07-03-2022, 05:00 AM | #1 |
Newbie with some skills
22
Rep 70
Drives: BMW F30 318D Luxury
[SOLVED] Speed limit failure after retrofitted M steering wheel
Hello everyone,
My car comes with a multifunction steering wheel with set and reset button
I’ve retrofitted a long ago LIM function (with F30 cheat sheet)
Work flawless during months; Today I’ve retrofitted the M steering wheel with LIM button : Media buttons works but LIM function doesn’t : LIM SPEED LIMIT FAILURE on instrument panel/CIC…. Error memory : MFL wrong variant I've coded :
Could you help me with this problem ? Edit :
Retrofit : S676A, S3AGA, S481A, S488A, S459A, S5ACA, S5DCA, S6NKA, S8THA (emulator), S710A Last edited by ReMiii40; 07-08-2022 at 02:27 PM.. Reason: more informations |
07-06-2022, 04:10 AM | #2 |
22
Rep 70
Nobody ?
Temporarily I disabled the LIM function, so I use the LIM button like the SET button. I can live without the LIM function but I need to find a SET button for the M Sport steering wheel, do you know where I could find this button?
Retrofit : S676A, S3AGA, S481A, S488A, S459A, S5ACA, S5DCA, S6NKA, S8THA (emulator), S710A |
07-08-2022, 01:37 PM | #4 |
22
Rep 70
solution below
Good news guys! I found how to activate the LIM function. An additional FDL must be coded. It's soooo weird because with the Sport steering wheel I just needed regular FDL codes (found on Super Cheat Sheet), I've read tutorials for X5, X3, Series 1, 3 and 4, no one talks about this extra FDL code.
I use ESYS for VO code S710A + S249A + S544A, so my car come without any FDL modifications; >>>>>>>>>
I just changed that >>>>>>>>>
And it's work
Retrofit : S676A, S3AGA, S481A, S488A, S459A, S5ACA, S5DCA, S6NKA, S8THA (emulator), S710A Last edited by ReMiii40; 07-08-2022 at 02:28 PM.. Reason: grammar |
08-08-2023, 11:44 AM | #6 |
Rep 82
Great info, thank you very much. I managed to remove all errors for wrong steering after retrofitting the M Sport steering wheel.
I must add that I also had to change LIN_VARIANTE_LRE lre_tlz_lhz -> lre_lhz I also had LRE invalid version error. |
ReMiii4021.50 |
08-16-2023, 03:22 AM | #9 | |
22
Rep 70
05-08-2024, 10:45 AM | #10 |
Rep 1
Hi, i have retrofit a multifunction steering wheel and program it to the buttons work but my lim button causes a error on the traction control so i'm wondering how you have disabled the lim
