difference with the AWE suite and that difference was more tone then anything.
║ VRSF HD FMIC ║ ER DP custom paint ║ AWE cat back Exhaust Suite ║ NGK Plugs ║Bootmod3 Stage 1 93 ║ GFB DV+ ║ BMS 10mm Front ⁞ 12mm Rear Spacers ║ P Style BSM Rear Spoiler ║ Smoked Front Reflectors ║ Madico Onyx 20 Tint ║ LCI Lighted Trim Bezel ║ Opti-Coat Pro+ ║ Last edited by Noelified; 09-20-2018 at 03:22 PM.. Reason: typo |
rjd_F301999.50 |
